I'm seeing this more and more but have no idea what they're called. Refer to this pictu https://cdn.jetphotos.com/full/6/53013_1459261993.jpg
This was Stefan Langer's Libelle, it's got those black plastic(?) thing at the aileron and wing. So does this Cirrus: https://cdn.airplane-pictures.net/im.../14/975766.jpg What are they called and do they help in performance? Would it be worth installing? |
At 10:58 08 April 2019, Senna Van den Bosch wrote:
I'm seeing this more and more but have no idea what they're called. Refer to this pictu https://cdn.jetphotos.com/full/6/53013_1459261993.jpg This was Stefan Langer's Libelle, it's got those black plastic(?) thing at the aileron and wing. So does this Cirrus: https://cdn.airplane-pictures.net/images/uploaded- images/2017/10/14/975766.jpg What are they called and do they help in performance? Would it be worth installing? They are aerodynamic "fences". Standard on inboard end of flaps/faperons on many gliders, DG800, Antares and others. All mods make you go faster, no? |
Yes, they're typically called fences. They attempt to keep higher pressure air from the bottom of the wing from going past a control surface when you move a flight control.
Op maandag 8 april 2019 13:30:06 UTC+2 schreef Dave Walsh:
At 10:58 08 April 2019, Senna Van den Bosch wrote: I'm seeing this more and more but have no idea what they're called. Refer to this pictu https://cdn.jetphotos.com/full/6/53013_1459261993.jpg This was Stefan Langer's Libelle, it's got those black plastic(?) thing at the aileron and wing. So does this Cirrus: https://cdn.airplane-pictures.net/images/uploaded- images/2017/10/14/975766.jpg What are they called and do they help in performance? Would it be worth installing? They are aerodynamic "fences". Standard on inboard end of flaps/faperons on many gliders, DG800, Antares and others. All mods make you go faster, no? I've googled a bit and found this document testing the effect of those fences: https://tu-dresden.de/ing/maschinenw...TS.pdf?lang=en Fairly neglectable, even 5 pairs of fences were teste: "...the loss in overall performance by applying for example four additional pairs of fences on the wings of an ASW-28 (Fig. 1). The result was a decrease in maximum L/D of about 0.25 points for a singe pair of fences..." Worth the read ![]() |
These aileron fences do not help performance. They may help with some other issues:
1) most gliders require counter-aileron while circling. The fences prevent ailerons from being sucked to the upper side when the aileron is deflected. The suction is applied by beginning airflow seperation at high angles of attack. This issue exists with some older gliders (e.g. LS1, Libelle) when getting close to stall while circling. 2) slight improvement of aileron authority 3) improve airflow on wing/fuselage intersection on flapped gliders |
Op maandag 8 april 2019 18:23:48 UTC+2 schreef :
These aileron fences do not help performance. They may help with some other issues: 1) most gliders require counter-aileron while circling. The fences prevent ailerons from being sucked to the upper side when the aileron is deflected. The suction is applied by beginning airflow seperation at high angles of attack. This issue exists with some older gliders (e.g. LS1, Libelle) when getting close to stall while circling. 2) slight improvement of aileron authority 3) improve airflow on wing/fuselage intersection on flapped gliders I'm owner of a DG-101, would it be interesting to fit them? I know a few Std Cirrus and Std Libelles which have them fitted. |
Difficult to use with wing covers.
I found out the hard way on my Nimbus 3. ROY |
| Thread Tools | |
| Display Modes | |
| Discus B aileron sealing | Kurt[_3_] | Soaring | 3 | March 17th 17 11:59 AM |
| Aileron inboard edge sealing | Piotr Jaszczuk | Soaring | 14 | March 11th 16 12:41 AM |
| GPS-NAV security sealing | Sam Discusflyer[_2_] | Soaring | 31 | August 29th 08 03:28 AM |
| Sealing a Schweizer; 1-35 mainly | TOM RENT | Soaring | 0 | April 11th 04 09:46 PM |
| Libelle Gap Sealing | Owain Walters | Soaring | 4 | April 11th 04 08:13 PM |
