On Jan 1, 1:24*pm, wrote:
wrote: http://nextbigfuture.com/2009/12/sup...enable-electri... -- Mark Practical, manufacturable high temperature superconductors would enable a whole bunch of neat things and would be as spectacular as a cure for the common cold, lasting peace in the Middle East, and controlled fusion, and is just as likely to happen in the near future. I recently read up on some work being done with graphene supercapacitors. I IRC, it was at Caltech. What was interesting is how they performed at lower temperatures (e.g. room temp.). Also, charging times were impressive. Still in the realm of research, so it wasn't clear to me how well it would scale beyond smaller applications (consumer electronics, for example. |
On Jan 1, 1:24Â*pm, wrote: wrote: http://nextbigfuture.com/2009/12/sup...enable-electri... -- Mark Practical, manufacturable high temperature superconductors would enable a whole bunch of neat things and would be as spectacular as a cure for the common cold, lasting peace in the Middle East, and controlled fusion, and is just as likely to happen in the near future. I recently read up on some work being done with graphene supercapacitors. I IRC, it was at Caltech. What was interesting is how they performed at lower temperatures (e.g. room temp.). Also, charging times were impressive. Still in the realm of research, so it wasn't clear to me how well it would scale beyond smaller applications (consumer electronics, for example. Supercapacitors are great for things like keeping your clock from flashing on every minor power failure, but not that great for real power application. The basic physics of capacitors says the energy density can never be as good as existing batteries. Graphene makes them better but it will take yet to be invented materials to match batteries. Capacitors are also a poor choice for running something like a motor because of their discharge curve. While a battery's discharge curve is basically flat until it gets close to full discharge, then takes a big dive, a capacitor discharge curve is a straight line between fully charged and zero. Motors operate over a narrow voltage range. Electric motor speed control is done by pulsing the motor voltage on and off, not by varying a constant voltage. Now it is possible to build a thing that will take in a lower voltage and output some constant higher voltage to keep a motor happy. The problem with that is it is more complexity subject to failure, not good with airplanes, and it would require big, heavy, high current transformers, which ups the weight a good bit. My wild assed guess is that if electric airplanes ever become practical without Star Trek technology, it will likely be through a fuel cell that is yet to be invented. |
a wrote:
There was a contest recently where one had to demonstrate more than 200 passenger miles per gallon equivalent, and an engineering team from Penn State won it with a battery powered airplane. See http://live.psu.edu/story/55543 for details. It is just a big motor glider. |
Electric jets where are You? | nrepeb | General Aviation | 5 | March 13th 11 08:56 PM |
FS: Electric tow | Bug Dout | General Aviation | 0 | October 16th 10 06:27 PM |
6CH Electric RC Helicopter for $169 | GTY | Rotorcraft | 0 | October 27th 05 08:59 PM |
Electric RC Helicopter for $83 | NYPT Man | Home Built | 0 | October 24th 05 06:47 PM |
Electric DG | Robbie S. | Owning | 0 | March 19th 05 03:20 AM |
