Wingrunner Checklist
Old March 5th 13, 10:07 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Wingrunner Checklist
On Tue, 05 Mar 2013 07:34:11 -0800, John Carlyle wrote:
John, that's not always true. My LS8 spoilers will stay open by
themselves, even without me in the cockpit. I agree with the rest of
what you say.
Its not limited to just single seaters either: the spoilers will stay
open on a parked Puchacz.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 5th 13, 10:21 PM posted to rec.aviation.soaring
Tony[_5_]
of course the buck stops with the pilot but the wingrunner, towpilot and any knowledgable bystanders are all part of the safety net. an american cheese model of safety does not work, we have swiss cheese. case in point, Sean Fidler (F2) who does like to drive us all crazy in the winter, managed to save a couple pilots lives at Uvalde as they nearly took off with the cover on their horizontal stabilizer. the wing runner didn't notice, the two presumably experienced pilots didn't notice, and their presumably well trained crew missed it. sometimes you need a lot of layers of swiss chees before all the holes were filled.
http://www.youtube.com/watch?v=nuTBQIb721g
Old March 6th 13, 04:18 PM
Squeaky Squeaky is offline
Member
First recorded activity by AviationBanter: May 2011
Agree,
But even more so, most of us operate from clubs, and we want the club to remain strong and in operation, and part of that is ensuring the club is a professional, safe and dependable operation. This helps with insurance costs directly and costs of club aircraft or facilities, but also helps with perception of the operations at the club, perceptions or feelings people have about the culture of the club, and lastly it's important to the sport itself to entice new piltos, keep the FAA at bay, and to ensure someone else has our six.
This includes wing runners going over the major things that can cause an emergency in one of the phases of flight where soaring pilots have them the most: Take-offs. Canopies and spoilers locked, dollies and covers removed, pattern is deconflicted for takeoffs and landings.
While no one doubts the PIC is ultimately responsible for this, having the wing runner check these things is not an onerous task, and I as Duty officer say it out loud and ask my ADO's to do the same, as a last safety and sanity check. Our club is even starting to consider having the duty crew ask private ships is they accomplished a critical assembly and/or positive control check as a last chance reminder as well. It's not intrusive, and it's not out of bounds--it's just a help which takes no time and could save an incident or accident.
I hope no one is against prevention.
Cheers
Squeak
Old March 6th 13, 09:59 PM posted to rec.aviation.soaring
Clay[_4_]
But if you know someone else is going to run through a checklist, doesn't that make it slightly less likely you will run through yours? What if the wingrunner interrupts you while you're running thru your own checklist? Hey, I'm not against prevention and am not gonna fall on my sword over this, but I just wonder if we're not engineering a subtle shift in psychology here.. I could be totally wrong.
Old March 6th 13, 10:20 PM posted to rec.aviation.soaring
shift in psychology here. I could be totally wrong.
We encourage our launch marshals and their assistants to ask "Brakes
locked?" if the pilot didn't say "Brakes locked immediately asking for
"Cable on". IMO, if you're going to use such a procedure, thats the place
to do so, NOT earlier when the pilot is still running through his
checklist, thinking about eventualities, etc.
org |
Old March 7th 13, 02:54 PM
Member
Quote:
I don't and I do not see that from most club members.
Overall, it's a matter of timing and not interupting Pilots in their routines. As Pilots stage their aircraft is when they are asked about Critical assembly and Positive control checks. When pilots are ready, and hooked up, as I walk to the wing and get ready to lift it, I look over their aircraft and the pattern. At Thumbs Up, I look and say loud enough for the pilot to hear: "Dolly's removed, Canopy and Spoilers locked, Pattern clear." At which point I signal to take up slack. Adds maybe 5 second to the process...
Checklist a[_3_] Piloting 1 May 26th 11 11:19 PM
Checklist Larry D. Cosby Piloting 148 March 29th 08 05:10 AM
Checklist use Private Piloting 2 February 12th 08 09:25 PM
747-100 Checklist Bartscher General Aviation 0 December 18th 04 08:20 PM
C-180 100 hr checklist ConchyJoe Owning 1 May 4th 04 12:53 AM
