On 05/16/2013 10:52 AM, Dan Daly wrote:
I use this panel pass-through, and it works well: "NEUTRIK - USB A/B Pass Thru Black D-Type". I have a usb stick with a flashing LED to indicate it is accessing. I would be nice if there were a menu item, perhaps below the one where you set it to download IGC files, where you could end recording and then download IGC files to the USB stick without cycling power. I have to turn off everything, then boot my 7007 (provides power to the Core) in order to get the IGC file out. I am happy that I can transfer declarations from my Dell Streak/XC Soar via IOIO to the Core - very handy. There is an IGC flight download menu item in the new display firmware, it seems to work fine. Luke |
Op donderdag 16 mei 2013 16:52:43 UTC+2 schreef Dan Daly:
I use this panel pass-through, and it works well: "NEUTRIK - USB A/B Pass Thru Black D-Type". I have a usb stick with a flashing LED to indicate it is accessing. I would be nice if there were a menu item, perhaps below the one where you set it to download IGC files, where you could end recording and then download IGC files to the USB stick without cycling power. I have to turn off everything, then boot my 7007 (provides power to the Core) in order to get the IGC file out. I am happy that I can transfer declarations from my Dell Streak/XC Soar via IOIO to the Core - very handy. Hi Dan, Did you buy your IOIO adapter, or did you make this yourself? Thanks, Joop |
| PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 26th 12 12:58 AM |
| PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported | Paul Remde | Soaring | 24 | January 22nd 12 02:50 AM |
| New ILEC SN-10 Firmware | Paul Remde | Soaring | 5 | August 25th 05 09:11 PM |
| v3.20 Firmware now out for Garmin 296 {nt} | Cockpit Colin | Piloting | 0 | March 8th 05 02:12 AM |
| Garmin 196 firmware update v3.1 released | Aloft | Piloting | 0 | August 13th 03 01:50 AM |
