You might find this interesting...
http://www.youtube.com/watch?v=1Od9s_VEXS8 I am the pilot, 150 hp Warrior, temp is 7 deg C. Fuel is at tabs, 70 lbs in baggage, I am alone (160 lbs) Camera is 600 ft down the rny.. Mattisons mods (seals and VG's) and his takeoff technique... Good luck with your search! Cheers! Dave On Thu, 10 Mar 2011 20:18:18 +0000, MBDiagMan wrote: 'Dave[_1_ Wrote: ;765111']OKaaaaaaaaaaaaaaay..... Check out the Cherokees... Parts cheaper than Cessnas, and slipping with full flaps (no restrictions) will bring it down like a cinder block safely. Find one with Art Mattisons gap seals and VG's and the short runway would be no issue.. (or add them later... easy.....) We have these mods on our Warrior, and the low speed, takeoff/landing performance is stunning.... ![]() Plus, two more seats and FAR more comfortable (and suitable) for cross country flights.. Late 60's and early 70's 140's with a mid time engine/ light panels should be on $$$ reach.. Good Luck! Dave On Thu, 10 Mar 2011 12:19:42 +0000, MBDiagMan wrote: - Bug Dout;765065 Wrote: - MBDiagMan writes: - I am currently looking at a C140A with 100HP and a climb prop.- Excellent. That should do the job on takeoff and climb out. I forget, does that have flaps? Is some small amount of flaps recommended for soft-field takeoff? Check its ability to slip (for landing), as well as any restrictions on slipping with flaps. -- What is either a picture or a novel that is not character? - Henry James- Thanks Bug, that is some great information to have and good questions about the plane. I do know that the C120's had no flaps while the C140 and C140A did. I have read that the 140 flaps are only marginally effective and the 140A flaps are only slightly more effective than that. Investigating it's slipping capabilities is something I had not thought about, so thanks for pointing this out. I will also investigate flap usage for soft field take off. I will be able to go fly it next week if we get the weather for it. Thanks again,- Thanks very much for the reply Dave! I have always been a fan of the Cherokee, but several folks elsewhere have said that it wouldn't be a good choice for my proposed field. They might have said that before I realized the field will be closer to 1,300 feet than my originally estimated 1,100 feet. That said, the forward slip is fine for getting in, but I don't think that getting in will be a problem. Getting out over those trees will be the problem. If there's an economy nose wheel, four place plane that can do it, I'm all ears. Thanks again for all the comments. |
Dave,
Thanks very much for the link to your Youtube! It was very impressive. My question now is.... would the same modifications do the same thing for a Hershey Bar Cherokee? Thanks again, Doc Last edited by MBDiagMan : April 6th 11 at 01:05 PM. |
| Thread Tools | |
| Display Modes | |
| Historic Bombers B-25 Mitchell Bomber Taking off from Grass Field.jpg (1/1) | J.F. | Aviation Photos | 0 | October 26th 07 02:17 AM |
| A warm evening, a grass strip, and thou.... | Jay Honeck | Piloting | 29 | August 28th 07 12:14 AM |
| Looking for cheap power 4 short strip. | On-Condition | Home Built | 7 | September 11th 05 09:18 AM |
| What is a "short field" for a PA28-181 | Roy Page | Owning | 79 | November 24th 04 01:11 PM |
| Now THIS is a short field landing | John Harlow | Piloting | 8 | March 16th 04 11:42 PM |
