Pawnee Tow Release
Old September 16th 19, 04:48 PM posted to rec.aviation.soaring
Duster[_2_]
Default Pawnee Tow Release
It's an "R" model and I can forward you the FAA form 337 paperwork they have on file for the engine if you want. Thanks for the useful tips; we'll follow up.
Mike
Old September 16th 19, 06:51 PM posted to rec.aviation.soaring
Bob Youngblood
On Monday, September 16, 2019 at 11:22:06 AM UTC-4, Charles Longley wrote:
Interesting that someone put an O-470 on a Pawnee. Do you know which model it is?
To answer your question the TOST tow release comes with an STC. W&W does a pretty good job supporting them.
Here’s the standard one-
https://wingsandwheels.com/aircraft-...-for-pa25.html
If your club wants to spend a lot more money and go to a retractable one here’s the link-
Pros and cons for each. Depends on how your club operates.
I would put the release in front of the throttle where the pilot can easily see it. One of the Pawnee’s I fly is set up that way. The other two use the stock dump lever. Which is acceptable but not as convenient to reach.
Any IA can sign off the FAA form 337 to document the conversion. The approved data will come from the STC and AC 43.13.
Hope this helps.
Charlie
The TOST DOES NOT come with a STC. It comes with an EASA1 European form not a STC. Read 43-13-2A Chapter8, page 73-75, Circular adv. This is not as difficult as one might think. Bob
Old September 16th 19, 03:07 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Originally Posted by Duster[_2_] View Post
We are looking to purchase a Pawnee PA-25 that had a Continental engine installed (230hp?). It is approved for aerial towing (Schweizer hook) and we are trying to decide if it's worth the time/money to seek an FAA conversion to towing gliders with a TOST. Have read through several of the RAS discussions on this and talked with a couple clubs that completed STC's/FDSO field inspections. I get the feeling it's a real headache, some people concluded they wouldn't do it again. Anyone have a better experience or advice?
Thanks
D
"Trying to decide if it's worth the time/money?" Time and money should not enter into the equation when the life of your tow pilot may depend on the TOST release. If you don't care about the life of your tow pilot then by all means keep the Schweizer hook. While you're at it you might give consideration to placing the release handle where the pilot can quickly access it in the upright, seated position. JMHO
Walt Connelly
Former Tow Pilot
Old September 16th 19, 08:07 PM posted to rec.aviation.soaring
Bob Youngblood
On Monday, September 16, 2019 at 2:43:06 PM UTC-4, Walt Connelly wrote:
'Duster[_2_ Wrote:
;1000607']We are looking to purchase a Pawnee PA-25 that had a
Thanks
D
Walt Connelly
Former Tow Pilot
Walt Connelly
I think that Walt has pretty much summed up the situation. Walt has see my towplane release arrangement and commented on what he saw on the Yellow Gorilla, simply put, it is SAFE, but not fool proof. Get that release handle where it is within easy reach of the pilot.
Old September 17th 19, 02:35 PM
Senior Member
Thanks
D
Walt Connelly
Former Tow Pilot
Walt Connelly
There is NO foolproof system, if the glider kites suddenly at a low enough altitude the tow plane will go in with potentially catastrophic results. I'm not talking about the slow, annoying type of kite, I'm talking the tow plane going from staight and level to nose steeply down in the wink of an eye, it happens. My concern is that a known deficiency in both the Schweizer hook and the position of the release continue to prevail. IF the Schweizer hook is to be used it must be inverted and the release handle needs to be such that it is immediately available to the pilot in the upright, seated position. If your IA can't figure out how to do this get another IA.
Walt Connelly
Former tow pilot
Now happy helicopter pilot.
Old September 16th 19, 06:17 PM posted to rec.aviation.soaring
Thanks
D
See if the Pawnee is certified as "Normal" vs. "Restricted". If it is in the "Restricted" category, the "special purpose" will be on the Airworthiness Certificate and it needs to say "glider towing" - not "banner towing" - in order to legally tow gliders.
Old September 16th 19, 11:38 PM posted to rec.aviation.soaring
Duster[_2_]
Good point; the one of interest to us had earlier been incorrectly categorized as "Normal" which the FAA since corrected to read "Restricted; aerial advertising, Other- Banner Tow, Glider Tow". The "Time and Cost" concern regarded converting this Pawnee from banner towing with Schweizer release to glider towing w/Tost release. We love our tow pilots.
.....though sometimes that's not so obvious. This summer a misplaced tow rope got sucked into our tow plane's prop. Only one tow after the engine was replaced and prop overhauled; and while towing a twin Grob (single pilot), rear canopy started to raise @ 2,500', glider nose pulls up, tow plane's tail goes vertical, rope breaks, tow plane enters spin, spin recovery but becomes inverted, tow pilot recovers at 500' AGL. Finally the tow plane and glider land safely but both front and rear glider canopies have departed (front one broke loose possibly when cockpit items shattered it when in negative g. We are so thankful the tow pilot's vast experience got him out of that mess!
Old September 17th 19, 02:12 AM posted to rec.aviation.soaring
Charles Longley
Wow good job on the tow pilots part!
Old February 26th 20, 01:07 PM posted to rec.aviation.soaring
Bruce Cynamon
Weirsdale Glider Club
Bruce,
Curious as to what days your club is active. Would like to drop by and have a look. What glider/gliders do you have? While I have no interest in towing ever again, with the proper ship I might be interested in catching a thermal. I own property up in your area.
Walt Connelly
Former Tow Pilot (7000 TOWS)
Now Happy Helicopter Pilot.
Old February 27th 20, 03:32 PM posted to rec.aviation.soaring
On Wednesday, February 26, 2020 at 8:07:25 AM UTC-5, wrote:
Bruce Cynamon
Bruce,
Walt Connelly
Walt
We do not have a regular schedule, we fly when the conditions look good and the tow plane is available. I emailed you my phone number, drop me a line and we can let you know when we will flying.
Bruce
Piper PA-25 Pawnee pics [04/11] - Pawnee pulls a glider.jpg (1/1) Miloch Aviation Photos 0 November 10th 18 03:53 PM
Piper PA-25 Pawnee pics [01/11] - A Swift glider is performing continuous full rolls while being towed by a Pawnee.jpg (1/1) Miloch Aviation Photos 0 November 10th 18 03:53 PM
Pawnee Tost Release Mike125 Soaring 1 April 16th 08 03:59 PM
Tow Release Handles for Pawnee and C182 [email protected] Soaring 2 March 12th 07 02:40 AM
WTB towhook release for Piper Pawnee [email protected] Soaring 2 November 22nd 06 03:29 PM
