Hi all,
I am about to head off overseas for a 3yr assignment. I will be leaving my LS6 in its trailer (fibreglass Komet). Are there any ideas on specific prepapration I could do to limit deterioration? I would like to give her a coat of wax before putting her away. Maybe a sheet of plastic over the hull in case the trailer leaks? Although this could trap condensation and make it worse. It's generally pretty dry here. Mouse poison? Thanks, Ben |
On Sep 25, 8:00*pm, Ben C wrote:
Hi all, I am about to head off overseas for a 3yr assignment. *I will be leaving my LS6 in its trailer (fibreglass Komet). *Are there any ideas on specific prepapration I could do to limit deterioration? *I would like to give her a coat of wax before putting her away. * Maybe a sheet of plastic over the hull in case the trailer leaks? *Although this could trap condensation and make it worse. *It's generally pretty dry here. *Mouse poison? Thanks, Ben Where are you located? I have a dehumidifier in my trailer in the winter to keep the corrosion down. 9B |
The glider is in the Hunter Valley in Australia, a few hours north of Sydney. We have had a few wet winters but generally a short period of heavy rain followed by dry spells and not a lot of humidity. Temps -2 - 20 deg C in winter, 15 - 40 deg C in summer.
Regards, Ben |
For three years, it might be worth taking your glider with you! This
may not apply to Antarctica, Iraq, or a few other places. Since you used the term fibreglass, perhaps it's not registered Experimental, so easy to register elsewhere. If you must leave your glider behind, coat the lift pins, spar pins, L'Hotelliers, etc with a rust inhibitor like LPS-3 or Boeshield. I've had decent luck using a modified "mole chaser" to keep out rodents. Remove the device from it's original housing, mount it in a project box with a voltage regulator on the incoming power. Use a 12V glider battery and a solar panel to keep the thing running. Leave it somewhere in the trailer that will resonate nicely. Waxing is good. Don't forget the trailer. Or you could lease it to the fellow a few threads ago... Jim |
On 9-26-2011 03:00, Ben C wrote:
Hi all, I am about to head off overseas for a 3yr assignment. I will be leaving my LS6 in its trailer (fibreglass Komet). Are there any ideas on specific prepapration I could do to limit deterioration? I would like to give her a coat of wax before putting her away. Maybe a sheet of plastic over the hull in case the trailer leaks? Although this could trap condensation and make it worse. It's generally pretty dry here. Mouse poison? Thanks, Ben Yes, I would think rodents would be one of the primary concerns. They crap and pee on everything and that stuff is very corrosive. If you have any wiring, they will surely chew off all of the insulation. Seat cushions would be the next in line. Would you have anyone that could periodically put out more poison? They will finish the stuff off long before the three years has passed. Poison is probably not a "cure all" anyways. The damn things will go and bury themselves in the deepest recesses of the ship and die. I think it would be far better to find a trusted pilot friend to keep the ship active for the three years... |
Some suggestions for glider storage.
Find and seal the cracks and holes in your trailer. At night, put a bright light bulb inside your trailer. Close lids and doors. Roll underneath and mark anywhere you see light coming through the trailer. Seal everything, even the smallest openings. This also helps keep road dust out of your trailer. Remove the edible cushions and any accessible wiring if possible. Don't leave any food crumbs or liquids in the cockpit -- ever! Decon pellets is a brand of mouse poison found in the USA. After they eat the little green pellets, mice get dehydrated and hopefully go outside to find water and do not die inside your trailer. An undisturbed box of Decon is a indication you do not have mice. Scattered Decon pellets will indicate mice. Store the trailer inside a building if you can. Might be worth the extra expense. In Texas, mice may attract snakes, so we try our best to sabotage the food chain! So far, no snakes inside . . . but we know they are out there. Burt Marfa Gliders Soaring Center, west Texas USA |
Three years is a long time to keep the glider idle in a trailer. You
should consider leasing it so that it gets aired out and exercised. If you do decide to park it, don't put a plastic cover over the trailer. I know someone who did that for 6 months and when the glider came out of "storage" it was covered in mold. Now two years later you can still see stains in the gel coat where the mold grew. |
| Thread Tools | |
| Display Modes | |
| F-15s Preparing | Canuck[_3_] | Aviation Photos | 0 | December 17th 08 03:41 AM |
| hx 4700 storage | John Galloway[_1_] | Soaring | 3 | May 16th 07 08:11 PM |
| preparing for commercial oral and practical | gatt | Piloting | 42 | May 16th 07 01:56 PM |
| Preparing for a XC : Bathroom Breaks | TF | Piloting | 98 | February 7th 07 08:19 AM |
| 103 Storage | BTIZ | Soaring | 3 | November 18th 03 01:47 AM |
