a Li-Ion in a lead acid world.
Old November 12th 10, 09:52 PM posted to rec.aviation.soaring
jcarlyle
Default a Li-Ion in a lead acid world.
Brian,
Very interesting post! I've never given a thought to the fact my cell
phone and iPAQ batteries were Li-ion.
You mention that you ignited a Li-ion with a hammer. That's not very
realistic as an in-cockpit trigger, so in your view what might cause a
Li-ion battery in a cell phone or a iPAQ (that had been fully charged
on the ground) to catch fire?
-John
On Nov 12, 2:45 pm, brianDG303 wrote:
When you say that the Peak battery is a lot safer, I'm not all that
convinced, because 1) I was never able to ignite the Li-Ion's other
than with a hammer, and 2) everyone is flying with Li-Ions, in cell
phones, iPaq's, Oudies, Socket Mobile power packs, etc. and I don't
hear of those catching on fire, ever. Not to mention all the Li-Ion's
sitting on job sites everywhere all night on chargers, if one burned
in Seattle I would know about it.
But I think that is something for each person to decide and I won't
attempt to convince anyone Li-Ion's are safe, just to consider how
many they are already flying with. One of the batteries I burned up
was from an Ipaq 3950 and it was clear that you Can Not survive such
an event without losing the canopy at a minimum. The smoke, not only
from the battery but from the plastic case and components goes on for
about 90 seconds, is very acrid, think burning tires. The youtube
videos don't do it justice, I think because they burn the battery only
and not a PDA/PNA at the same time which is where a lot of the smoke
comes from.
Old November 12th 10, 08:54 PM posted to rec.aviation.soaring
brianDG303[_2_]
Frank, I have a problem with those Peak Batteries, the web site
doesn't give enough information. Size, what kind of charger, etc.
Maybe you or someone could dig into it a little and report back. I did
read the article in Soaring but felt it was thin in places.
Brian
Take a look at Scott Fletcher's article in this month's Soaring
Magazine. *While very expensive (about 5x), the Li-Fe-Po (Lithium-Iron-
Phosphate) battery pack is a lot better suited to soaring use than
either Li-ion or SLA batteries. *The K2 Energy (http://www.peakbattery.com/) 12V 10AH pack is the same size and form factor
Frank (TA)
Old November 13th 10, 01:53 AM posted to rec.aviation.soaring
Frank[_12_]
Brian
Frank (TA)
Brian,
The K2 site sells a compatible charger (which btw is also much smaller/
lighter than my older VDC Electronics Battery Minder Plus), and will
charge two K2 LiFePo batteries in parallel. Cost for one battery, one
charger and shipping to Columbus OH was about $242 US.
The combination is much more expensive than my SLA setup. However,
when I consider the cost of modifying my battery compartments to
accommodate larger batteries, or the potential cost (i.e., my life!)
of not having a transponder/FLARM next year, I'm comfortable with the
tradeoff ;-).
Frank (TA)
Old November 13th 10, 06:29 AM posted to rec.aviation.soaring
Mike the Strike
I remember fun days working in a lab where colleagues were developing
the "revolutionary" sodium sulfur battery (colloquially referred to as
the "fire and brimstone" battery). The chief skill developers learned
was how to run fast while wearing asbestos suits and full-face
protective helmets. If you've never had to deal with a bucket of
burning molten sodium, you've never lived! (Hint - water isn't
terribly useful!) You probably wouldn't want any quantity of burning
(molten or otherwise) lithium near you or in your glider either.
Lithium is WAY too close to the reactive end of the periodic table
(right up there with sodium, magnesium and potassium).
MIke
Old November 13th 10, 04:54 PM posted to rec.aviation.soaring
MIke
Most smaller Cessnas and the Grob G-103 have magnesium wheels....and I
like bananas for the potassium before I fly.
aerodyne
Old November 13th 10, 11:33 PM posted to rec.aviation.soaring
brianDG303[_2_]
the "fire and brimstone" battery). *The chief skill developers learned
protective helmets. *If you've never had to deal with a bucket of
burning molten sodium, you've never lived! *(Hint - water isn't
terribly useful!) *You probably wouldn't want any quantity of burning
MIke
Mike,
I have no problem with considering Li-Ion's to be unsafe and to have
no place in a glider, but I don't understand having that opinion and
then flying with 1 to 3 of them. That was why I burned up an Ipaq
battery, to see if they are too small to cause a problem. My
conclusion is that anything from 800 mAH or larger, and probably
smaller, will make a glider uninhabitable.
But perhaps a better way of getting a handle on the risk is to look at
the incident rate, said to be about 100 cell phones fires between 2002
to 2004, out of more than 200 million cell phones are in use. This is
consistent with a fire risk of something like 1 in 4 million per year
of use for 'good' batteries and 1 in 200,000 for defective ones.
Laptop fires:
There were two recalls, the first of 9.7 million laptops after 16
fires, the other of under 6 million after 50 fires. This was for
defective units with metal particles that internally shorted out the
battery.
More info he
http://www.consumeraffairs.com/news0...#ixzz157SfeqzG
and he
http://www.buchmann.ca/article28-page1.asp
Really I am not trying to convince anyone that Li-Ions are safe, I
thought it would be helpful to have a discussion about them. The most
valuable fact for me was the existence of the 15AH lead acid unit.
Brian
Old November 12th 10, 05:33 PM posted to rec.aviation.soaring
sisu1a
The Li-Ion battery I ended up with is he
http://www.dinodirect.com/Super-9000...ion-Battery-fo...
Hope it was worth the read,
Other than price, is there a compelling reason to use Li-Ion batteries
instead of LiFeP04 batteries like these?
http://www.batteryspace.com/128vlife...terypacks.aspx I know some
folks using batteries/chargers from these guys are are quite happy
with them... many options at many pricepoints...
-Paul
Old November 12th 10, 08:52 PM posted to rec.aviation.soaring
brianDG303[_2_]
On Nov 12, 8:33*am, sisu1a wrote:
* The Li-Ion battery I ended up with is he
instead of LiFeP04 batteries like these?http://www.batteryspace.com/128vlife...rypacks.aspx*I know some
-Paul
Paul,
those look really nice.
Brian
Old November 12th 10, 10:18 PM posted to rec.aviation.soaring
Dave Nadler
On Nov 12, 12:14*am, brianDG303 wrote:
... I was
not able to ignite these by any combination of overload,
short circuit, or charging abnormality.
Clearly an amateur ;-)
Old November 12th 10, 10:28 PM posted to rec.aviation.soaring
sisu1a
... I was
I think we should pitch in and buy him this shirt:
http://lib.store.yahoo.net/lib/yhst-...ed-asphalt.gif
Note- the SunSeeker (http://solar-flight.com/sunseeker/index.html) has
a 'battery ejection' system in case of ignition of it's LIon
batteries. It's a fancy sting and pulley thing if memory serves, but
should release it's incendiary payload in a pinch -hopefully before
the rest of the plastic goes all flaming marshmellow...(look out
below!)
-Paul
ps. did you try the exacto trick? (stab deeply w/#11 blade and quickly
jump out of way of ensuing focused plasma flame
How long does it take for phosphoric acid to dry? Michael Horowitz Home Built 1 May 20th 09 12:49 AM
Broken P lead? Jim Burns Piloting 16 October 27th 06 09:06 PM
US Glider Clubs Lead IGC-OLC World League! Doug Haluza Soaring 6 July 8th 06 07:16 AM
Car (Including Lead-acid Aircraft) and Deep Cycle Battery FAQ Bill Darden Home Built 0 April 17th 06 06:26 AM
And A Little Software Program Shall Lead Them...... :-) John Clonts Instrument Flight Rules 12 July 15th 03 11:06 PM
