https://en.wikipedia.org/wiki/Tupolev_Tu-142
--- http://foxtrotalpha.jalopnik.com/ins...a-s-1795375146 Interesting read about "Inside The Russian Bomber That’s Been Flying America’s Coastline"...fairly long article but worth the read if you're an aviation nut like me! It's about the TU-95 from which the 142 was developed from. The Tupolev Tu-142 (NATO reporting name: Bear F/J) is a maritime reconnaissance and anti-submarine warfare (ASW) aircraft derived from the Tu-95 turboprop strategic bomber. A specialised communications variant designated Tu-142MR was tasked with long-range communications duties with Soviet ballistic missile submarines. The Tu-142 was designed by the Tupolev design bureau, and manufactured by the Kuibyshev Aviation and Taganrog Machinery Plants from 1968 to 1994. Formerly operated by the Soviet Navy and Ukrainian Air Force, the Tu-142 currently serves with the Russian Navy. Developed in response to the American Polaris programme, the Tu-142 grew out of the need for a viable Soviet ASW platform. It succeeded the stillborn Tu-95PLO project, Tupolev's first attempt at modifying the Tu-95 for maritime use. The Tu-142 differed from the Tu-95 in having a stretched fuselage to accommodate specialised equipment for its ASW and surveillance roles, a reinforced undercarriage to support rough-field capability, improved avionics and weapons, and enhancements to general performance. The Tu-142's capability was incrementally improved while the type was in service, eventually resulting in the Tu-142MZ, the final long-range Tu-142 with highly sophisticated combat avionics and a large payload. Tupolev also converted a number of Tu-142s as avionics (Tu-142MP) and engine (Tu-142LL) testbeds. Even as the Tu-142MK entered service, its Korshun-K STS was already becoming obsolete. Work began on yet another improved Tu-142, resulting in the Tu-142MZ ("Bear F" Mod. 4) with the Korshun-KN-N STS. This consisted of Nashatyr-Nefrit (Ammonia/Jade) ASW avionics, which included the Zarechye sonar system. As well as the RGB-1A and RGB-2 buoys of the Berkut, the Tu-142MZ was compatible with the RGB-16 and RGB-26 buoys. When working with the ASW avionics, these buoys provided 50% greater coverage. The Kuznetsov NK-12MV were replaced by the more-powerful NK-12MP engines, and for the first time, the Tu-142 had an independent engine-starting capability with the addition of the TA-12 auxiliary power unit.[ This variant was distinguished from earlier "Bear Fs" by the chin fairings housing several antennas. Role Maritime patrol and anti-submarine warfare aircraft National origin Soviet Union Russia Design group Tupolev Built by Kuibyshev Aviation Plant Taganrog Machinery Plant First flight 18 July 1968 Introduction December 1972 Status Out of production, in service Primary users Soviet Navy (historical) Russian Navy Indian Naval Air Arm (historical) Ukrainian Air Force (historical) Produced 1968–1994 Number built 100 Developed from Tupolev Tu-95 Throughout its operational history, the Tu-142 demonstrated significant capabilities. On 19–22 August 1974, four Tu-142s shadowed a foreign submarine in the Barents Sea; one of the aircraft was reported to have maintained continuous contact for 2 hours and 55 minutes. In 1975, a Tu-142 managed to trail a Soviet submarine for 3 hours and 16 minutes. On 10 October 1977, a group of five Tu-142s tracked a US submarine in the Philippine Sea; one of the Tu-142s reportedly trailed the submarine for 4 hours and 5 minutes. Soviet Tu-142s, besides operating domestically, were sent to friendly overseas bases in Angola, Cuba, Ethiopia, Vietnam, and Yemen. In the early 1990s, with the dissolution of the Soviet Union, the Soviet fleet of Tu-142s was handed to the Russian Navy, although the Ukrainian Air Force gained a few Tu-142s that had been left in its territory. Ukrainian Tu-142s were later dismantled as a result of the bilateral START I treaty signed between the United States and the Soviet Union in 1991, which came into effect in late 1994. Besides the Tu-142's military applications, a one-off Tu-142MP was used to test a new ASW suite. Another Tu-142 was converted to replace the Tu-95LL for the testing of turbojet engines. Designated Tu-142LL, the ASW equipment and armament were removed to allow an engine test bed to be carried under the belly. Some of the engines installed were the NK-25 for the Tu-22MZ, RD36-51A for the Tu-144D, and the NK-32 for the Tu-160. The first Tu-142MK was converted for an airborne laboratory role, setting several altitude-in-horizontal and time-to-altitude records in its class. Specifications (Tu-142MZ) General characteristics Crew: 11–13 Length: 53.08 m (162 ft 5 in) Wingspan: 50.00 m (167 ft 8 in) Height: 12.12 m (39 ft 9 in) Wing area: 311.10 m² (3,348.76 ft²) Empty weight: 90,000 kg (198,000 lb) Max. takeoff weight: 185,000 kg (407,848 lb) Powerplant: 4 × Kuznetsov NK-12MP turboprops, 11,033 kW (14,795 shp) each Performance Maximum speed: 925 km/h (500 kt, 575 mph) Cruise speed: 711 km/h (384 kt, 442 mph) Combat radius: 6,500 km (3,454 nmi, 3,977 mi) Service ceiling: 12,000 m (39,000 ft) * |
| Thread Tools | |
| Display Modes | |
| Tupolev Tu-22M pics [20/21] - Tupolev-Tu-22M-Blackfire-3.jpg (1/1) | Miloch | Aviation Photos | 0 | August 4th 16 05:57 AM |
| Tupolev Tu-22M pics [19/21] - Tupolev-Tu-22M-Blackfire-2.jpg (1/1) | Miloch | Aviation Photos | 0 | August 4th 16 05:57 AM |
| More Tupolev Tu-95 pics [5/6] - tupolev-tu-95-and-mikoyan-mig-29.jpg (1/1) | Miloch | Aviation Photos | 0 | July 26th 16 07:52 AM |
| Tupolev Tu-95 pics [19/21] - Tupolev Tu-95 and Boeing B52.jpg (1/1) | Miloch | Aviation Photos | 0 | July 26th 16 07:48 AM |
| Tupolev Tu-22 Blinder pics [21/21] - tupolev-tu-22-L-UuNGeR.jpg (1/1) | Miloch | Aviation Photos | 0 | July 25th 16 11:59 PM |
