Buying LS3a or ASW20a? ~$25k cross country glider. Which one and why?
Old April 1st 19, 03:30 PM posted to rec.aviation.soaring
Default Buying LS3a or ASW20a? ~$25k cross country glider. Which one and why?
Agree, you should also consider the S-H Ventus.
The LS-3 is a dream to fly; controls are very harmonic and it is comfortable. It lacks accommodating panel space and it does not "run" as well or land as short as the ASW-2O. That being said, the 20 is more pitch sensitive and will not tolerate poor approach piloting. The 20's thinner airfoil requires more attention and stall respect.
The LS support is iffy and concerning (no offense Cumulus Soaring). Here in the US, you'll have more experience and support with a Schleicher product. The Mayes family @ Williams Soaring, CA are the Schleicher US reps and are very experienced.
Which one? IMO, deciding factors should be damage history, finish condition, instrumentation, and trailer condition.
Having many XC hours in both, my preference is the ASW-20 and especially the 20C. The 20C is worth the extra money.
On Sunday, March 31, 2019 at 11:04:06 PM UTC-4, Michael N. wrote:
I'm looking for a glider for cross country in the $25k range.
Old April 1st 19, 03:50 PM posted to rec.aviation.soaring
SoaringXCellence
Unless you're also planning on competing, or trying for records, you should widen your selection. The performance difference is very small between most of the second generation glass ships. Looking at the Johnson reports shows 1-2 points difference, but all of them measured better than 37:1 which is plenty for great XC soaring.
I have flown an H301 Libelle, Pegasus, ASW-20, and currently own a Mini Nimbus C.
The flapped ships are fun and the Peg is very easy to fly. I love the Mini for the landing flaps (which some people don't). Lots of panel space and easy to rig (nothing is as easy as the Libelle. Automatic hook-ups and a very comfortable cockpit (about the same as the Ventus).
Mike B.
Old April 1st 19, 04:20 PM posted to rec.aviation.soaring
Michael N.
Thanks, I guess at this point I am looking for "best bang for the buck" in the current marketplace. Including finish and instruments and trailer.
I really cannot go much higher than $25k so I am looking for a complete package (good finish, trialer, instrumentation package) for cross country.
I do want a flapped ship, as again I have lots of hours in complex aircraft, and I want the ability to get into short fields on landing out if I have too.
I am reconsidering now the Ventus B, also the DG202, as well as the previously mentioned LS3 or LS3a, and ASW20 (a,b, or c)
In my price range I do see an ASW20a and a Ventus B (maybe) without winglets. So I am also trying to see if winglets are still available for the 20 or Ventus.
Thanks for the feedback, please keep it coming.
Mike
Old April 1st 19, 05:27 PM posted to rec.aviation.soaring
JS[_5_]
Mike
Mosquito should be another candidate.
You may find that for $25k you'll end up with something other than those two choices. But if you insist, the LS could be the best of the two for that price.
If you want "ready to fly", perhaps look at the overall condition of the glider and trailer before performance. That would include paperwork.
Old April 1st 19, 08:26 PM posted to rec.aviation.soaring
With 200 hours I would stay away from the Ventus w/o winglets unless your instructor says you have plenty of extra bandwidth available while flying and your thermalling skills are already very sound. It's not a glider that you want to learn how to fly XC with.
OTOH, if you are flying in the western US and know for sure you are in it for the long term and only want to buy and fly one glider in the next 10 years and your enthusiasm is high, the Ventus might be a good choice. But it will take you longer to get better at all of the XC skills than if you bought an LS-4 and flew it for 200 hours XC first. As was said, some of the unappreciated but very valuable things about the Ventus are auto hookups, pretty light wings, and it's easy to put water in it. Just pour water into the wing from a hose with meter attached. And it really, really goes. It's the perfect glider for me because I've flown a lot and I can't afford the next generation.
Buy a 4 or 3 or Mosquito or Pegasus or the like, fly it for 200-300 hrs. XC, then buy a Ventus. The numbers are only slightly different but the performance is dramatic and well worth it in my opinion, particularly with water..
An Oudie2 or similar is a very powerful easy to add computer sufficient for navigation. The radio is also important, should be clear and have a functional PTT.
And you should probably consider adding FLARM if it doesn't already have it..
And don't buy anything without a sound Komet or Cobra trailer unless you have hangar access.
Pretty tough to have all that and a good finish for $25K but I wish you success. 10 years ago it was impossible!
Old April 1st 19, 08:47 PM posted to rec.aviation.soaring
Michael N.
Can you comment further on the differences in handling of the Ventus B with and without winglets?
Thanks!
Old April 1st 19, 09:31 PM posted to rec.aviation.soaring
Thanks!
Unfortunately I can't, never flown one with them. There have been comments in other threads iirc. JS's post above is a good one, safety is the primary concern with all of this. Another tack... your instructor, and competent conservative pilots that you hold in high regard that know your flying, that you have flown with, will know. Ask them what they think of your idea and if they get quiet and take a long pause, listen . This works for many, many questions in soaring... "I'm thinking of doing _X_, whaddya think"? If eyes dart towards the ground you probably have your answer. Like the day I was considering a Diamant...
And are you sure you would lose any significant amount of $ buying and selling glider #1? Gliders are getting cheaper over time i believe so if you buy one with a good finish, are not stuck with a "hot potato" as it were, then it's mostly just inconvenience. And you might have a much better idea what you DO want, say you have a chance to fly a Ventus for example, and then be in a position to jump and buy the glider you know you want when it comes up for sale.
Old April 1st 19, 06:02 PM posted to rec.aviation.soaring
Michael N.
As a secondary question, how well do winglets, or 16.6 extensions help the flying qualities of the Ventus B?
Old April 1st 19, 07:11 PM posted to rec.aviation.soaring
First questions nobody asked.......
Where are you flying?
How serious?
I can only comment on 20's........
20a, fantastic flaps......early flying season, come in very high on final, do full landing flaps and full dive brakes.......drops like a homesick brick.......
But, elevator is not auto connect.......know of a ship trashed because of this.
A 20A or C, limited to 9pounds..........fine if eastern thermals. Screwed if fast conditions.
Sucks to western thermals or ridge......trust me, I have been beat in eastern ridge in a nationals......I had local knowledge so made time on gap climbs, watched heavier gliders run by on long ridge runs. Yes, ran against "DG in a LS6" and,others.
Flying ridges or western thermals, maybe a 20B.
All the 20's can be helped with winglets.
I have my preference, but I am biased partly because I was "beta boy" on lots of testing for 20 and 24 winglets.
In your price range.....I will say a standard AS ship......partly because if you learned on a SGS, control harmony is similar.
I can't state for other glass single seaters.......
As stated before, in your price range, a flapped ship is likely borderline a rat.
Bad?.......ask Daniel on his performance on a "rat ship" I know of last year.
Crazed surface THAT IS SMOOTH can do well.
Most of a result is the "nut behind the stick".
Just my opinion.
Best I ever did was first page on the SSA ranking list.
I won't say I am a "mover or shaker"....,,
Old April 1st 19, 08:27 PM posted to rec.aviation.soaring
Michael N.
On Monday, April 1, 2019 at 12:11:36 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
How serious?
Yep, agreed I am a nut :-)
How serious? I don't know yet, to be honest. I'd like to compete in club class when I have some time built up.
I can't afford to buy or sell gliders over and over, so my intent is "best bang for the buck" and flapped for the short field landing capabilities. I'm not afraid of the workload of flaps, as I noted I have some hours in Mooney's and other complex high performance aircraft that require concentration and planning especially on approach to land.
I will be flying mountain, as I am part time in Utah. I learned out of Minden, flying wave and mountain.
I had heard that the ASW20 (a-c) were good for mountains due to the semi-flexible wing design?
Thanks for any further feedback...
Mike
Long engine-off cross-country flights in a XImango Motor glider [email protected] Soaring 0 July 15th 17 09:57 PM
Glider cross-country time toward commercial SEL requrements? Matt Michael Soaring 17 November 25th 04 04:45 PM
Glider Cross-country signoff & FARs Jamey Jacobs Soaring 45 January 24th 04 07:41 PM
Cross Country glider rentals Burt Compton Soaring 0 January 10th 04 07:31 PM
A 4,200 NM cross-country Phil Verghese Piloting 0 September 1st 03 10:03 PM
