Paul,
No sign of your posting on the OGN forum, however a couple of points occur to me, The Flarm is probably faulty if the frequency is that unstable, I have seen units where the frequency offset has been close to unacceptable, but they don’t normally change much in use, as a workaround you could ask the owner of the ground station to increase the bandwidth that they receive on, this has the downside of higher cpu load and greater noise but will pick up off- frequency units better (perhaps set the demodulator ScanMargin to around 20 or 25) But in the long term you will probably need to get the Flarm unit checked by the manufacturer as it doesn’t look right to me. Ben. (U.K. OGN station Aldersht2) At 01:17 18 August 2018, Glidingstuff wrote: Thanks for the quick reply Dan. Have you updated the FLARM to the latest firmware (6.60)? Yes. Both units are running 6.60 What kind of coax did you use to connect the antennae to the FLARM and how long are the runs? Aviation quality and about three meters Have you tried a factory reset of the FLARM? Yes. Its just back from being reset. But they admit they didn't check the freq performance. Does the towplane have a metal tint on the plexiglass windscreen? No I haven't ever seen the frequency offset move that quickly. We had a FLARM CORE in the club which went for repair and the transmit section was replaced; it could only be seen for 100m or so. Now, range like all the others (OGN ranges of greater than 40 km). A great resource is the forum for the OGN; it is at https://groups.google.com/forum/#!fo...nglidernetwork . Details on joining it are at http://wiki.glidernet.org/contact . Cheers Dan I have sent the above data to the OGN people but no reply from them as yet either. Paul |
Continental PE-150 Ground Power Unit 150HP For Sale | [email protected] | Aviation Marketplace | 1 | August 9th 20 09:45 PM |
Gloster Gladiator pics 2 [06/11] - Legionnaires_guards_gladiators landing ground at H4 pumping station in Transjordan.jpg (1/1) | Miloch | Aviation Photos | 1 | March 22nd 18 11:08 AM |
Continental PE-150 Ground Power Unit 150HP For Sale | [email protected] | Aviation Marketplace | 0 | August 29th 17 01:24 AM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
FAA Awards $1.8 BILLION ADS-B Ground Station Contract | Larry Dighera | Piloting | 27 | October 4th 07 04:07 PM |
