Oudie starved for power
Old February 20th 17, 05:52 AM posted to rec.aviation.soaring
Craig Funston
Default Oudie starved for power
On Sunday, February 19, 2017 at 8:46:41 PM UTC-8, Craig Funston wrote:
On Sunday, February 19, 2017 at 10:30:05 AM UTC-8, John Ferguson wrote:
Think you need to get the V7 checked out as I've run an Oudie from both a
V7 and an S80, both varios supply enough power to charge the Oudie without
problem.
John
At 16:14 19 February 2017, Matt Herron Jr. wrote:
Help!
I run my Oudie from my V7 so that it gets all the flarm data from my
Flarm
Core. Unfortunately it tends to run out of battery power towards the end
o=
f the flight, even though the V7 is supplying juice.
I measure the current draw of the Oudie in this setup and it came in
around=
160ma. I then plugged it into the Colibri II connection I have a s a
GPS
backup, and it then drew 360ma. The red charging light also came on. I
mo=
ved it back to the V7 and the charging light went back to green and
current=
again dropped to 160ma.
Conclusion: V7 output is current limited and starving the Oudie in
flight.
Solution: so what I need is power from the Colibri II power supply, but
da=
ta from the V7. Anyone ever done this? I could make some funky splitter
ca=
ble, but I am worried about ground loops between the V7 and the Colibri
II
power supply.
Any suggestions or experience solving this problem?
Thanks,
Matt
Matt,
I had exactly the same issue. The V7 power output to the PDA is limited to 1A which is less than the power consumption of the Oudie with the screen at full bright. I made a power supply out of the stock powered Oudie data cable. Here's a link to how it was set up.
https://www.dropbox.com/s/15qwaepsnk...20v.3.pdf?dl=0
It runs directly off the ship power and provides plenty of juice to keep the Oudie topped off.
Craig
7Q
BTW I did try a cheap Chinese 12v to 5v power converter, but it was so noisy electrically it broke squelch on the radio. The Oudie power supply is much quieter and has worked flawlessly.
OUDIE [email protected] Soaring 31 November 5th 16 04:19 PM
Oudie 5.19 Bug Lauren Soaring 3 June 4th 14 07:57 PM
Power FLARM power Andy[_1_] Soaring 9 June 6th 12 01:38 AM
Oudie Steve Hunt Soaring 2 July 8th 11 01:19 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 03:44 AM
