On 10/4/2011 5:44 AM, JJ Sinclair wrote:
After 30 years in the repair business, I found the only way to insure the mylar didn't lift was to sand both the inside of the mylar and the corresponding wing (stab, fin) with 220 dry, then wipe both surfaces with acetone just before applying double back sticky. Keep the DBS straight as an arrow and then follow it in order to keep the Mylas straight without any kinks. Sand only the 10mm area where the DBS will go. If you get a kink, make a cut to remove it and press on. I believe a good mylar job is all that in needed (internal seals not necessary). I've always used Mylar that already had the transfer tape on it. It saves me a lot effort and time, and I've never had the adhesive come off the Mylar. I prepared the carbon on my ASH 26 E by cleaning off the old adhesive COMPLETELY, even scraping with a flat Xacto blade or single edge razor, then sanding gently with a block and 320 grit as JJ describes until only fresh carbon shows, then cleaning the residue off with acetone. I apply the Mylar under a very slight tension. When it's all on, I rub over the adhesive portion with a firm piece of balsa, rag, thumb, as needed , then follow that with a hard roller, paying particular attention to "white" places. That's probably easier to do when the wing surface is carbon instead of gel coat. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Oct 4, 5:24*pm, Eric Greenwell wrote:
On 10/4/2011 5:44 AM, JJ Sinclair wrote: After 30 years in the repair business, I found the only way to insure the mylar didn't lift was to sand both the inside of the mylar and the corresponding wing (stab, fin) with 220 dry, then wipe both surfaces with acetone just before applying double back sticky. Keep the DBS straight as an arrow and then follow it in order to keep the Mylas straight without any kinks. Sand only the 10mm area where the DBS will go. If you get a kink, make a cut to remove it and press on. I believe a good mylar job is all that in needed (internal seals not necessary). I've always used Mylar that already had the transfer tape on it. It saves me a lot effort and time, and I've never had the adhesive come off the Mylar. I prepared the carbon on my ASH 26 E by cleaning off the old adhesive COMPLETELY, even scraping with a flat Xacto blade or single edge razor, then sanding gently with a block and 320 grit as JJ describes until only fresh carbon shows, then cleaning the residue off with acetone. I apply the Mylar under a very slight tension. When it's all on, I rub over the adhesive portion with a firm piece of balsa, rag, thumb, as needed , then follow that with a hard roller, paying particular attention to "white" places. That's probably easier to do when the wing surface is carbon instead of gel coat. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) Forgot one thing, I make sure the mylar is secured to the DBS and to the surface by rolling it very hard with a roller that I made from a 30mm X 10mm bearing mounted on a 12" rod. I press down real hard as I roll everything twice. I usually buff and wax the ship every other year (wax every year), then replace the safety tape which is showing some age (wax after replacing the safety tape). BTW, I believe the pilot of Ventus that had tape lift on its elevator, had waxed the surface, then applied the safety tape..........good point to remember! Cheers, JJ |
Go to Lee Valley Hardware and buy the plastic Razor blades. You can
use these to remove the tape gunk and not damage the gelcoat or Mylar while scraping. http://www.leevalley.com/US/wood/pag...56,43407,53612 Dave www.foxonecorp.com |
| Knots 2U gap seals | JAMES VOYTEK | Owning | 15 | February 5th 07 06:12 PM |
| Gel headset seals | Brian Burger | Piloting | 2 | September 26th 04 01:00 AM |
| ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 04:45 PM |
| mylar seals | D.A.L | Soaring | 1 | February 23rd 04 08:15 PM |
| New ear seals | Chris | Owning | 7 | December 16th 03 02:02 AM |
