On Saturday, June 3, 2017 at 5:34:46 AM UTC-7, Echo wrote:
Installed my transponder this off season, passed the transponder check to make it legal. First flight with it yesterday. Called the local controlling agency to check it out. They had nothing on me, but they did once I cycled the transponder off and back on. I then realized that where the "ALT" is indicated on the lower right of the screen with the little airplane symbol was actually just 3 dashes instead. Multiple times in flight I noticed it kicked off to the dashes, and I wasn't broadcasting. It seems a reboot worked, but not for long. Running it with a premade wiring harness and L2 antenna, dual LiPo batteries. Anyone have any ideas? Jordan ASW20 The only thing in the manual that addresses this is this: Warning Messages If the transponder detects a problem, the screen will indicate WARNING and a brief statement of the problem. Depending on the nature of the problem, your transponder may not be replying to interrogations. Note the message on the screen and pass that information to your avionics maintenance organisation. Press ENT to clear the message; if the fault is still present the message will reappear. My guess is that the transponder detected an impedance mismatch with the antenna and shut down transmissions to protect itself. A mismatch could be the result of a damaged coax (there may be no external signs of damage). Let us know what Trig says. Tom |
Will do. Mid continent (the North American distributor) said check connections. No screen messages. Gonna reset all hookups and try again this weekend...then it's a call to trig.
E |
1. Where did you put your L2 antenna? I did fine putting it in the nose
after shaping a balsa piece to fit. 2. How did you route the coax? With a lifting instrument panel you have to be careful the coax does not get mangled by adjacent hardware. 3. Are the coax connectors secure to the conductors, especially outer? If it gets to the point that you might have to ship it out for diagnosis, it might help to hook up the removed components to a battery. If there's a major airport within 50 miles you should see replies to TCAS interrogations from the heavies. You don't have to be in the air to receive TCAS interrogations. But do double check the harness plugs are seated properly before doing anything else. |
Yeah the L2 is well behind the control mixing in the mid aft fuselage. It's strange to me because if it were a fault with the antenna or other, my understanding is it should throw a fault code. When it is on (like after I restart it), Nashville approach picks me up fine. I can't get a hold of trig, every time I call I get error messages, so not sure how to call over there if my provider and wifi options aren't working.
| Thread Tools | |
| Display Modes | |
| Trig TT21 Transponder ... reports? | Grider Pirate | Soaring | 105 | March 29th 18 02:10 AM |
| Trig transponder | [email protected] | Soaring | 0 | April 14th 16 04:30 AM |
| Garmin GPS 20A with Trig TT22 in Experimental Glider - OK? | Paul Remde | Soaring | 35 | December 21st 15 06:17 AM |
| Transponder TT21 versus TT22 - Considerations | WaltWX[_2_] | Soaring | 16 | January 23rd 15 07:01 PM |
| New Trig TT22 Transponder | Paul Remde | Soaring | 1 | January 14th 10 08:27 PM |
