Lubricant for spar pins
Old January 10th 18, 02:19 PM posted to rec.aviation.soaring
ND
Default Lubricant for spar pins
On Saturday, January 6, 2018 at 11:44:13 PM UTC-5, Jonathan St. Cloud wrote:
Did a search of RAS and all the threads were quite old, so I thought I would ask what lubricant do you use when assembling your glider? I have noticed that the lube that comes with Schleicher gliders seems to have more friction and lube. Of course there is the old standby of white lithium, but any new ideas?
i know a very well respected pilot with a good reputation for maintenance who uses plain old vaseline. both because it works, and because it washes out of clothes. no more grease rings on your thigh.
Old January 10th 18, 03:43 PM posted to rec.aviation.soaring
Be secure in your machismo - use a rigging apron!
Old January 10th 18, 04:29 PM posted to rec.aviation.soaring
Putting on and then removing a rigging apron takes valuable time, time that you might not be able to afford in a high-speed relight from an early off-field landing in a competition.
Wait...those aren't allowed anymore. Living in the past. How many on this group recall those "exciting" dashes back to the contest, throwing the glider together as fast as possible, and relaunching, hoping to do better the second time? The rapid assembly was sometimes made easier by taking some shortcuts in the derigging process at the landout site. We once hauled our 1-26 back without installing the spar hold down bolts on the trailer by parking someone in the back of the station wagon to to make sure the wings didn't slide off the trailer during the 10 mile drive back to the contest site. A long time ago.
Chip Bearden
LS1 F glider - question on spar pins [email protected] Soaring 2 April 29th 13 11:45 AM
Alignment tool for spar pins soartech[_2_] Soaring 5 September 6th 12 05:39 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
"Duke" will receive lubricant funds during prison stay! Vox Populi Naval Aviation 1 December 11th 05 02:02 PM
Best lubricant for Mechanical Tachometer Cable??? RonLee Home Built 3 January 4th 05 12:04 AM
