Why not jam the switch down or, for the more adventurous, solder a jumper
across it? "JohnDeRosa" wrote in message ... One comment based on a IPaq model 2215 so may not relate to your 4700. The battery cover of the 2215 must be in place for the unit to power up. The difference between "in place" and "not in place" could be used for microscopic scientific measurements. I had the cover come loose (ever so slightly) in flight and the unit powered off, which was a lot of fun (not). Took me a while to figure out what was going on. There is a small tab on the battery cover that pushes a switch telling the unit life is good. Of course this tab often breaks. Of course a replacement cover is difficult and expensive to come by. Fix = gaffers tape on the cover. I never understood what they were trying to protect me from. I suppose the lithium battery but sheez. Am I bitter? Nah. I switched to an Oudie! YMMV. - John |
On May 2, 7:25*pm, "Dan Marotta" wrote:
Why not jam the switch down or, for the more adventurous, solder a jumper across it? Well I am adventurous! I opened the patient and (as I remember it) the tiny switch was surface mount rather than through hole and had multiple contacts. I removed the switch and soldered across where it seemed appropriate. Worked for a while. Luckily I owned several for backups. Jamming something to hold the switch closed was problematic due to the layout. You had to be there. I think that the HP engineers were playing hard to get. - John |
FS: Ipaq 4700 + Winpilot Pro | Ramy | Soaring | 0 | January 21st 12 05:25 AM |
Instruments and iPaq 4700 for sale, USA | Chris | Soaring | 1 | November 3rd 09 01:34 PM |
Winpilot pro and Ipaq 4700 locking up. | joesimmers | Soaring | 5 | July 17th 08 05:42 AM |
IPAQ 4700/4705 | Doug LS4 | Soaring | 9 | January 31st 06 01:01 PM |
New iPAQ 4700 | Paul Remde | Soaring | 2 | October 9th 04 11:06 PM |
