limit of trim = limit of travel?
Old May 2nd 08, 12:01 PM posted to rec.aviation.piloting
Mxsmanic
Default limit of trim = limit of travel?
Peter Dohm writes:
I do not presently fly, but plan to do so in the future. Therefore, please
do not start out with a PC simulator--especially with a single monitor--as a
starting point for learning to fly in visual conditions. Doing so will
teach you to fixate on exactly the wrong things, you will rarely look at the
right things, and the thought of subsequently having to share the sky with
anyone who is doing that really SCARES THE LIVING CRAP OUT OF ME!!!!!
The jury is still out on whether prior sim experience is good or bad, and it
may depend to some extent on the individual, the instructor's preferred
methods, etc. I believe a prospective pilot can learn a lot more from a book
and a sim than from a book alone.
  #102
Old May 2nd 08, 01:10 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Mxsmanic" wrote in message
Peter Dohm writes:
please
monitor--as a
with
it
book
Yeah, but you believe a lot of stupid ****.
Absent any actually experience, your opinion means nothing.
  #103
Old May 2nd 08, 01:11 PM posted to rec.aviation.piloting
Maxwell[_2_]
Benjamin Dover writes:
You can do it with FAR LESS instruments than are found in a
typical C182. If you can't maintain constant altitude in a C182 in
visual
conditions without it being a pain, you're too ****ing incompetent to fly
on instruments.
Motion cues are absent and visual cues are limited in the sim, which may
be a
factor. However, I'm sure I'll get better with practice. I may try to
install Reality XP instruments, which are smoother in motion and better
for
detecting small changes.
Try one of the sim groups. Maybe they give a ****.
  #104
Old May 2nd 08, 01:40 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Wed, 30 Apr 2008 00:12:54 +0000 (UTC), Bertie the Bunyip
WingFlaps wrote in news:ad8fc9c9-57cb-4733-9e97-
On Apr 30, 9:37*am, wrote:
On Apr 29, 2:24 pm, WingFlaps wrote:
I don't follow this. The trim surface operates in the opposite
direction to the trimmed surface and takes area away from it.
Explain
please?
Cheers
* * * *The trim tab generates a force that moves the trailing edge
of
the control surface. So if you trim nose-up, you'll be moving the tab
downward, where it forces the elevator up.
Yes that is exactly what I said. So, does the trim actually improve
control responsiveness or not?
Do you mean if oyu move the trim tab in the same direction as the
elevator? IN general, yes, it will.
Bertie
Cheers
control responsiveness? no absolutely not.
trim will change where the apparent zero force neutral position is as
sensed from the control column.
responsiveness in elevator is only changed by cg position.
responsiveness in rudder doesnt change nor does aileron.
btw this area stuff wingflaps talks about is clueless.
Stealth Pilot
  #105
Old May 2nd 08, 06:44 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Stealth Pilot wrote in
Explain
please?
Cheers
of
tab
Bertie
Cheers
Sure it will. Authority will be increased if the tab is moved in the
same direction as the surface, especially at low speeds. You're reaching
a more ideal camber.
Yes, of course, but I'm not talking about feel, I'm talking about the
actual power of the surfaces.
Area?
Bertie
  #106
Old May 2nd 08, 06:59 PM posted to rec.aviation.piloting
"Maxwell" luv2^fly99@cox.^net wrote in
Peter Dohm writes:
please
monitor--as a
will teach you to fixate on exactly the wrong things, you will
rarely look at the
sky with
ME!!!!!
and it
preferred methods, etc. I believe a prospective pilot can learn a
Way to go stabilised boi.
Bertie
  #107
Old May 2nd 08, 07:00 PM posted to rec.aviation.piloting
visual
to fly on instruments.
may be a
to install Reality XP instruments, which are smoother in motion and
better for
What do they give you?
Bertie
  #108
Mxsmanic wrote in
Tina writes:
You said single piston, not single engine. Show me an airplane with a
significant climb rate using a single piston.
Single-engine Otto cycle reciprocating internal combustion engine.
Why not two strokes?
Bertie
  #109
Old May 2nd 08, 07:06 PM posted to rec.aviation.piloting
news:dd3d76f7-4d65-41de-afa8-c89dcf2651e6
@q1g2000prf.googlegroups.com..
a significant climb rate using a single piston.
Here's one. Just one piston, too.
http://video.google.ca/videosearch?h...0Airplane&um=1
&ie=UT
F-8&sa=N&tab=wv
Dan
Now there is a man with Honeck's money and Bertie's brains.
Awww, you're just being hurtful now.
BTW, Jay still has more money than the chattels he's ensnared.
Bertie
  #110
Old May 2nd 08, 07:07 PM posted to rec.aviation.piloting
Mxsmanic wrote in
visual conditions without it being a pain, you're too ****ing
incompetent to fly on instruments.
may be a factor. However, I'm sure I'll get better with practice.
Who cares? Go buy a Maro brothers game. You can see your score rise on
those!
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
speed limit in class B Andrey Serbinenko Piloting 0 July 23rd 06 04:05 AM
Pegasus life limit Mark628CA Soaring 2 March 30th 06 10:37 PM
Aft CG limit(s) Andy Durbin Soaring 13 November 26th 03 05:10 AM
Pushing the limit Dan Shackelford Military Aviation 20 September 14th 03 10:27 PM
