HVLP Paint Sprayer Recommendations
Old March 15th 18, 01:46 PM posted to rec.aviation.soaring
Default HVLP Paint Sprayer Recommendations
On Thursday, March 15, 2018 at 12:07:29 AM UTC-4, LongJourney wrote:
On Wednesday, March 14, 2018 at 7:46:13 AM UTC-5, wrote:
On Tuesday, March 13, 2018 at 11:53:31 PM UTC-4, LongJourney wrote:
Has anyone used an HVLP sprayer to refinish a wood and fabric aircraft? If so, did you get a better finish? Did it save a significant amount of paint? Was it worth using vs. a regular paint spray gun?
Thanks,
Jeff
I have been using a turbine HVLVP system for almost 10 years to spray dope.
It saves about 20% in material and reduces over spray that land in the shop and out the window by a lot. The system I use is from TIP. Pattern is big which helps speed things up. Warm air speeds drying and that requires retarder in last coats sometimes.
This does not work as well for me with AU due to quicker drying reducing flow out. Possibly hot weather reducer would help. For that I use HVLP gun fed from compressor.
FWIW
UH
Thanks for the reply. What is TIP?
Jeff
Look up TP Tools for HVLP turbine system we have. Likely well outside your budget range.
If you are doing the Polyfiber system the gun isn't all that important. That stuff sprays pretty easily.
We have about 80 feet of copper pipe for a cooling manifold off our compressor, followed by a 6 foot drip leg to separate water, then a filter. Gets out water well enough to spray polyester which is the most sensitive to moisture.
UH
Axis Products Citation HVLP Filter Change Andy[_7_] Restoration 0 May 29th 08 07:07 PM
Recommendations for paint shops & avionics shops near NW Ohio [email protected] Owning 0 May 20th 06 01:23 PM
corrosion x sprayer paul Home Built 0 July 31st 05 08:52 PM
paint shop recommendations wanted (SE) Stephen N Mills Owning 0 January 29th 04 04:44 PM
Cleaning the sprayer Michael Horowitz Home Built 2 August 26th 03 04:12 AM
