#21
At 14:00 22 March 2012, Tobias Bieniek wrote:
From what I've understood so far, there is one important difference between= SoarTronic and the K6BT, which is baudrate switching. The K6BT has a proto= col to let the connected software change the baudrate of the adapter and I = haven't seen any other devices yet, that are able to do that. XCSoar has re= cently implemented that protocol which makes it easy to change the baudrate= for IGC file downloads for example. The Flarm does not need this feature s= ince it doesn't have to change the baudrate, but my DX50 (similar to LX5000= ) sends GPS data at 4800 yet the transfer mode for upload/download works at= 19200. Turbo Hi Turbo You are right, as usual. Changing the baud-rate is possible using AT commands when the module is not paired, but cannot be done over BT connection. Setting up environment for these settings in not easy, otherwise we would have asked people to do their own settings. We will program these to operate on 19200b speed, since I suppose that faster speed does not really give any advantages, other than downloading logger files. This is tailored for use with our club gliders with LX RedBox FLARM units and external displays, but it works nicely with any other FLARM unit as well, as long as they use the standard RJ45/12 cabling. I have added into youtube videos or testing of the Bluetooth module and IOIO extension board for radio disturbances. Results were good, and tomorrow we will place the order for PCBs and components. If someone wants one, it's final call. http://www.youtube.com/watch?v=8JfWRzj7SNk http://www.youtube.com/watch?v=_OaMyLbV7xU http://www.youtube.com/watch?v=2KmiUaDPVro |
On Thursday, March 22, 2012 1:19:25 PM UTC-4, Kimmo Hytoenen wrote:
Setting up environment for these settings in not easy, otherwise we would have asked people to do their own settings. I'm having that problem, too, with a similar if not the same BT module that takes TTL level UART data. Can't change the baud rate without setting up a level converter. We will program these to operate on 19200b speed, since I suppose that faster speed does not really give any advantages, other than downloading logger files. Intelligent varios can be configured to supply NMEA data at different rates.. 19200 should be sufficient. That said, without baud rate switching (as Tobias pointed out), you'll run into trouble when connecting this device to something older like the Volkslogger (4800bps normally, but a higher speed for bulk up/downloading). Because the device on the RS232 side is dumb, and the device on the BT end is smart, I'm not sure how one can make this work with the hardware you have. |
On Thu, 22 Mar 2012 10:19:25 -0700, Kimmo Hytoenen
wrote: At 14:00 22 March 2012, Tobias Bieniek wrote: From what I've understood so far, there is one important difference between= SoarTronic and the K6BT, which is baudrate switching. The K6BT has a proto= col to let the connected software change the baudrate of the adapter and I = haven't seen any other devices yet, that are able to do that. XCSoar has re= cently implemented that protocol which makes it easy to change the baudrate= for IGC file downloads for example. The Flarm does not need this feature s= ince it doesn't have to change the baudrate, but my DX50 (similar to LX5000= ) sends GPS data at 4800 yet the transfer mode for upload/download works at= 19200. Turbo Hi Turbo You are right, as usual. Changing the baud-rate is possible using AT commands when the module is not paired, but cannot be done over BT connection. Setting up environment for these settings in not easy, otherwise we would have asked people to do their own settings. We will program these to operate on 19200b speed, since I suppose that faster speed does not really give any advantages, other than downloading logger files. This is tailored for use with our club gliders with LX RedBox FLARM units and external displays, but it works nicely with any other FLARM unit as well, as long as they use the standard RJ45/12 cabling. I have added into youtube videos or testing of the Bluetooth module and IOIO extension board for radio disturbances. Results were good, and tomorrow we will place the order for PCBs and components. If someone wants one, it's final call. http://www.youtube.com/watch?v=8JfWRzj7SNk http://www.youtube.com/watch?v=_OaMyLbV7xU http://www.youtube.com/watch?v=2KmiUaDPVro Kimo, It sounds like a great device. How much does it cost? Sorry if it's already been posted, I've missed it somehow. My personal email is Thanks, Craig Funston 7Q -- Using Opera's revolutionary email client: http://www.opera.com/mail/ |
At 21:30 22 March 2012, David Reitter wrote:
On Thursday, March 22, 2012 1:19:25 PM UTC-4, Kimmo Hytoenen wrote: Setting up environment for these=20 settings in not easy, otherwise we would have asked people to=20 do their own settings. I'm having that problem, too, with a similar if not the same BT module that= takes TTL level UART data. Can't change the baud rate without setting up = a level converter. We will program these to operate on=20 19200b speed, since I suppose that faster speed does not really=20 give any advantages, other than downloading logger files. Intelligent varios can be configured to supply NMEA data at different rates= .. 19200 should be sufficient.=20 That said, without baud rate switching (as Tobias pointed out), you'll run = into trouble when connecting this device to something older like the Volksl= ogger (4800bps normally, but a higher speed for bulk up/downloading). Beca= use the device on the RS232 side is dumb, and the device on the BT end is s= mart, I'm not sure how one can make this work with the hardware you have. David, SoarTronic Bluetooth module is optimized for use with FLARM. Important part of it is the use of IGC standard RJ45 connectors, and possibility to connect Bluetooth and external display in parallel - no need for switches for declaration and file download. If you want to change the RS232 baudrate of SoarTronic Bluetooth module, it is possible using AT commands. However it cannot be done over Bluetooth, you must connect it to a computer, and use terminal program. For Volkslogger, GPS-NAV, and many variometers you can use similar Bluetooth modules but with Sub-D9 connector. It should be possible to also draw 5 volts from the serial port of these devices. You can get one of these Bluetooth modules from HongKong under 20 EUR, delivered. |
At 22:38 22 March 2012, Craig Funston wrote:
On Thu, 22 Mar 2012 10:19:25 -0700, Kimmo Hytoenen wrote: At 14:00 22 March 2012, Tobias Bieniek wrote: From what I've understood so far, there is one important difference between= SoarTronic and the K6BT, which is baudrate switching. The K6BT has a proto= col to let the connected software change the baudrate of the adapter and I = haven't seen any other devices yet, that are able to do that. XCSoar has re= cently implemented that protocol which makes it easy to change the baudrate= for IGC file downloads for example. The Flarm does not need this feature s= ince it doesn't have to change the baudrate, but my DX50 (similar to LX5000= ) sends GPS data at 4800 yet the transfer mode for upload/download works at= 19200. Turbo Hi Turbo You are right, as usual. Changing the baud-rate is possible using AT commands when the module is not paired, but cannot be done over BT connection. Setting up environment for these settings in not easy, otherwise we would have asked people to do their own settings. We will program these to operate on 19200b speed, since I suppose that faster speed does not really give any advantages, other than downloading logger files. This is tailored for use with our club gliders with LX RedBox FLARM units and external displays, but it works nicely with any other FLARM unit as well, as long as they use the standard RJ45/12 cabling. I have added into youtube videos or testing of the Bluetooth module and IOIO extension board for radio disturbances. Results were good, and tomorrow we will place the order for PCBs and components. If someone wants one, it's final call. http://www.youtube.com/watch?v=8JfWRzj7SNk http://www.youtube.com/watch?v=_OaMyLbV7xU http://www.youtube.com/watch?v=2KmiUaDPVro Kimo, It sounds like a great device. How much does it cost? Sorry if it's already been posted, I've missed it somehow. My personal email is Thanks, Craig Funston 7Q SoarTronic Bluetooth costs 30 EUR + posting from Finland, and we are just placing PCB and component orders after successful EMI tests. |
On Thursday, March 22, 2012 4:01:35 PM UTC-7, Kimmo Hytoenen wrote:
At 22:38 22 March 2012, Craig Funston wrote: On Thu, 22 Mar 2012 10:19:25 -0700, Kimmo Hytoenen wrote: At 14:00 22 March 2012, Tobias Bieniek wrote: From what I've understood so far, there is one important difference between= SoarTronic and the K6BT, which is baudrate switching. The K6BT has a proto= col to let the connected software change the baudrate of the adapter and I = haven't seen any other devices yet, that are able to do that. XCSoar has re= cently implemented that protocol which makes it easy to change the baudrate= for IGC file downloads for example. The Flarm does not need this feature s= ince it doesn't have to change the baudrate, but my DX50 (similar to LX5000= ) sends GPS data at 4800 yet the transfer mode for upload/download works at= 19200. Turbo Hi Turbo You are right, as usual. Changing the baud-rate is possible using AT commands when the module is not paired, but cannot be done over BT connection. Setting up environment for these settings in not easy, otherwise we would have asked people to do their own settings. We will program these to operate on 19200b speed, since I suppose that faster speed does not really give any advantages, other than downloading logger files. This is tailored for use with our club gliders with LX RedBox FLARM units and external displays, but it works nicely with any other FLARM unit as well, as long as they use the standard RJ45/12 cabling. I have added into youtube videos or testing of the Bluetooth module and IOIO extension board for radio disturbances. Results were good, and tomorrow we will place the order for PCBs and components. If someone wants one, it's final call. http://www.youtube.com/watch?v=8JfWRzj7SNk http://www.youtube.com/watch?v=_OaMyLbV7xU http://www.youtube.com/watch?v=2KmiUaDPVro Kimo, It sounds like a great device. How much does it cost? Sorry if it's already been posted, I've missed it somehow. My personal email is Thanks, Craig Funston 7Q SoarTronic Bluetooth costs 30 EUR + posting from Finland, and we are just placing PCB and component orders after successful EMI tests. I would expect that a modern device like Powerflarm will already come with a builtin bluetooth. Go figure. I am interested in one unit. Ramy Yanetz (TG) |
Please add one more to your order list.
Thanks, Craig Funston 7Q |
| Thread Tools | |
| Display Modes | |
| Power FLARM portable reports? | Andy[_1_] | Soaring | 2 | December 9th 11 04:58 PM |
| Red Box FLARM update question | Martin Gregorie[_5_] | Soaring | 1 | June 11th 11 11:13 PM |
| P-63 (?) Airacobra/Kingcobra power question | Ricky | Piloting | 75 | November 27th 09 01:35 AM |
| Engine power question??? | [email protected] | Home Built | 24 | October 13th 07 03:40 AM |
| Ship's Power (or portable GPS) Question | Kyle Boatright | Home Built | 9 | May 29th 07 04:17 PM |
