What could cause extremely high effort to release a Tost CG hook on aTwin Astir?
Old June 1st 15, 03:18 AM posted to rec.aviation.soaring
Bill D
Default What could cause extremely high effort to release a Tost CG hookon a Twin Astir?
On Sunday, May 31, 2015 at 8:12:52 PM UTC-6, Bill T wrote:
Hate to launch again as an "experiment " without knowing what is really going on.
You said the instructor "rear" seat release pull took what you estimate is a 200 lb pull.
Is the front seat release having a problem?
Any problems with an auto back release at top of climb?
BillT
Yes, rear seat release.
The front seat release hasn't been tested in flight.
The "back-release" function seems to work well at the top of the launch.
Old June 1st 15, 03:25 PM posted to rec.aviation.soaring
Bob Kuykendall
I'd suggest anchoring the glider, and using a come-along to tension a rope on the hook to some modest value, say ~150 lbs, and actuate the release. That will at least give you an idea of the relationship between tow rope force and actuation force. It will also show you if anything is distorting under tow force.
Old June 1st 15, 03:33 PM posted to rec.aviation.soaring
Bill D
We're thinking along those lines too. However, to check a CG hook at the rope angles normally experienced, the pull angle has to be something line 45 degrees down from horizontal. That's going to be complicated.
Old June 1st 15, 04:24 PM posted to rec.aviation.soaring
I'd suggest anchoring the glider, and using a come-along to tension a rope on the hook to some modest value, say ~150 lbs, and actuate the release.. That will at least give you an idea of the relationship between tow rope force and actuation force. It will also show you if anything is distorting under tow force.
Lay the fuselage on its side??
Old June 1st 15, 04:26 PM posted to rec.aviation.soaring
Dan Marotta
Perhaps a pulley mounted to a 2 x 12 of sufficient length that the
glider sits on the board to hold it down. Position the glider on the
board to get the desired angle and put a couple of people in the
cockpit. Use a spring scale and come along to set the desired tension.
snip
Dan Marotta
Old June 1st 15, 04:45 PM posted to rec.aviation.soaring
Papa3[_2_]
glider sits on the board to hold it down.** Position the glider on
the board to get the desired angle and put a couple of people in the
cockpit.* Use a spring scale and come along to set the desired
tension.
snip
Dan Marotta
Yup. Was involved in a similar exercise many years ago when John Campbell was investigating critical angles on Schweitzer releases. If the glider is assembled, you can get a group of folks together and lift it onto some tall saw horses supporting the wings near the root. Use big pads to avoid crushing the skin. Even better would be to take the wings off and support using the lift pin hardpoints. If you do this over a solid tie down (airport tiedown ring), you'll only need a small pulley and you can move the fuselage forward or backwards to get the required angles.
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
TOST Release Failure - Two Uncommanded Release's [email protected] Soaring 11 October 13th 12 10:23 AM
needed!! drawings/data for Tost hook for Pawnee thing73 Soaring 3 November 13th 09 02:14 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
