Glider near miss with Airliner (emergency climb) near Chicago yesterday?
Old September 26th 17, 06:30 PM posted to rec.aviation.soaring
Sean Fidler
Default Glider near miss with Airliner (emergency climb) near Chicago yesterday?
I just listened to this news on a major news network and pseudo confirmed it he http://www.airliners.net/forum/viewtopic.php?t=1374687
The newsperson actually said, "Why didn't this glider have a transponder, why wasn't this glider talking to someone, how is this possible…" live on the air.
I continue to believe that the sailplane community needs to fully adopt ADSB and transponders whenever outside of 3 miles of the airport (for basic training). Getting an exemption was a big mistake. Sailplane flying cross country, near major airspace, or at high altitudes should absolutely have ADSB and/or 250 watt transponders.
The awful scenario we are all worried about IS going to happen eventually. Its simply a matter of: A) was the gliding community pro safety or B) was the gliding community defiant and trying to wiggle out of safety and make special exceptions for itself.
When IT happens, the result will be unfortunate if we are still on the B path, as we are now…
Old September 26th 17, 06:51 PM posted to rec.aviation.soaring
Bruce Hoult
The awful scenario we are all worried about IS going to happen eventually.. Its simply a matter of: A) was the gliding community pro safety or B) was the gliding community defiant and trying to wiggle out of safety and make special exceptions for itself.
Those of us in other countries marvel that gliders in the USA don't have transponders. And that you still fly 2-33s and think basic trainer Grobs are high performance, of course.
I'd have thought that within 3 or 5 or whatever miles of the airport (or more at higher altitudes) would be *precisely* where you should have the transponder turned on.
I guess another surprising thing is that they allow IFR flights into class G airspace. That's the place you should have a right to fly without a transponder and the big guys should be kept away.
Old September 26th 17, 07:49 PM posted to rec.aviation.soaring
Pete[_9_]
Food for thought/outrage/discussion:
We all use and benefit from airlines without a doubt. However, they are in the business of making money to fly. They are flying big jets with poor visibility at high speeds with autopilot on. It's usually the jet hitting the object, not the otherway around. I feel it's their responsibility to pay for and develop technology to avoid gliders, ultralites, drones and birds WHEN OUTSIDE THE MODE C VEIL or BELOW 18,000 FT.
The FAA will continue to put the vicegrip down on recreational flying until it can't be done without a glass cockpit and a $150,000 machine if we are the scape goat for any near misses.
Reality is the airlines are creating the issue and making the $$ while doing it, they need to figure out how to avoid everyone else more effectively.
Instead, the professionals are relegating the task to mere mortal "private" pilots running a weekend club in the sticks to make sure the airline's operations are safer.
What do you trust more? The professionally maintained 757 and crew or the shared club transponder with the guy that sort of knows how to use it?
Until the 757 has the technology for object avoidance, there is nothing safe enough because the weak leaks in the the current model's safety chain are too weak.
For example, if I had a huge bus that I liked to drive 500 mph on the highway and I made money from this bus and then called you to say that you needed to spend $2,500 of your money to prevent my huge bus from hitting your car on the highway because I can't see you all that well, I think you would say "slow down and/or pay for the accident avoidance technology yourself.
Old September 26th 17, 08:06 PM posted to rec.aviation.soaring
Bruce Hoult
Reality is the airlines are creating the issue and making the $$ while doing it, they need to figure out how to avoid everyone else more effectively..
I'm not so sure. A shocking number of those airline pilots seem to have forgotten the most basic principles of flying.
Just one example:
http://www.popularmechanics.com/flight/a357/2156137/
Old September 26th 17, 08:12 PM posted to rec.aviation.soaring
jfitch
Yeah but a glider is pretty hard to miss when you can't see it, and at 250 knots or so you can't see it. I'm not sure why everyone is jumping right to ADSB, in this and most situations an old Mode C would have mad the encounter a non-issue. That said if the FAA allowed 199 type ADSB in gliders, I'd probably have one installed for next season. Requiring 250W and 145 gps sources fits the definition of perfection being the enemy of good enough.
Old September 26th 17, 07:36 PM posted to rec.aviation.soaring
We should just ban gliding. Between the horror of Elmira Death Hooks and causing spilled drinks on flying cattle cars gliding is just too dangerous for the modern world.
Old September 26th 17, 08:33 PM posted to rec.aviation.soaring
Darryl Ramm
I hope the rest of the gliding community in the USA has a more responsible and serious attitude to safety than your spilt drinks comment implies you do.
I have expected glider pilots were more responsible, but if attitudes about safety issues that affect airliners really are this flippant then the FAA needs remove glider transponder and ADS-B Out exemptions ASAP. To hell with all the operators that will harm that don't fly near busy airspace, lets regulate it because of irresponsible pilots and attitudes like you show.
We don't know exactly what happened here yet, don't know for sure if the glider had a working transponder or not, or how close the aircraft came, but this incident should be a reminder to the very real risk that gliders can pose to an airliner, and should remind us that transponders provide an effective safety net.
I notice the glider port where it looks you fly from is located between two VORs, maybe not airline traffic but I would expect lots of IFR traffic transiting there. I hope that operation/club is paying more attention to mid-air collision risk safety than it seems you do from these comments.
Old September 26th 17, 08:59 PM posted to rec.aviation.soaring
What about the hot air balloons, ultralights, antique airplanes, hanggliders, skydivers, drones, birds, and mountains?
It is our airspace too and we were there first. Airlines and motorplanes need to do a better job of avoiding all of the stuff in the sky. And if you guys start advocating for limiting my ability to fly without a transponder than I am going to start advocating to limit your flying regardless of how powerful a ball roasting beeper you put in your gliders.
Old September 26th 17, 09:21 PM posted to rec.aviation.soaring
Darryl Ramm
With that childish attitude you are a complete liability to the entire soaring community, not just from a safety viewpoint, but from the damage you will do the the impression of our sport. I sure hope the rest of the pilots who fly out of Post Mills Soaring Club have a much more responsible attitude about safety than you do. If not well, oh well thanks to your posts here, everybody, including the FAA, now knows what they might possibly be facing there. Lets hope it is nothing as bad as your attitude implies it might be.
Old September 27th 17, 02:20 AM posted to rec.aviation.soaring
Amen, thermaling in an airway without providing ATC a clue is not nice, regardless of who was there first. The attitude reflects poorly on our community and invites oversight (see 91.13).
That said, the FAA is making it less likely the clue will be provided with the ADSB program. I have mode C + Flarm now. To move to ADSB 2020 will cost $4k. (1800 for the transponder + $1800 for the GPS + install)
The cost give me pause especially because the 2x cost premium for the certified GPS appears to net a system which emits state vectors which are less accurate than the Flarm. This issue could be greatly improved if ATC were to use ADSB emissions with COTS GPS and increased uncertainty spheres. We already routinely depend on the Flarm Brick GPS for close encounters. It would be neat if FAA could approve at least that specific receiver.
Stinson Airliner pics 1 [04/11] - Chicago Municipal Airport - American Airlines - Stinson Model A Tri-Motor.jpg (1/1) Miloch Aviation Photos 0 August 14th 17 03:55 PM
Need to move a glider from Chicago to Los Angeles Maciek Arkuszewski Soaring 14 May 19th 16 12:59 AM
Aug 6th B738 and Glider Near Miss. Frankfurt Karen Soaring 70 October 23rd 10 06:27 AM
Glider-Airliner Near Miss jcarlyle Soaring 0 June 12th 07 05:52 PM
Report on "Old" Glider/airliner midair? Jim Kellett Soaring 5 October 13th 03 03:20 PM
