#21
On Wed, 23 Jun 2004 17:27:32 +0100, Robert Briggs
wrote: Ed Rasimus wrote: Higher speeds mean the store can generate lift (just like any curved surface.) IIRC, "curved" is unnecessary here. After all, they do say that, given enough thrust, a brick will fly, do they not? Actually, no. Lift is balanced by weight, while thrust opposes drag. The brick (AKA F-4) would not really "fly", but simply be propelled in the desired direction. It is the tendency for airflow to accelerate over a curved surface creating a low pressure area that causes "lift". The dropped store had better be curved if you want to get lift, since it isn't supplied with thrust. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
"Ed Rasimus" wrote in message ... On Tue, 22 Jun 2004 22:46:32 -0400, "Kevin Brooks" wrote: The A3D was not the only member of that family that experienced such a problem. Knew a guy who flew B-66's (and later EB-66's) who told me that it was unnerving to do a bomb drop from the Destroyer because it sometimes had a habit of having bombs "bounce" around in the bomb bay after release before actually leaving the aircraft (which may explain why its career as a bomber was rather short). Brooks Early prototypes of the F-105 attempted conventional rigging of the B-28-RE in the internal bomb-bay. No one anticipated the boundary layer along the fuselage at 600 knots IAS. When the bombbay opened for bomb release, shackles opened and bomb dropped a few inches but didn't come through the high speed airflow. Bombbay doors reclosed with bomb simply resting on the doors. (Shape--of course, not hot weapon!) Solution was a "displacing gear"--a roughly six-inch diameter, pneumatic piston that had about a two foot throw. Charged to a couple of thousand pounds/sq-inch, the piston was said to either push the bomb down or the airplane up. All became moot because the airplane never carried an internal nuke operationally. Displacing gear was still in place, however. The boundary layer flow was the reason for the B-66 problem as well, from what I remember of the gent's explanation. But in his case ISTR he experienced it when dropping conventional ordnance during a training evolution; I remember him distinctly mentioning "bombs" (plural) thudding around, and IIRC he indicated a little pull up on the nose was used to ensure their eventual departure. I do know he said it was not a pleasant experience! Brooks Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
Robert Briggs wrote:
Richard Brooks wrote: Paul Housley wrote: A while ago, I saw video footage of a bomb being released from a fighter-bomber under test conditions. It was on an aviation documentary. The high speed camera then shows it climb up and destroy the tailplane. I don't think they quite got their trajectory calcs right! This shows up towards the end of a documentary called Dambusters, which has been seen on UKs Channel 4. The Lanc may have had guns, but that doesn't make it a fighter-bomber. I'm sorry, I didn't give enough information. The footage of the American aircraft disintegrating, being sought was at the end of the hour-long documentary which included photos with a German officer standing beside a mine which had not exploded, interviews with one of the tower sentries, interviews with people who lived near the dams, German and American variants, etc . It's been the best documentary on the whole bouncing bomb idea Richard. |
To be 'technically' correct... a wing with camber (curved) can generate
lift at zero angle of attack. A symmetric airfoil (such as a flat brick) cannot, it must be at a positive angle of attack to generate lift (but the point is... it CAN). Both generate lift (positive C sub L) but at different AOA. At 'normal' airspeeds the coefficient of lift may not be sufficient for a brick to generate enough lift to fly, but then again if the airspeed was high enough.... Here's some reading on the subject.... "...Almost any relatively flat surface could be made to generate some lift. In fact, a perfectly flat thin plate will do the job. If you don't believe that, try out any of a number of simple little balsa-wood hand launched model gliders. Most of them have flat wing sections, and they fly. The flat plate, then, is probably the simplest of airfoil sections, as shown in Figure 5..." From the following site http://142.26.194.131/aerodynamics1/Basics/Page4.html Mark "Robert Briggs" wrote in message ... Ed Rasimus wrote: Higher speeds mean the store can generate lift (just like any curved surface.) IIRC, "curved" is unnecessary here. After all, they do say that, given enough thrust, a brick will fly, do they not? |
Ed Rasimus wrote:
Robert Briggs wrote: Ed Rasimus wrote: Higher speeds mean the store can generate lift (just like any curved surface.) IIRC, "curved" is unnecessary here. After all, they do say that, given enough thrust, a brick will fly, do they not? Actually, no. Lift is balanced by weight, while thrust opposes drag. This assumes more than I wrote. Can you say "Harrier", for example? Okay, I didn't have that aeroplane in mind, but I *was* careful not to specify any particular angle of attack - after all, an "inverted" pass at an air display is not *exactly* inverted, with the aerofoil acting against you (in the case of "ordinary" aeroplanes, at any rate). The brick (AKA F-4) would not really "fly", but simply be propelled in the desired direction. It is the tendency for airflow to accelerate over a curved surface creating a low pressure area that causes "lift". The dropped store had better be curved if you want to get lift, since it isn't supplied with thrust. I was also careful to omit any assertion about the aerodynamic stability of the brick. |
Ed Rasimus wrote: On Wed, 23 Jun 2004 17:27:32 +0100, Robert Briggs wrote: Ed Rasimus wrote: Higher speeds mean the store can generate lift (just like any curved surface.) IIRC, "curved" is unnecessary here. After all, they do say that, given enough thrust, a brick will fly, do they not? Actually, no. Lift is balanced by weight, while thrust opposes drag. The brick (AKA F-4) would not really "fly", but simply be propelled in the desired direction. It is the tendency for airflow to accelerate over a curved surface creating a low pressure area that causes "lift". The dropped store had better be curved if you want to get lift, since it isn't supplied with thrust. ....except when you're looking at something like the B-70 "waverider" technique, where the underside of the plane provides compression lift, without providing classical Bernoulli-type lift. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#28
"Paul Housley" wrote in message om... Perhaps a bit of a random question for this newsgroup. A while ago, I saw video footage of a bomb being released from a fighter-bomber under test conditions. It was on an aviation documentary. The high speed camera then shows it climb up and destroy the tailplane. I don't think they quite got their trajectory calcs right! Has anyone seen this video? Does anyone know where I could get a copy. Stills from it would be fine. It's for a uni project in case you were wondering. If not, anyone able to point me in the right direction of where to ask? Thanks for your help. Paul. We have a compilation video at work of "Store Release gone WRONG!" Makes interesting viewing before we start doing release and jettison work. Unfortunately it would be too large to email out of the office (and I don't think the security people would like it too much!) Its made up mainly of Edwards/Eglin/Pax River stuff, but a few things from RAF/RN are in it as well..... |
#29
The store (or tank) separated, floated in the slipstream for a second or two, then went straight back and cleaned off the right stab. That is what I remember as well. Wasn't a chase plane also caught up in the mishap? Are you thinking of the F/A Teen test where a Mk 82 plus the pylon detaches and wipes out the TA-4 chase plane? Some of the nastiest video I have seen - you can almost hear the Scooter pilot yelling, "What the hell did you doooooooo!!!" just as he flinches into the path of the oncoming bomb. Bonus points for the crew, staying in their flaming torch for the first 6-7 fiery tumbles, then ejecting just before the debris rains down next to the range observation boat. A++ video clip (cuz no one got kilt). v/r Gordon ====(A+C==== USN SAR Its always better to lose -an- engine, not -the- engine. |
#30
"Ian" wrote We have a compilation video at work of "Store Release gone WRONG!" Makes interesting viewing before we start doing release and jettison work. Unfortunately it would be too large to email out of the office (and I don't think the security people would like it too much!) Its made up mainly of Edwards/Eglin/Pax River stuff, but a few things from RAF/RN are in it as well..... As an ex-weapons troop, I'd *love* to see that. Pete |
| Thread Tools | |
| Display Modes | |
| A BOMB PATTER IS LIKE A FOOTBALL | ArtKramr | Military Aviation | 17 | March 3rd 04 02:54 PM |
| Air Force announces small diameter bomb contract award | Otis Willie | Military Aviation | 0 | October 9th 03 10:52 PM |
| Air Force announces winner in Small Diameter Bomb competition | Otis Willie | Military Aviation | 0 | August 30th 03 04:06 AM |
| AIRCRAFT MUNITIONS - THE COBALT BOMB | Garrison Hilliard | Military Aviation | 1 | August 29th 03 10:22 AM |
| FORMATIONS, BOMB RUNS AND RADIUS OF ACTION | ArtKramr | Military Aviation | 0 | August 10th 03 03:22 AM |
