BD5B
Old November 16th 03, 02:53 AM
Dan Thomas
Ron Wanttaja wrote in message . ..
] Any body ever see a BD5 flying cross country?
] Anybody ever see a BD5 fly?
Actually, other than at fly-ins, I actually see very few of ANY homebuilts
other than the ones based at my home field. I don't think I've ever been
at an airport when a Lancair dropped in, nor a Wheeler, nor a Venture, nor
a Rotorway Exec, nor a Rans, nor a Pietenpol, or dozens of other common
homebuilts. Maybe I just don't get out much. :-)
But when you think about it, about one in ten small aircraft you see should
be a homebuilt. Doesn't seem that way. Probably because of all those 152s
and 172s with students flying 'round and 'round.
I think most homebuilts end up sitting in some hangar because the
builder spent way too much time and money on it, and now his family
(and all the other things that went uncared-for) won't let him spend
any more.
Some builders are thoroughly fed up with the project by the time
it's done, and others don't trust their workmanship enough to fly
much.
Some used poorly designed auto conversions that just drove them
nuts or dollared them to death.
In 30 years of being around homebuilts and homebuilders, I've
seen all of these. The guy interested in building an airplane would be
wise to anticipate and deal with them. Most of us are tempted to bite
off way too much.
Dan
Old November 14th 03, 06:16 PM
Curious Question
RobertR237 wrote:
Why not just let it die?
why don't you do the world a favour and take your own advice.
Old November 15th 03, 12:39 AM
RobertR237
In article , Curious Question
writes:
I had DUMB ****! I wasn't the one who brought it up. Now try doing the same!
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
RobertR237
In article , Big John
writes:
Bob
I got put in my place so that's it for me. Juan may have me 'plonked'
????????? so no reply to my postings G.
Big John
Hell John, I really don't give a hoot one way or the other. I got burned once,
learned a valuable lesson and moved on. The only reason I ever get involved in
the BD5 discussion it to remind people to look at the records before getting
involved with anything regarding the BD5 or BEDE.
Bob Reed
Old November 15th 03, 02:41 AM
Del Rawlins
On 14 Nov 2003 12:57 PM, Big John posted the following:
Bob
Juan wouldn't use a killfile, since it would deny him the opportunity to
have the last word.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old November 14th 03, 05:32 PM
Big John
Corky
A bit of BD5 trivia.
When Jim first built the bird and during the test phase (which
continued after he had started selling kits) they experienced a number
of engine failures with the German/Austrian (forget the name) engine.
Basic problem, as I remember, was that when throttle was put in idle
for long period in landing pattern, there was not enough oil going
through the engine to keep it from freezing up. As bird made pattern
the prop would keep engine RPM up and with only the oil from idle
throttle bad happened. In a snowmobile application (which engine came
out of) this never happened because engine was not spun up like it was
with the prop..
Was going back to Iowa to visit family and stopped by and spoke with
Jim about this. Suggested that he use an engine that had oil injection
vs the mixed fuel/oil normally used in a two cycle. Would have solved
his problem.
The only problem was that he had a contract (with a low price) with
the engine manufacturer that he couldn't get out of and they didn't
want to or couldn't make (without making major redesign $$$$$) changes
to the engine (or something like that) so history came to pass.
If the original engine had worked and Jim had delivered with all the
kits sold, would have been a lot more built (and possibly deaths as
you say, hot bird, high stall speed, even with the 'B' wing, etc.)
Thought seriously about building one (ex Fighter Pilot) but then all
the problems came up and decided against (I'm dumb but not stupid and
know when to cut my losses).
Big John
On Fri, 14 Nov 2003 13:57:03 GMT,
(Corky Scott) wrote:
On Thu, 13 Nov 2003 23:23:22 -0600, Big John
No one has posted a follow up with the name of the BD5 pilot, and
details of the accident (1000 ft short on final). You don't see many
BD5 accidents but there are not a lot flying so statically the
accident rate is probably pretty high vs other homebuilts with a lot
completed and flying?
Man those BD5's just don't seem like a good idea. Tiny, high stall
speed, tight engine compartment, and the pilot sits right on the
bottom of the fuselage.
The airplane has been discussed in this group previously and my
recollection is that it has a very high fatal accident rate. It's
first flight accident rate is also very high. Perhaps Ron Wanttaja
can step in with his always meticulous statistical analysis.
Corky Scott
