Can a Plane on a Treadmill Take Off?
Old February 5th 06, 02:34 AM posted to rec.aviation.student,rec.aviation.piloting
Default Can a Plane on a Treadmill Take Off?
"cjcampbell" wrote in message
Saw this question on "The Straight Dope" and I thought it was amusing.
http://www.straightdope.com/columns/060203.html
The question goes like this:
"An airplane on a runway sits on a conveyer belt that moves in the
opposite direction at exactly the speed that the airplane is moving
forward. Does the airplane take off?" (Assuming the tires hold out, of
course.)
Cecil Adams (world's smartest human being) says that it will take off
normally.
When this question was raised on Sci.aeronautics it lasted 14 replies, (as
archived by Google groups, but I think that some other posts were dropped by
the news servers.)
http://groups.google.ca/group/sci.aeronautics/browse_thread/thread/e344b133e57880a0/57a2a6789dd92bf6?lnk=st&q=(treadmill)+group%3Asci. aeronautics&rnum=1&hl=en#57a2a6789dd92bf6
One of the posters raised the issue of what would happen when the aircraft
returned for landing.
we are up to about 110 replies here on r.a.s, r.a.p.
A similar question was posed in the Airliners.net forums, what a great
discussion it was! See he
http://www.airliners.net/discussions...d.main/136068/ over
400 replies!
I am quite surprised that this question has received the amount of
consideration that it has. Must be a slow news month or maybe is an
indication that there are more people thinking about flying than there are
actually doing it.
Old February 5th 06, 03:49 AM posted to rec.aviation.student,rec.aviation.piloting
course.)
normally.
Maybe he's not so smart after all :)
On a calm day you can run and feel a wind on your face because you are
moving across the ground as well as through the air. But, if you run on a
treadmill there will be no wind because you are not moving through the air -
the air is calm so it has no relative motion with respect to the ground.
Neither do you when you run on a treadmill.
Assume the airplane is on the conveyor and there is a 10 kt headwind, and
assume we need 60 kts for takeoff. The only way to generate the additional
50 kts of airspeed is by moving across the ground at 50 kts. If the
airplane is standing still because the conveyor is moving backwards at the
same speed that the airplane is moving across the ground at, then the
airspeed will still be 10 kts.
If the conveyor keeps the airplane standing still relative to the ground,
then it cannot take off. If it could, then we'd all have problems during
run up because the brakes do the same thing that the theoretical conveyor
does - prevent motion across the ground.
BDS
Old February 5th 06, 03:56 AM posted to rec.aviation.student,rec.aviation.piloting
"BDS" wrote in message
t...
air -
Yes, but an airplane isn't propelled by its feet.
Old February 5th 06, 02:57 PM posted to rec.aviation.student,rec.aviation.piloting
This is where everyone who seems to think that the airplane will fly is
getting confused.
The method of propulsion doesn't matter. You can drive an airplane down the
runway by driving its wheels just like a car and it will still reach takeoff
airspeed and fly briefly. The propeller is only important once you are
airborne, because you need something to pull you through the air.
The bottom line is this - you cannot take off without first moving across
the ground unless the wind (airmass movement relative to the ground) is
blowing hard enough to give you sufficient airspeed to fly without moving.
In this case, once you take off your airspeed will immediately begin to
decrease unless you are using a prop to pull you through the air, or a
tether to hold you there (relative to the ground).
Example - a floatplane is sitting in a river that is moving at 30 mph (hey,
it's a fast river!). There is also a wind blowing down the river at 20 mph.
If the floatplane is anchored and facing into the wind, it has an airspeed
of 20 mph. If you release the anchor and use enough engine power to get the
plane going through the water upstream at 30 mph you will be standing still
with reference to the shore, and your airspeed will be 20 mph. If the river
was flowing at a rate in excess of the maximum speed of your airplane, then
you could never move forward going upstream with reference to the shore, and
your airspeed would never exceed 20 mph, even at full throttle. If you
fully understand this then you would know that you could shut your engine
down, face downstream, and take off and fly briefly.
BDS
Old February 5th 06, 03:17 PM posted to rec.aviation.student,rec.aviation.piloting
getting confused.
Nevermind - I finally get it.
DUH!!
BDS
Old February 5th 06, 08:19 PM posted to rec.aviation.student,rec.aviation.piloting
BDS, aren't you glad you used initials rather than your name?
DUH!!
BDS
Old February 5th 06, 03:23 PM posted to rec.aviation.student,rec.aviation.piloting
m...
getting confused.
takeoff
And all this time, I thought it was the propellor that made the airplane
move across the ground. I stand corrected.
What do you mean, 'unless you are using a prop to pull you through the air'?
How does your airplane work?
(hey,
mph.
still
river
then
and
This is not an anology. With the wheels turning on the treadmill, friction
(and thus the force exerted) are negligible. The force exerted by the
running water on the floats is much greater.
BDS
Old February 5th 06, 03:39 PM posted to rec.aviation.student,rec.aviation.piloting
m...
getting confused.
takeoff
(hey,
mph.
still
river
then
and
BDS
BUT... the initial condition, as stated in the OP, is that the
river(conveyor) is moving at the same
speed as the airplane but in opposite directions. So, with a 30 mph
river(conveyor) and a
20 mph headwind the airspeed would be 50 mph. The plane is moving at 30 mph
in the opposite
direction with respect to the shore(runway). The airplane would then be
travelling upstream at 60 mph
relative to the rivers surface. The only difference between the river
example and the conveyor example is how firmly the airplane is
coupled to the conveyance. The floats/river scenario would require more
thrust to overcome the resistance
than the wheels/conveyor example. Same mathmatics, different numbers. The
floatplane just needs a bigger motor.
Old February 5th 06, 04:04 AM posted to rec.aviation.student,rec.aviation.piloting
t...
But the airplane *isn't* standing still (as others have pointed out).
Since the wheels are able to spin freely, the reverse thrust by the
conveyor belt is *not* transferred past the wheels to the plane's
fuselage, and so the only remaining applied force is the unbalanced
forward force of the thrust of the engine.
The conveyor *doesn't* "drag" the plane backwards to compensate
for the engine's thrust. All it does (as others have pointed out) is
spin the wheels faster.
It doesn't.
(Don't worry... I didn't understand it at first either.)
BDS
Jeff Shirton (PP-ASEL)
Old February 5th 06, 04:18 AM posted to rec.aviation.student,rec.aviation.piloting
"One of the posters raised the issue of what would happen when the
aircraft
returned for landing."
If the belt were moving backwards at the speed of the aircraft when it
touched down, it would be similar to landing with that much tailwind,
basically, your ground speed would double you airspeed at touch down.
Jester
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
Navy sues man for plane he recovered in swamp marc Owning 6 March 29th 04 12:06 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
