Harley powered airplane
Old December 11th 03, 07:32 AM
Brett
Default Harley powered airplane
I built a Zenith 601 XL with a Harley motor. It took about 7 months to
build alot of that time figuring out the motor stuff. Then 3 mo.
waiting for the inspection. Well I just got my inspection done on the
9th and I took it up. WOW what a rush. You can see it at
www.hog-air.com
Old December 11th 03, 11:42 AM
Larry Smith
"Brett" wrote in message
om...
www.hog-air.com
Nice ad. Nice movie.
Looks torquey. How much rudder on takeoff?
Also looks to be an installation where the cylinder head temps should be
monitored and maybe the cylinders should be baffled. Love them Harleys,
though. Evo runs much cooler than the shovel-head or panhead.
Old December 11th 03, 02:22 PM
ET
(Brett) wrote in news:3778c1e5.0312102332.18010aa8
@posting.google.com:
www.hog-air.com
Interesting... Aside from the belt drive, is the motor stock??? What
prop is used? Custom? At what RPM is the engine going to cruise )
It appears you plan on basically assembling Zodiac XL kits, fitting the
Harley motor to them, and selling the complete airplane.... Here, I
believe, many of us are perhaps interested in the firewall forward
package, if not just the engine and/or belt drive. What is your pricing
for those options???
I assume this will only run on 91+ octane mo-gas... do you know if 100LL
would run this baby properly? (hard to find mo-gas sometimes on cross-
countries)?
Looks really cool, and the aaahhh factor of having a Harley Plane is
hard to ignore. It will be interesting to see the long-term performance
of this baby. I'm either going to build a Zodiac XL or a Sonex...
either of which may be ideal for this type engine... I will not even
begin construction for 6 months to a year, so I will be following your
progress with interest.
ET
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Old December 11th 03, 04:03 PM
Rich S.
om...
www.hog-air.com
Hmmm........... I particularly like the caption on the picture of the
horizontal stab - "A Tail Wing".
Rich S.
Old December 11th 03, 05:22 PM
Jay
In motorcycle circles, aren't Harleys known more for their nostalga
and styling and less for their power to weight ratio?
"Larry Smith" wrote in message ...
om...
www.hog-air.com
Old December 11th 03, 10:03 PM
Bart D. Hull
Jay,
I agree with you on the style vs. power to weight, but a Harley does
have the advantage of "loosing" the transmission and just using the
engine as a direct drive. The PSRU would put the Harley into it's
power range so that ain't too bad either.
USAF used to use 2 Moto Guzzi V50 (500CC) engines on their prop
driven pusher-puller design ROV in the late 80's. I saw one up close
at a small field near the Arizona - Mexican border. Same idea, lose
the gearbox and put a GM alternator to power all the toys in the
baggage section.
Bart D. Hull
Tempe, Arizona
Check
http://www.inficad.com/~bdhull/engine.html
for my Subaru Engine Conversion
Check http://www.inficad.com/~bdhull/fuselage.html
for Tango II I'm building.
.com...
www.hog-air.com
Old December 11th 03, 11:44 PM
Bushy
No, they are known for having to have a ute (and a trailer cause there will
be more than one!) follow the ride to bring home the broken ones. Unless you
count the fancy new motordesigned in Germany they have a typical TBO of 400
hours.
Every Harley I know, is in pieces more often than it is riden.
Hope this helps,
Peter
Old December 12th 03, 11:39 AM
RR Urban
Oh, they're known for their power to weight ratio - it's lower than
just about any other bike (with the exception of my bicycle of
course).
Mark Hickey
In the case of aircraft applications...
this is a GOOD THING towards reliability.
Barnyard BOb - .5 hp/cid
Old December 12th 03, 02:10 PM
Jimmy Galvin
QUESTION:
Why doesn't Harley Davidson make televisions?
ANSWER:
They can't figure out how to make them leak oil.
"Mark Hickey" wrote in message
course).
Mark Hickey
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
