Question for the real pilots
Old April 13th 07, 12:28 AM posted to rec.aviation.piloting
C Booth
Default Question for the real pilots
I was flying out of VGT last month (North Las Vegas) heading back to
SLC in an Aztec after a great round of Golf. After getting VFR
clearance from ground to MMM (Mormon Mesa Vortac) which is ENE of
Vegas. Cleared for takeoff and given a heading from the tower, then
handed off to Nellis aproach. The controler gives me heading and asks
intention and sounds like she has marbles in her mouth. I ask her to
repeat instructions and finally get her instructions read back. I am
squawking a descreat code and continuing to follow instructions from
Nellis getting vectored out of the way of inbound F-18's and even a
B-2. All of a sudden out of the blue she calls me and asks me if I
have class B clearance. I gulp hard a couple of times, in all the
vectors and hand offs I realize that I have not received clearance...I
fess up and say noooo. She says "Well, you're right smack in the
middle of Class B airspace". That's it, no instructions. I say,
"Well..., can I get clearance now, or do you want me to go somewhere?"
She gives me the clearance. Whew, first time that has ever happened
to me. I am usually very careful not to bust airspace. Needless to
say I was embarassed but in other instances where I have been vectored
into Class B, such as in this instance, I have always been given the
clearance. I know that it is my responsibility to get the clearance
before flying into the airspace, but if they are giving vectors to
penetrate the airspace, are they at fault as well? Maybe I should
file a NASA report just to be safe, what do you think?
Just thought an aviation based thread might be good for the group.
Cbooth
SEL MEL Instrument
Old April 13th 07, 12:42 AM posted to rec.aviation.piloting
Jose
Yes, file a NASA report. They shouldn't vector you into the Bravo
without giving you those magic words, but it happens.
Jose
Get high on gasoline: fly an airplane.
Old April 13th 07, 01:00 AM posted to rec.aviation.piloting
JGalban via AviationKB.com
Technically no, they are not at fault. As you posted, the responsibility
is yours.
Realistically, I have a problem with a controller that issues a vector into
Class B without providing a clearance. I used to base at a class B airport
and always had to be on guard for that. Often, Approach Control would sound
annoyed when I asked for a Class B clearance that hadn't been given. Too bad
for them.
Filing a NASA report would be a very good idea in this instance.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200704/1
Old April 13th 07, 01:36 AM posted to rec.aviation.piloting
Jim Macklin
You must file the NASA report within 10 days of the event,
you said last month, so you missed the deadline for legal
protection. Hope they didn't report you.
"C Booth" wrote in message
heading back to
getting VFR
ENE of
tower, then
heading and asks
ask her to
back. I am
instructions from
and even a
asks me if I
all the
clearance...I
in the
I say,
somewhere?"
ever happened
Needless to
been vectored
given the
clearance
vectors to
I should
the group.
| Cbooth
| SEL MEL Instrument
Old April 13th 07, 02:41 AM posted to rec.aviation.piloting
BT
File the NASA report...
But for what it's worth... even on ATC vectors for a climb, if she did not
say the magic words.. and you as PIC did not ask... PIC is to blame.
would you like a phone number to the Nellis Watch Supervisor?
BT
Cbooth
SEL MEL Instrument
Old April 13th 07, 03:58 AM posted to rec.aviation.piloting
Larry Dighera
On Thu, 12 Apr 2007 16:28:32 -0600, C Booth wrote
in :
Vegas.
Ground Control doesn't issue other than taxi clearances to they?
Were you inside KLAS Class B airspace when you contacted Nellis
Approach?
If she's vectoring you, I believe it is her responsibility to clear
your transitions through B, C and D terminal airspace. I'd have to
consult FAAO 7110.65R to be su
http://www.faa.gov/regulations_polic...a/7110.65R.pdf
I am
Perhaps she was a trainee and her trainer called the fact that she had
failed to specifically issue you Clearance into Bravo airspace.
Sometimes Class Bravo clearance is implied, but it's always best if
you get it explicitly.
Needless to
That's my understanding also.
It's all in FAAO 7110.65R
Maybe I should
I think it's always prudent to file a NASA form. Not only does it
usually save you from the ordeal of an enforcement action, but the
information you provide is used to make the NAS safer.
I believe the ATC tapes are available for ~15 days. You might phone
Nellis approach and arrange to discuss the incident with the
controller. She would normally have to file an FAA form for action to
be taken. She probably didn't do that, or you would have heard those
other little magic words, "Pleas phone ATC upon landing." At least
you'll get a chance to see what's up.
I couldn't agree more. Thanks.
Cbooth
SEL MEL Instrument
Old April 13th 07, 04:45 AM posted to rec.aviation.piloting
TheSmokingGnu
Erk. Class B clearance must always, always, always, always (always) be
given explicitly with "... cleared to enter the Class Bravo
airspace...". Any other usage isn't an implied clearance.
You can get implied clearance through C and D space if they use your
full callsign, but B is the big special 80,000 lbs. gorilla, and needs
full, explicit clearance.
As to the OP, technically speaking it was mostly your responsibility to
get the clearance, but both parties were really at fault, and no real
harm came because of it, so I wouldn't worry too terribly much.
TheSmokingGnu
Old April 13th 07, 11:30 AM posted to rec.aviation.piloting
Larry Dighera
On Thu, 12 Apr 2007 19:45:43 -0700, TheSmokingGnu
wrote in
Not that I disagree with you, but are you able to cite FAA regulations
or orders that support your allegation?
Old April 13th 07, 01:34 PM posted to rec.aviation.piloting
Ron Natalie
wrote in
He can't. There's no rule. The controller should issue VFR clerarances
that way however. Obviously IFR clearances aren't going to sound like
that at all.
The pilot is definitely responsible for the bust, but the controller
rules also prohibit the controller from vectoring aircraft into
airspace without coordinating the transition. Of course it fails
all the time.
Old April 13th 07, 07:32 PM posted to rec.aviation.piloting
Mxsmanic
Ron Natalie writes:
Yes, there is. A specific clearance is required, and a specific phraseology
is used.
Are these Pilots Real? DannyVit Piloting 11 April 17th 11 07:02 PM
The REAL Question Regarding 9/11 is.... BDS Piloting 2 February 23rd 06 06:30 PM
A Question For Real Airline Pilots Blue Simulators 34 September 6th 04 02:55 AM
Flight Simulator for Real Pilots Charles Talleyrand Piloting 29 November 29th 03 04:10 PM
