XF-103 Thunderwarrior
Old February 13th 04, 04:05 PM
robert arndt
Default XF-103 Thunderwarrior
Check out one of the F-102's competitors. This aircraft is truly "out
there" when compared to the technology of the time:
XF-103 Mock-Up: http://wpafb.af.mil/museum/research/fighter/f103.jpg
XF-103 Cut-Away: http://www.testpilot.ru/usa/republic...ges/xf103v.gif
XF-103 Colors: http://www.alpha-net.ne.jp/users2/ku...st103color.jpg
XF-103 Model: http://www.collectaire.com/modelpages/xf103/xf103.html
The modeling page is all color with all views. Truly ahead of its
time, but only ranked 8th out of 9 design proposals that led to the
F-102.
Rob
Old February 13th 04, 10:07 PM
Dave Kearton
"robert arndt" wrote in message
om...
| XF-103 Cut-Away:
| XF-103 Colors:
| F-102.
| Rob
Would certainly keep the runways clean.
Cheers
Dave Kearton
Old February 14th 04, 05:53 PM
robert arndt
"Dave Kearton" wrote in message ...
om...
Correct link to Mock-up:
XF-103 Mock-Up: http://wpafb.af.mil/museum/research/fighter/f103-1.jpg
Rob
Old February 14th 04, 10:44 PM
PosterBoy
om...
message ...
om...
Rob
Nope. Wrong, again.
It's:
http://www.wpafb.af.mil/museum/resea...ghter/f103.htm
(Or, if you like it short and sweet, it is:
http://tinyurl.com/25ktk .
Cheers.
Old February 15th 04, 04:26 AM
Paul F Austin
"B2431" wrote in message
Date: 2/14/2004 10:53 AM Central
message ...
om...
XF-103 Mock-Up:
Rob
Try http://www.wpafb.af.mil/museum/resea...ghter/f103.htm
Thanks.
Looking at it, the aircraft would likely have had the same sort of
performance shortfall that the F102 prototype had because of lack of area
ruling. During that period, transonic aerodynamics were very poorly
understood and engine development failed a lot. The J-67 was one of those
failures IIRC.
Old February 15th 04, 05:08 AM
Brett
message ...
om...
"out
XF-103 Mock-Up:
Rob
Thanks.
failures IIRC.
The XJ67 was a US license built Bristol Olympus engine and was also proposed
as an F-102 powerplant.
Versions of the Bristol Olympus powered the Vulcan, the TSR-2 and it was the
basis of the Rolls-Royce/SNECMA Olympus that developed almost 40,000 lb at
sea level installed in the Concorde.
What was supposed to give the XF-103 mach 3+ performance was the XRJ55
afterburner/ramjet.
Old February 16th 04, 07:44 PM
Scott Ferrin
On Sat, 14 Feb 2004 22:26:45 -0500, "Paul F Austin"
message ...
om...
XF-103 Mock-Up:
Rob
Thanks.
failures IIRC.
AFAIK the "coke bottle" fuselage shape is only an indicator of area
ruling. There are many high speed aircraft over the years that didn't
have a coke bottle shape to the fuselage. Area ruling takes in the
whole package, not just the fuselage.
Old February 17th 04, 12:50 AM
Paul F Austin
"Scott Ferrin" wrote in message
in
message ...
om...
"out
XF-103 Mock-Up:
Rob
Thanks.
failures IIRC.
Yep but doing an eyeball-analysis of the F103 picture makes it look like the
cross section graph would have multiple humps and jumps starting at the
inlet with a ramp starting at the begining of the wing root, a sharp drop at
the aft extent of the wing, then another ramp with bumps for the tail..
"Coke-bottling" was the first-generation effort and applying the area rule
but the people designing the F102 and F103 certainly weren't beyond that
first generation.
