(alfred montestruc) wrote in message . com...
(Jack Linthicum) wrote in message . com... (alfred montestruc) wrote in message . com... "Charles Talleyrand" wrote in message ... Lets suppose you get to give a single new airplane design and a single prototype to a participant of World War One. You can offer the Austro-Hungarians the design for a B-52 if you wish. However, that might prove a manufacturing challenge to them (and one can only wonder about their supply of jet fuel). Your goal is to change history. You can hope for a German victory or just that the Allies win faster. It's up to you. So, what design do you offer, remembering that this design must be manufactured, fueled, and armed by the natives? Probably a Japanese Zero. The Zero could land and take off on a relitivly short grass runway as long as the ground is not soft. The engine should be within their capacity to build, and that is the main thing, a late 1930's evolved internal combustion aircraft engine with lots of power. The airframe had lots of wood and nothing very sophisticated in terms of metal parts. The 20mm cannons would make it's firepower something to be feared. A Zero would be a terror of the sky in 1918, it can outrun and out climb everything else. A small number with fuel and ammunition can rout the other side's airforce and do nasty things in ground attack, and recon especially given their speed and range. -snip problem: that aluminum wing spar What problem? German Navy Zepplins of WWI used aluminum for frames. http://www.richthofen.com/dark_autumn/ ---quote As the war progressed, the German Navy and Army each built their own mutually exclusive airship fleets. The Navy zeppelins however, were usually of aluminum Zeppelin Company manufacture, whereas the Army often used the wooden Shutte-Lanz or "SL" ships rejected by the Navy due to their excessive weight. ---end quote True, little thin pieces of aluminum, not a full depth wing spar, which required a special new aluminum developed by Sumitomo. In later years the few Zeros still extant had this spart crystalize and fail. "It was the first aircraft credited with using wing spars that provide high strength, but were constructed of light weight aluminum. " http://www.pacificwrecks.com/reviews/roaring_a6m5.html |
(alfred montestruc) wrote in message . com... (Jack Linthicum) wrote in message . com... (alfred montestruc) wrote in message . com... "Charles Talleyrand" wrote in message ... Lets suppose you get to give a single new airplane design and a single prototype to a participant of World War One. You can offer the Austro-Hungarians the design for a B-52 if you wish. However, that might prove a manufacturing challenge to them (and one can only wonder about their supply of jet fuel). Your goal is to change history. You can hope for a German victory or just that the Allies win faster. It's up to you. So, what design do you offer, remembering that this design must be manufactured, fueled, and armed by the natives? Probably a Japanese Zero. The Zero could land and take off on a relitivly short grass runway as long as the ground is not soft. The engine should be within their capacity to build, and that is the main thing, a late 1930's evolved internal combustion aircraft engine with lots of power. The airframe had lots of wood and nothing very sophisticated in terms of metal parts. The 20mm cannons would make it's firepower something to be feared. A Zero would be a terror of the sky in 1918, it can outrun and out climb everything else. A small number with fuel and ammunition can rout the other side's airforce and do nasty things in ground attack, and recon especially given their speed and range. -snip problem: that aluminum wing spar What problem? German Navy Zepplins of WWI used aluminum for frames. http://www.richthofen.com/dark_autumn/ ---quote As the war progressed, the German Navy and Army each built their own mutually exclusive airship fleets. The Navy zeppelins however, were usually of aluminum Zeppelin Company manufacture, whereas the Army often used the wooden Shutte-Lanz or "SL" ships rejected by the Navy due to their excessive weight. ---end quote True, little thin pieces of aluminum, not a full depth wing spar, Sure they could. Aluminum extrusion was invented before 1905. http://www.tms.org/pubs/journals/JOM/0102/fig2.gif that timeline GIF file is from this website. http://www.tms.org/pubs/journals/JOM...ders-0102.html which required a special new aluminum developed by Sumitomo. In later years the few Zeros still extant had this spart crystalize and fail. "It was the first aircraft credited with using wing spars that provide high strength, but were constructed of light weight aluminum. " http://www.pacificwrecks.com/reviews/roaring_a6m5.html I think others have shown that statement to be in error. |
| Thread Tools | |
| Display Modes | |
| FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | August 23rd 04 06:18 AM |
| Ever heard of Nearly-New Airplanes, Inc.? | The Rainmaker | Aviation Marketplace | 1 | June 23rd 04 06:08 PM |
| SMALLL airplanes.. | BllFs6 | Home Built | 12 | May 8th 04 01:48 PM |
| FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 06:57 AM |
| Sport Pilot Airplanes - Homebuilt? | Rich S. | Home Built | 8 | August 11th 03 12:41 AM |
