"Tex Houston" wrote in message ...
"Kevin Brooks" wrote in message ... "robert arndt" wrote in message om... http://www.fprado.com/armorsite/leo2.htm Forecast International's and Jane's Best Tank in the World... three years running. Rob ![]() Let me know the next time that either source gains some actual combat experience with those parade-ground-wonder-weapons, OK? Till then, preaching its unsurmounted superiority is a bit premature... Brooks What is this fascination (obsession?) with tanks in a newsgroup labeled rec.aviation.military? Two words: airlift logistics. Tex |
On Sun, 2 May 2004 10:13:24 -0600, "Tex Houston" wrote:
"Kevin Brooks" wrote in message ... "robert arndt" wrote in message om... http://www.fprado.com/armorsite/leo2.htm Forecast International's and Jane's Best Tank in the World... three years running. Rob ![]() Let me know the next time that either source gains some actual combat experience with those parade-ground-wonder-weapons, OK? Till then, preaching its unsurmounted superiority is a bit premature... Brooks What is this fascination (obsession?) with tanks in a newsgroup labeled rec.aviation.military? Tex It is our little nazi Rob ranting about aryan (read German) superiority in all fields, with the rest of the world just tagging along. Al Minyard |
![]() "B2431" wrote in message ... From: "CKOMOPOX" Yes, that's what Hitler thought. "How could ve lose? My vonderful Tigers, my Panthers, all gone! Vat happened?" Well...transmission problems aside, The Tiger was superior. The tank teuton was referring to was the King Tiger which was a piece of junk over all. The armour was good and the main gun was excellent. They were difficult to steer, the engines were unreliable and under powered and the beasts simply weighed too much. I put them in the category of flops along with Ferdinand. There just wasn't enough of them. German tanks had a gun sighting system far superior to anything the T-34 had. They also had radios. The main flaw with both Panther and Tiger 1 was they were built like fine watches. When they worked right in proper numbers they were almost unstoppable, Unfortunately the broke down too often and too many times had to be left behind because the Germans never got the hang of tank recovery. The real problem was that they were too damm complicated and couldnt be delivered in the numbers needed Germany managed to build around 4800 Panthers, 9000 Mk IV's, 6000 Mk III's, 1300 Tigers and 500 King Tigers The USA built 48,000 Shermans, the USSR built 40,000 T-34 and 2,200 JS-2, the UK built 28,000 tanks including Churchill's Cromwell's ,Matilda II's and Valentines Being outnumbered 10-1 is not good. Keith |
"Keith" == Keith Willshaw writes:
"B2431" wrote in message ... The main flaw with both Panther and Tiger 1 was they were built like fine watches. When they worked right in proper numbers they were almost unstoppable, Unfortunately the broke down too often and too many times had to be left behind because the Germans never got the hang of tank recovery. Keith The real problem was that they were too damm complicated Keith and couldnt be delivered in the numbers needed Keith Germany managed to build around 4800 Panthers, 9000 Mk Keith IV's, 6000 Mk III's, 1300 Tigers and 500 King Tigers Keith The USA built 48,000 Shermans, the USSR built 40,000 T-34 Keith and 2,200 JS-2, the UK built 28,000 tanks including Keith Churchill's Cromwell's ,Matilda II's and Valentines For defensive battles, the Jagdpanther and Jagdtiger were better, as well as Sturmgeschutz III and IV. The Germans built a great many of those too, although I don't have the figures handy (my head leaks). I wonder if these suffered from the same problems, or whether they were simplified and more reliable... -- G Hassenpflug * IJN & JMSDF equipment/history fan |
![]() "Gernot Hassenpflug" wrote in message ... "Keith" == Keith Willshaw writes: "B2431" wrote in message ... The main flaw with both Panther and Tiger 1 was they were built like fine watches. When they worked right in proper numbers they were almost unstoppable, Unfortunately the broke down too often and too many times had to be left behind because the Germans never got the hang of tank recovery. Keith The real problem was that they were too damm complicated Keith and couldnt be delivered in the numbers needed Keith Germany managed to build around 4800 Panthers, 9000 Mk Keith IV's, 6000 Mk III's, 1300 Tigers and 500 King Tigers Keith The USA built 48,000 Shermans, the USSR built 40,000 T-34 Keith and 2,200 JS-2, the UK built 28,000 tanks including Keith Churchill's Cromwell's ,Matilda II's and Valentines For defensive battles, the Jagdpanther and Jagdtiger were better, as well as Sturmgeschutz III and IV. The Germans built a great many of those too, although I don't have the figures handy (my head leaks). I wonder if these suffered from the same problems, or whether they were simplified and more reliable... The Sturmgeschutz III was based on the same chassis as the PkW III and used its production facilities after the tamk went out of production. Around 8000 of the Aus G models were built They were simpler and cheaper than the Panthers and Togers. In fact you could buy 4 for the price of 1 King Tiger. Keith |
(B2431) wrote in message ...
From: "CKOMOPOX" Yes, that's what Hitler thought. "How could ve lose? My vonderful Tigers, my Panthers, all gone! Vat happened?" Well...transmission problems aside, The Tiger was superior. The tank teuton was referring to was the King Tiger which was a piece of junk over all. The armour was good and the main gun was excellent. They were difficult to steer, the engines were unreliable and under powered and the beasts simply weighed too much. I put them in the category of flops along with Ferdinand. Hitler had tankers who could hit first time and at long range and work team minded. He needed adequate gun, good reliability, re-claimable without a tug-boat, easy to make, lots of them. The 'too many Ivans' problem in the east had to be fixed by using strengths against etc. He needed something better than the IIIs and the IVs, it had to be standard, easy to churn out, reliable, and arrive in time. It was almost as easy to make a U-Boat as to fashion one big complex lump of German precision engineeering on tracks. A simplified panther with jpanzer derivatives possibly. He needed to also Ford-T a Hetzer type vehicle. The Hetzer was almost there but not quite, armour is irrelevent, if one can hit first and the Germans could usually do that. The thick armour only came into play because of the 'too many Ivans' equation, which would diminish if there was more shooting back. |
