double wide trailer
Old October 18th 10, 09:40 PM posted to rec.aviation.soaring
Tony[_5_]
Default double wide trailer
i know its been done a few times. I've heard of a husband/wife duo of
Libelles that had a double trailer. Also I've seen a double 1-26 open
trailer. Leah and I only have one pickup but two gliders and tend to
like to go places together. I'd like to solicit opinions (dangerous
thing to do here!) on how you would design a trailer to fit two
gliders, namely two Cherokee II's. It may require some creativity as
they have a fixed center section approx 3 ft wide. I'd like something
enclosed. Stable while empty or with one or both gliders loaded.
Old October 19th 10, 12:06 AM posted to rec.aviation.soaring
bildan
On Oct 18, 2:40*pm, Tony wrote:
i know its been done a few times. *I've heard of a husband/wife duo of
Libelles that had a double trailer. *Also I've seen a double 1-26 open
trailer. *Leah and I only have one pickup but two gliders and tend to
like to go places together. *I'd like to solicit opinions (dangerous
gliders, namely two Cherokee II's. *It may require some creativity as
they have a fixed center section approx 3 ft wide. *I'd like something
enclosed. *Stable while empty or with one or both gliders loaded.
The usual max width for interstate highways is 102 inches plus 5" for
necessary protuberances like mirrors. That's pretty wide but it could
still be a squeeze for two gliders side-by side. Maybe put the
fuselages in the middle one nose aft and the other nose forward. The
wings could be on tracks to the outside with the tips in opposite
directions. It's doable - especially with a small glider like the
Cherokee II.
Old October 19th 10, 12:11 AM posted to rec.aviation.soaring
Just buy a 2 seater...
Old October 19th 10, 12:48 AM posted to rec.aviation.soaring
Craig[_2_]
On Oct 18, 4:11*pm, "
It shouldn't be too difficult if they are loaded with one fuselage
facing forward and one backward. I've had trailers that loaded over
the tongue so and it wasn't a problem. You might even be able to set
it up so that one loads from one end and one from the other. That way
they can be used independently.
What a nice problem to have ;-)
Cheers,
Craig Funston
Old October 19th 10, 01:23 AM posted to rec.aviation.soaring
harold
On Mon, 18 Oct 2010 16:11:58 -0700 (PDT), "
A two seater is obviously not what they want. The poster asked a
reasonable question. Why do you fell the need to be an a-hole and
make such a stupid comment?
Old October 19th 10, 05:02 AM posted to rec.aviation.soaring
A two seater is obviously not what they want. *The poster asked a
reasonable question. *Why do *you fell the need to be an a-hole and
Harold;
I was going to comment and invoke the glass-hole syndrome, but you did
a much better job.
aerodyne
Old October 19th 10, 05:24 AM posted to rec.aviation.soaring
Tony[_5_]
now now guys everyone play nice.
Old October 19th 10, 12:09 PM posted to rec.aviation.soaring
John Bojack[_2_]
I think I saw Jim Stoia (sp?) show up at Perry one year with two Libelles in
one trailer.....remember thinking it was a very slick and efficient set-up,
but don't remember the specifics. He lives in South Carolina.
J4
Old October 19th 10, 12:37 PM posted to rec.aviation.soaring
rlovinggood
but don't remember the specifics. * *He lives in South Carolina.
J4
Yea. He got Herr Spindelberger (Cobra) to build a special trailer for
an "old-timer" glider: one that needs LOTS of room for a wide chord
and stuff. Later, he found he could stuff two Libelle's in it.
Ray Lovinggood
Carrboro, North Carolina, USA
Old October 19th 10, 01:09 PM posted to rec.aviation.soaring
doug
We have used ordinary utility trailers hauling up 4 SparrowHawks at
one time (just fits in a 24 footer with double racks for wings above
the fuselage) The big question is how long the wings are. That is
usually what determines the length of the trailer. The 24 footer my
friend has weighs about 3500 lbs. empty and my dad has a lighter 22'
trailer that weighs around 3000 lbs. I imagine that with the chord of
the Cherokee wing, you could probably make a rack for one wing on each
wall and the other 2 overhead (We screwed a 2X4 to each wall to
support another 2X4 bridging across. The weight of the wings and
where you can support them obviously might require something a little
different). The trailers are about 8' wide inside, so the two
fuselages should fit. Might have to have them nose to tail so you can
get around them. We just have the fuselage sitting on the dolly and
tie it down with cargo straps. Both trailers (one's a Haulmark and
the other is an Interstate) have elastomeric suspensions and tandem
axles. They ride very nicely, so the gliders don't get beat up.
Price wise, they are hard to beat also. 5 years ago, they were around
$7K - $8K new. That and a little wood for racks and it is a lot
cheaper than a Cobra for one glider. I saved the secret benefit for
last - once the gliders are set up, you have a nice, shady "club
house" to hang out in.
ASK 21 in Cobra trailer single or double axle? Karaka Soaring 7 June 19th 09 10:15 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Double scissor jack for trailer ramp? Bullwinkle Soaring 15 January 18th 06 05:18 PM
Five Foot Wide Glider Trailer Steve Leonard Soaring 2 December 8th 05 03:35 AM
Five-foot-wide glider trailer? Bob Kuykendall Soaring 1 December 6th 05 10:45 PM
