On Sat, 22 Nov 2003 09:01:09 -0000, "karel adams"
wrote: :dear all, : :what is the blue foam around which composite parts are built? :is it polyurethane? what brand names does it carry in europe? It is absolutely NOT polyurethane. Polyurethane will release cyanide gas if you try to hot wire it. DON'T. It is Polystyrene foam, trade name Styrofoam by Dow chemical. The form usually used in homebuilding is PI (Pipe Insulation) Billets, or FB (Fabrication Billet) or BB (Bouyancy Billets), made by Dow. The BB is a little ligher and weaker than the PI or FB, which are the same thing. The PI's come in 8x16x104 inch blocks, or, lately, 10x20x104. Don't use white EPB (Expanded Polystyrene Bead) board, often sold for insulation, or used to make molded foam things like cheap ice chests. You can recognise it because if you break it, it looks like it's made from thousands of tiny round beads fused together. That's exactly what it is. It's chemically the same, and you can hot wire it, but it's not nearly as strong in flex or tension. Here are a couple of halfway decent primmers on hotwiring http://www.info-central.org/construction_hotwire.shtml http://www.spacemodeling.org/new/how_to/Foam_Cutter.htm Note - you don't have to use nichrome wire. I've used .020 stainless safety wire, and titanium MIG wire with good results. |
Thank you! That was as extensive an answer as one could wish for!
I have found the local importer for Dow and sent them e-mail... Karel Hingene (BE) I don't know what the situation is like in your country, but here in the USA we don't tell the Dow rep that we are going to use the foam for airplanes. If we do they won't sell it to us. I build lots of boat docks and boats G |
"karel adams" wrote in message ...
dear all, what is the blue foam around which composite parts are built? is it polyurethane? what brand names does it carry in europe? also, where can i find a description of how to build an electrically heated cutting wire for the same? Aircraft Spruce sells a book discussing 'Moldess Composite Construction'. This book was written by Burt Rutan. They also sell a 'kit' comprised of foam, various fiberglass weaves, and epoxy. I used this to build a few test wings and learned a lot in the process. (Including a deep hatred for sanding). Going from memory... The cutter used in the book is a long strip of 2"x2" with a 1/2" copper pipe snug fit into 1/2" holes in either end of the 2"x2". A small hole is drilled through the ends of the copper pipe, the cutting wire is fed through the holes, and looped a few times around each pipe. Tension is applied to the cutting wire by rotating the copper pipes (a bit like tensioning a guitar string). I used a car battery and lightweight jumper cables (from a battery charger) as the current source. Fasten one of the jumper cables to the copper pipe on the cutting tool. A variable resistance needs to be added in the path to control current and hence the heat in the cutting element. For this, I used another 3 foot section of 2"x2" (attached to the workbench) with a wire strung between two nails at either end. Connect the other jumper cable to one end of the wire. Connect a heavy-duty alligator clip to other copper pipe on the cutting tool through a length of wire. Attaching the alligator clip to resistance wire completes the circuit and allows current to flow. This will cause the both the cutting wire and the resistance wire to heat. Current can be adjusted by moving the alligator clip in various locations along the wire. It is a bit of an art to select the right current for cutting. Too hot and the foam will melt away, leaving divots and shriveled foam in the cut. Too cold and the wire will not cut well - which will stretch the wire and leave a cut that is not even. Having said this - you can probably purchase a better assembly (Aircraft Spruce?) than you can build. Or borrow one - talk to your local EAA chapter - if anyone has built an EZ - then they should have a foam cutter. -Nathan |
| Thread Tools | |
| Display Modes | |
| Foam | BD5ER | Home Built | 17 | September 20th 03 05:07 PM |
| blue foam, pink foam, yellow foam? | Corrie | Home Built | 26 | September 1st 03 06:01 PM |
