My 302 recorded today's flight with a date of 4/9/1995. The flight log generated by the Oudie had the same date. See You interpreted the CAI file's date as 4/9/2031.
Very glad there's a fix and thanks, Paul, for spreading the word. |
I just talked with Gary about sending in my 302 which is exhibiting 3
separate issues. He quoted me from their webpage that they have moved to a fixed price schedule for repairs. $350 should repair all faults. I think that's a lot less expensive than redoing my panel with newer technology and, besides, I really like my 302. On 11/21/2014 12:51 PM, Paul Remde wrote: Cambridge 302 and GPS-NAV owners – IMPORTANT NEWS Unfortunately, there has been a rash of Cambridge Model 10/20/25 and 302/302A with a fault in which the units lose track of the date and do not record a flight log, or record a flight log with an incorrect date. The problem is related to the internal Garmin GPS engine’s UTC date. This is a new issue, but there have already been many reported instances – especially from areas in which there are soaring flights this time of year. It is very likely that many 302 and GPS-NAV owners that have their gliders put away for the winter will, unfortunately, have the same issue during their first flight in the spring. If you have the optional LCD display connected to your 302 or GPS-NAV flight recorder, you may be able to tell whether or not your unit is affected. Connect the GPS-NAV Model 20/25 to a GPS-NAV LCD Navigation Display, or connect the 302 to a 303 LCD Navigation display and give the unit time to lock onto satellites before continuing. The GPS-NAV’s LED will blink when it is locked onto satellites. The 302 will show 3 bars on the right side of the screen when it has a good lock on satellites. Then scroll to the UTC date/time screen. If your unit is working properly you will see the current date. If your units is not working properly you will find an erroneous date – such as 2005. In that case, the unit will need repair. If your GPS-NAV or 302 does not have the optional LCD Navigation display, then the best way to determine whether your units is affected is to take a flight (or drive) and look at the date of the flight log that is generated. Make sure the unit has a good lock on satellites before takeoff. If the flight log’s date is off, or no flight log is generated, then the unit will need repair. The bad news is that the units will need to be sent in for repair. It is not possible to repair the unit in the field. This issue affects the GPS engine which is inside the logger, not the external GPS antenna. The great news is that Gary Kammerer at ClearNav can fix them. The Garmin receiver has a 3v rechargeable battery under its cover. The issue is not related to the 3v logger security button battery. Gary can remove the Garmin’s cover, replace the 3v rechargeable battery that is soldered to the Garmin circuit board put the unit back together and then send a couple of commands to the GPS which wake the Garmin back to reality. The new battery keeps it working properly after the repair procedure. Without the replacement battery the Garmin's memory cannot be kept "alive". Gary has performed this fix to dozens of 302 and GPS-NAV units he has received from all over. They have all been successfully repaired. CNI Service Policy For Cambridge Equipment-- http://www.clearnav.net/main/cn-service.html Gary’s contact information: Gary Kammerer ClearNav Instruments 779 Rosedale Rd Kennett Square, PA 19348 USA Phone: 610-388-0456 Email: Please include a note explaining the reason you are sending the unit to Gary, and also include your contact information. Gary and I hope this information will allow you to resolve this issue with your 302 or GPS-NAV before your next big soaring flight. Best Regards, Paul Remde Cumulus Soaring, Inc. -- --- Dan Marotta |
I didn't say $350 to change a battery and, since the full text from the
website was posted by Brian, I won't repeat that. My 302 is suffering from multiple problems, namely, the on/off switch is faulty, I'm getting the wrong date in log files, and it's completely losing GPS lock resulting in multiple log files being generated on a single flight. So I think the price is probably reasonable considering the cost of a replacement. On 11/24/2014 11:50 AM, Dan Marotta wrote: I just talked with Gary about sending in my 302 which is exhibiting 3 separate issues. He quoted me from their webpage that they have moved to a fixed price schedule for repairs. $350 should repair all faults. I think that's a lot less expensive than redoing my panel with newer technology and, besides, I really like my 302. On 11/21/2014 12:51 PM, Paul Remde wrote: Cambridge 302 and GPS-NAV owners – IMPORTANT NEWS Unfortunately, there has been a rash of Cambridge Model 10/20/25 and 302/302A with a fault in which the units lose track of the date and do not record a flight log, or record a flight log with an incorrect date. The problem is related to the internal Garmin GPS engine’s UTC date. This is a new issue, but there have already been many reported instances – especially from areas in which there are soaring flights this time of year. It is very likely that many 302 and GPS-NAV owners that have their gliders put away for the winter will, unfortunately, have the same issue during their first flight in the spring. If you have the optional LCD display connected to your 302 or GPS-NAV flight recorder, you may be able to tell whether or not your unit is affected. Connect the GPS-NAV Model 20/25 to a GPS-NAV LCD Navigation Display, or connect the 302 to a 303 LCD Navigation display and give the unit time to lock onto satellites before continuing. The GPS-NAV’s LED will blink when it is locked onto satellites. The 302 will show 3 bars on the right side of the screen when it has a good lock on satellites. Then scroll to the UTC date/time screen. If your unit is working properly you will see the current date. If your units is not working properly you will find an erroneous date – such as 2005. In that case, the unit will need repair. If your GPS-NAV or 302 does not have the optional LCD Navigation display, then the best way to determine whether your units is affected is to take a flight (or drive) and look at the date of the flight log that is generated. Make sure the unit has a good lock on satellites before takeoff. If the flight log’s date is off, or no flight log is generated, then the unit will need repair. The bad news is that the units will need to be sent in for repair. It is not possible to repair the unit in the field. This issue affects the GPS engine which is inside the logger, not the external GPS antenna. The great news is that Gary Kammerer at ClearNav can fix them. The Garmin receiver has a 3v rechargeable battery under its cover. The issue is not related to the 3v logger security button battery. Gary can remove the Garmin’s cover, replace the 3v rechargeable battery that is soldered to the Garmin circuit board put the unit back together and then send a couple of commands to the GPS which wake the Garmin back to reality. The new battery keeps it working properly after the repair procedure. Without the replacement battery the Garmin's memory cannot be kept "alive". Gary has performed this fix to dozens of 302 and GPS-NAV units he has received from all over. They have all been successfully repaired. CNI Service Policy For Cambridge Equipment-- http://www.clearnav.net/main/cn-service.html Gary’s contact information: Gary Kammerer ClearNav Instruments 779 Rosedale Rd Kennett Square, PA 19348 USA Phone: 610-388-0456 Email: Please include a note explaining the reason you are sending the unit to Gary, and also include your contact information. Gary and I hope this information will allow you to resolve this issue with your 302 or GPS-NAV before your next big soaring flight. Best Regards, Paul Remde Cumulus Soaring, Inc. -- --- Dan Marotta |
Well, poo. Checked 10 of them last night, and only 4 came up with the correct date. Several of those that failed to do so were used extensively this summer. Wonder if I can get a "group discount" rate? :-)
2 more to check and see if I can get back up to 50% Steve Leonard |
Install them with air lock or Dzus fasteners and swap the one good one
into the ship that you're flying today! On 11/25/2014 8:13 AM, Steve Leonard wrote: Well, poo. Checked 10 of them last night, and only 4 came up with the correct date. Several of those that failed to do so were used extensively this summer. Wonder if I can get a "group discount" rate? :-) 2 more to check and see if I can get back up to 50% Steve Leonard -- --- Dan Marotta |
Hi Steve,
Make sure they are locked onto satellites before checking the date. But you probably already know that. Best Regards, Paul Remde _____________________ "Steve Leonard" wrote in message ... Well, poo. Checked 10 of them last night, and only 4 came up with the correct date. Several of those that failed to do so were used extensively this summer. Wonder if I can get a "group discount" rate? :-) 2 more to check and see if I can get back up to 50% Steve Leonard |
On Tuesday, November 25, 2014 12:19:02 PM UTC-6, Paul Remde wrote:
Hi Steve, Make sure they are locked onto satellites before checking the date. But you probably already know that. Best Regards, Paul Remde _____________________ Yep. Some took a while. Others were pretty quick. Of course, before sending off, they will get a second chance to take the test. Will wait for more than just 3 showing and distance to waypoint shown. That is where some were last night when checked. Others got 8 satellites pretty quickly. Steve |
For anyone keeping score ..
I powered up my (3) GPS/NAV Model 20's .. All said UTC 04/12/95. Curt - 95 |
Hi Curt,
Please make sure they have a lock on satellites before checking the date. The green light blinks when the unit has a lock on satellites. Best Regards, Paul Remde Cumulus Soaring, Inc. _______________________ "CLewis95" wrote in message ... For anyone keeping score .. I powered up my (3) GPS/NAV Model 20's .. All said UTC 04/12/95. Curt - 95 |
Correction on my group. Test 10, 7 failed.
For those keeping score, failed serial numbers from my group (Model 20 unless otherwise stated): C0H5 C1SJ (Model 25) C1ER 0418 (Model 25) 0205 C0ZN C0DD Good: C0GZ 0327 0440 Have two more I might be able to check today. |
ClearNav CNv Vario Owners - Important News | Paul Remde | Soaring | 0 | February 20th 14 11:25 PM |
Big News from Cambridge and ClearNav | Paul Remde | Soaring | 4 | January 30th 14 10:49 PM |
Important News from the USA # 711 reporting. | [email protected] | Soaring | 5 | May 16th 05 05:02 PM |
Great news for Cambridge GPS-NAV owners! | Paul Remde | Soaring | 1 | September 11th 04 02:07 AM |
Important news For all webmaster,newsmaster | Bruce A. Frank | Home Built | 0 | November 1st 03 01:16 AM |
