Gear Warning
Old November 26th 05, 04:07 PM posted to rec.aviation.soaring
Default Gear Warning
"Derek Copeland" wrote in
message ...
Isn't the fact of the matter that retractable undercarriages
are a 'Murphy's Law' item that it is possible to get
wrong, whatever systems you put in place.
There are only two sorts of pilots - Those who have
already landed gear up, and those who will some day.
No offense, but that, of course, is hog-wash. There is a large third
category of pilots: "Those who use whatever tools are available to them to
fly safely and NOT land gear up during their entire flying career."
I intend to remain in this latter group.
all the best,
bumper
(2000+ hours in retractable since 1991 and no belly scratches yet. One gear
warning save during training.)
Old November 26th 05, 05:10 PM posted to rec.aviation.soaring
Dear 'bumper',
Good luck in remaining in the third category!
You have been saved from a wheel up landing on one
occasion by a gear up warning device. I was not so
lucky!
I believe that you said in a previous piece that it
was in a Mooney, i.e. is a powered aircraft. Power
flying tends to be a bit more structured than gliding
in terms of checklists etc, but then you have more
time to carry them out during the mini cross-countries
that power circuits seem to have become.
OK, I will concede that a few glider pilots go through
their careers without a wheel up landing, but they
are probably in the minority, or fly fixed gear types
anyway.
I have never understood the arguments against pre-landing
checks or undercarriage warning devices, which I will
list:
1) You might forget to do the check, or get it wrong!
2) You shouldn't rely on something that could go wrong
and fail to operate
3) An U/C warning device going off late on finals could
distract a pilot and cause him to have a serious accident,
rather than a minor scrape.
On the other hand:
1) In gliders, the U/C warning device is normally linked
to the airbrake lever. If you unlock the airbrakes
with the wheel up, the warning device should sound.
I normally unlock the airbrakes, but hold them shut,
on the base leg, so if the warning did go off, I would
have plenty of time to sort the problem out.
2) Undercarriages provide a degree of shock absorption
in the event of a heavy landing. A heavy wheel up landing
is much more likely to injure the pilot and seriously
damage the glider.
3) If I am warned at the last minute that I have left
the gear up, I don't necessarily have to try and lower
it. I can either head for a grass area, rather than
a tarmac runway, or aim to land as gently as possible.
I would rather know!
With pre-landing checks plus an U/C warning device,
at least two things have to go wrong before a gear
up landing can occur. Why not use the available techiques
and technology?
Derek Copeland
At 16:12 26 November 2005, Bumper wrote:
'Derek Copeland' wrote in
is a large third
category of pilots: 'Those who use whatever tools are
flying career.'
all the best,
bumper
Old November 27th 05, 12:16 AM posted to rec.aviation.soaring
message ...
Dear 'bumper',
lucky!
True, however, power planes sometimes do lots of touch-and-goes, so there's
more opportunity for a gear-up. Perhaps this skews the odds back in the
other direction? One might argue that a Mooney is not the typical trainer,
so wouldn't be subject to this.
I got the Mooney when I was a 25 hour student pilot, so was doing lots of
circuits and bumps when I had my "almost" gear-up. Abeam the numbers, I
thought, "Better put the gear down", not thinking that's where it already
was because I'd failed to raise it on take-off. Flipped the gear switch,
didn't matter which direction - - I just needed to operate something - - and
listened to the somewhat familiar sound of the gear in transit. Hmm, why is
that warning sound disturbing me?? Had there been no gear warning system,
there's no question of what would have happened next.
all the best,
bumper
anyway.
list:
and fail to operate
On the other hand:
damage the glider.
and technology?
Derek Copeland
is a large third
flying career.'
all the best,
bumper
Old November 27th 05, 04:07 PM posted to rec.aviation.soaring
For club 2 seaters it should be easy to satisfy both those that desire
a gear warning and those that think gear warning is dangerous and wish
to rely on checklists. Just fit a gear warning off switch and perform
a simple short final check - airspeed good, gear warning OFF.
The ideal position for the switch would be on the airbrake handle of
course otherwise the gear warning would have to be turned off before
the airbrakes are opened.
In my single seaters I''ll stick with my short final check - airspeed
good, gear down.
Andy
Old November 27th 05, 05:53 PM posted to rec.aviation.soaring
At 16:12 27 November 2005, Andy wrote:
snip
check - airspeed good, gear down.
Andy
Good idea; keep doing it!
But what is wrong with installing a gear warning system
and then pretending it is not there?
Old November 30th 05, 11:13 AM posted to rec.aviation.soaring
Not stupid at all Mark, if you read your post that
is exactly what you have said. I accept that it might
not be what you meant.
Not all pilots who have a retractable undercarriage
and no alarm will land wheels up, in fact I would say
that, despite anecdotal 'evidence' to the contrary,
the majority will not.
I don't think I have ever said do not ever fit an alarm,
just be aware it is a double edged sword.
At 00:18 30 November 2005, Mark Newton wrote:
Don Johnstone
At 11:36 25 November 2005, Mark Newton wrote:
A wheels-up landing in an aircraft which doesn't have
an undercarriage alarm is a wholly predictable accident.
Why is there this attitude that says it's ok to see
it coming,
yawn about it, and do basically *nothing* to prevent
it?
I mean, you can stress checklists and piloting skill
as much
as you want, but we've built up a track record which
says
those things DON'T WORK to prevent these accidents,
while building
up a simultaneous record which says undercarriage
warnings
DO work. So why resist the fitment of undercarriage
warnings?
So, your argument is that all pilots will land with
the wheel up if they do not have an alarm fitted?
Contratulations, Don, for winning the award for stupidest
comment yet posted in this thread. Which is some feat.
As you were typing it, you *knew* that my argument
was nothing
of the sort, but you went ahead and typed it anyway.
Well done,
mate, your determination and willingness to push-on
regardless
of your own knowledge of the facts of the situation
stands
proud as an example to us all.
- mark
Old November 30th 05, 10:43 PM posted to rec.aviation.soaring
Don Johnstone
No, exactly what I said is quoted below. It bears very little
resemblence to the words you have attempted to put into my
mouth.
I'm pretty confident that other readers, having looked at the
words I used and the meaning you have attributed to them, will
conclude that you're way off. So if you want to continue on
this basis feel free, just understand that it's your reputation,
not mine, that you're impugning.
I accept that it might not be what you meant.
Thanks heaps for cheapening the discussion, Don. Excellent
work, you have lots to be proud of!
- mark
Don Johnstone
it coming,
it?
as much
says
while building
warnings
warnings?
was nothing
Well done,
regardless
stands
- mark
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 01:15 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
