Orval Fairbairn wrote:
In article , (Dan Thomas) wrote: (Veeduber) wrote in message ... One of the easiest ways to cut sheet 4130 is with a band saw. Use an old metal cutting blade installed upside down (the teeth pointing up). Run the saw at normal speed and feed in the material. Keep the pressure up and it will go (melt) through like you are cutting butter. Don't pause though, it is not so easy to get started again. Some have also used the back side of the blade for this purpose with success. O-ring Seals --------------------------------------------------- Dear O-ring (and the Group), I believe you'll find there's a bit more to it than that :-) First off, the 'normal speed' you're referring to is for a woodworking bandsaw. The down-side is that most woodworking bandsaws are fitted with a rubber 'tire' on their driver- & idler-wheels. Friction cutting steel (which is what you're doing) will destroy the tire on the driver-wheel in short order. Bandsaw tires are moderately expensive and can be hellishly difficult to replace on some saws. Metal-cutting bandsaws do not use tires. The wheels are sizes so that the teeth overhang the edge of the wheel, not only for cooling but for clearing the swarf. You can set-up a metal cutting bandsaw for friction cutting if you have the proper ratio pulleys (ie, increase the blade speed). The popularity of this method hinged largely on the builder's ability to splice their own blades because the original idea was to use common steel strapping. Operated at high speed -- and cutting relatively thin stock -- the stuff does in fact cut like butter, with a very attractive displace of sparks, too :-) But the strapping was rapidly consumed and unless you were a dab hand at splicing, ideally with a Do-All type butt-welder, there was no long-term advantage over regular cutting. All of this came about due to the difficulty of cutting relatively hard steel in thinner gauges, which loves to strip the teeth off anything. .035 4130, you can do pretty well using a regular bi-metallic 32T blade by simply rigging the work to feed 'downhill' so that two teeth are in contact with the work. I used to cut 4130 using the bandsaw method, with a 1/2" bimetal blade installed the right way, and just letting the teeth round off the first time I used it. It would cut rather nicely, and didn't hurt the rubber tire. Keeping the cut straight was the biggest hassle. There's a German-made friction-cutting tool designed to cut sheet of all sorts using a steel wheel that doesn't spin but instead oscillates at a fairly high frequency in an arc of about 20 degrees or so. I saw it demonstrated on aluminum, steel and even stainless steel. Really noisy, but a really clean cut, too. No chips. When the section of the disc doing the work gets a bit dull, you loosen the screw and rotate it a bit to a sharper section. I am trying to remember the name, but can't. It was a big hit at our aircraft engineer's symposium a couple of years ago. Not cheap, but well worth the cost if you're doing much cutting. Friction welding of aluminum aircraft skin was presented there, too, though not demonstrated. Skins are butted together and a high-speed carbide bit with a flat end and one raised tit are run over the joint under pressure, the metal heats and fuses, and the alloy is not affected so strength isn't hurt at all. I don't know how. You get a flush, seamless joint with far less hassle than riveting. Also very expensive. I think Airbus is using it on the A380, maybe. Dan Dan I would think that the seam would lose a lot of its basic heat treat strength, due to the melting/recrystallization. A PDF on stir/friction welding from NASA.gov http://makeashorterlink.com/?E472217A6 ww |
It appears that my previous thank you note didn't get through. Maybe
it's a appropriate, 'cause now I get to thank everyone on Thanksgiving. The generosity of members of this list is boundless. I actually had several people volunteer to cut the sheet for me. I declined those offers because of the shipping cost and difficulty of communication (and I really do want to keep the 'I built that' element as much as possible). I have an inlaw that has access to a portable plasma torch. I'm going to get the sheet laid out and get up with him. I had actually forgotten all about this particular resource until someone here mentioned it. However, I'm still of the mind to hold back at least one piece so that I can give that friction cutting method a try. Just 'cause I LIKE to see sparks flying. Beyond that, I've had dozens of occasions to recieve excellent information from this newsgroup, both as direct responses to questions I've posed and in responses to others...even from old curmudgeons(sp?) like Barnyard Bob. Regardless of the amount of bickering and namecalling, I firmly believe that everyone here has the goal of building/help build the safest possible airplane at the least expense of time, effort, and dollars. When I come flying into Sun'n'Fun or Oskosh in a few years, you can all rest assured that you had a hand in getting me there. Thank you. (PS - If I crash and burn on test flight, then it's all on my head.) -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
I used a table saw and later a radial arm saw with abrasive cutting wheels
from the local lumberyard/hardware. Works just like cutting wood, but noisier and smellier. Be careful cover the wood table (if the saw table isn't metal) with a sheet of metal or the sparks will cause charring. I've cut up to .120 4130 this way and it works fine. I wouldn't use this method for huge projects, since the grit is messy and hard on the saw if you don't clean it well, but for the occasional part, it worked well, cutting straight lines and fairly quickly. "Ernest Christley" wrote in message . com... I've got some .035 4130 that I have to cut elevon ribs from. 2 inch on one end, 3/8ths on the other and about 16" long (each one is a different length). The small end fits against a run of tube, the thick end against the elevon spar. Both ends have to be shaped appropriately. The sides of the long runs need to be perfectly straight. I've seen a lot of options on how to cut aluminum, but the info on steel seems to be more limited. Here's where I'm at so far. A shear big and strong enough to handle the job is currently out of my budget. (though, I keep hearing that the economy is coming back around) Harbor Freight has a $35 cutting tool that can handle the job according to the advertised specs. It sorta, kinda looks like an angle grinder, except that it has a short arm and a reciprocating tooth out one side. I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet as guides, and just make a run with the cutter. Anyone have experience with these things? Do they leave a clean edge? Another option is to pay a machine shop. If I can find a good shop, I'm sure to get quality work, but I can't say that I did it and I won't have a tool afterward. I'm saving that as a last resort. Are there any better options? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
air drill question | Ded Dog | Home Built | 24 | November 24th 03 10:43 PM |
blue foam & cutting it | Richard Riley | Home Built | 6 | November 24th 03 01:53 PM |
Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 23rd 03 11:08 PM |
steel 4130 | Philippe Vessaire | Home Built | 4 | October 19th 03 07:19 AM |
Sheet metal shear/press brake | VideoFlyer | Home Built | 7 | October 7th 03 07:08 PM |
