#121
Ron Natalie writes:
Nope, GPS finds a 3-d position based on the relative distances between sets of satellites in geosynchronous orbit. Roughly, yes. It knows no more about true north than magnetic without elaborate conversion between where the satellites are at any given instant and where the earth is. With two fixes, it has true north. If it's moving, it has at least two fixes. Funny, I'm looking at the sky today and all I see are clouds. My compass still works. There are lots of places on Earth where your compass won't work, but an ANS will. You are clueless aren't you. The engine in just about every airplane out there runs just freaking fine without any electrical power consumed nor delivered to the rest of the aircraft. Are they all Diesels? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#122
Ron Natalie writes:
This is makes you look pathetically stupid and is the main reason that most people on this forum are hostile to you. I think that's a bit backwards. People who are stupid are likely to be hostile. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#123
![]() "Ron Natalie" wrote in message m... Because some were never right. Some where set right but the local variation has changed and the VOR's were never realigned. It's not necessary for them to set exact, just that they are known with a reasonable precision. The fact that they are close to magnetic north is again as we've been saying, convenience because all courses and headings IN FLIGHT are done magnetic. If they were set to true north they would still be known with a reasonable precision. They'd be no less useful and they wouldn't have to ever be reset due to magnetic drift. |
#124
In rec.aviation.piloting Mxsmanic wrote:
Ron Natalie writes: Correct, that was my point. It doesn't change anything. Magnetic south and magnetic north are still opposite directions at any given point on the earth. They are close to opposite, but not exactly so. And that doesn't matter in the slightest. Give me a chart and a compass and I'll do just fine VFR. If you have a chart, you're not using your magnetic compass _alone_. And even if you have a chart and a compass, how do you determine where you are? By looking out the windows. In my real airplane, I can fly all around the local area for about 50 miles by doing nothing other than looking out the window and occasionally at the compass. In your toy flight simulator, I can't get from one local airport to another by looking at terrain. I have to use the simulator instruments. That's yet another difference between real and simulated flight. -- Jim Pennino Remove .spam.sux to reply. |
#125
Tim writes: Tell that to Charlie Lindbergh. Charles Lindbergh had not only multiple compasses but charts and a timekeeping device. He never would have gotten anywhere with just a compass alone. A true enough statement, but one that shows how very little you know about navigation. -- Jim Pennino Remove .spam.sux to reply. |
#126
Ron Natalie writes: CHORTLE. Have you any experience with a real INS. A real INS can't find squat without being told where it is starting from. This has to be boostrapped from other navigational devices. It's long term stability isn't any better than a compass. It needs additional input. Not to find true north. It can find true north all on its own. Total, utter, nonsense. You haven't the slightest clue how either a INS or a gyro compass work. snip rest -- Jim Pennino Remove .spam.sux to reply. |
#127
writes: If you want to go to and from true and magnetic, you need a chart to get the local difference. If you want to do anything, you need more than a compass. You need to know the heading to use to get somewhere. You use the compass to actually go that direction. If all you want to do is go in some particular direction until you can see a recognizable landmark, all you need is a compass. In order to recognize the landmark, you need something more than a compass. You mean like fly a heading 230 degrees for 47 miles and there will be a lake. At the lake fly a heading of 273 degrees for 32 miles and at that airport, fly a heading of 264 degrees for another 44 miles and you will be at your destination? You obviously know nothing of real world navigation. -- Jim Pennino Remove .spam.sux to reply. |
#128
EridanMan writes: The system is a rube goldberg contraption with an instant-on kill switch. There is no instant-on kill switch. It takes quite a bit of time to send commands to all the satellites. Yeah, a few seconds once the decision is made. Wait until someone launches a home-made GPS guided cruise missile into Washington DC, watch them flick the switch, and see what happens. Just hope it doesn't happen at night, and you're not in the air at the time. They can't do that any more. It would be a worse disaster to turn it off than it would be to just let it run, for both military and civilian use. If backup systems like VOR, NDB, LORAN didn't exist, that might be true, but the backukp systems do exist. It also requires constant, very expensive maintenance, a complex receiver in good working order, and as I mentioned, can be turned off at the push of a button. None of these are traits you want for you primary navigation system. It cannot be turned off at the push of a button. I'm not aware of any constant maintenance requirement. Databases have to be updated by a monopolistic price-gouging private enterprise, but that's a separate issue. We'll just add that to the long and growing list of things you are not aware of. The simplest, fastest and most dependable (in VMC) way of finding true north (or any form of navigation) is simple spatial awareness and pilotage. A good chart, and a good eye. I wouldn't trust those. That's because you haven't a clue as to how to use them, especially the awareness part. -- Jim Pennino Remove .spam.sux to reply. |
#129
Ron Natalie writes: Nope, GPS finds a 3-d position based on the relative distances between sets of satellites in geosynchronous orbit. Roughly, yes. It knows no more about true north than magnetic without elaborate conversion between where the satellites are at any given instant and where the earth is. With two fixes, it has true north. If it's moving, it has at least two fixes. And that tells you your course, not which direction the nose is pointed. There is no GPS instrument available that will tell you which way your nose is pointed. Funny, I'm looking at the sky today and all I see are clouds. My compass still works. There are lots of places on Earth where your compass won't work, but an ANS will. The only two places on Earth a magnetic compass doesn't work in an airplane are over the north and south magnetic poles. You really are ignorant, aren't you? You are clueless aren't you. The engine in just about every airplane out there runs just freaking fine without any electrical power consumed nor delivered to the rest of the aircraft. Are they all Diesels? Good lord. Ignorant doesn't even begin to describe how totally, utterly, and completely clueless you are. Piston engines have magnetos which generate the spark plug firing voltage, and only the spark plug voltage. The engine has no other need for electrical power and doesn't generate electrical power to run things like GPS unless it has a generator or an alternator installed. Many airplanes have neither a generator or an alternator. Turbine engines only require electrical power to start. Once they are running, they are self sustaining. If you are going to be a pretend pilot, at least go learn some basics so you don't look like a complete fool. -- Jim Pennino Remove .spam.sux to reply. |
#130
On Apr 5, 1:33 am, RomeoMike wrote:
DR wrote: Declination in navigation is actually something else but I'll let you googgle for it. I'm not sure that's really true. In aviation we talk about variation, but when I'm using 7.5' topo maps on the ground, declination is the term used for the difference between magnetic and true north. (See the bottom left of a US DOI Geologic Survey 7.5' topo.) Variation and declination are defined the same If there's a more sophisticated use of the word declination in navigation, I'm willing to be enlightened. Astro navigation, but it's still an angle away from a standard vector. So different sciences are using the same word with different meanings. However, you're of course correct that for magnetic navigation, declination and variation are the same thing. http://www.ngdc.noaa.gov/seg/geomag/faqgeom.shtml Kev |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
