#131
In rec.aviation.piloting Mxsmanic wrote:
writes: You are talking about a gyro compass. No, I'm not. Yes, you are. A gyro compass is huge, expensive and heavy. But there is none inside an inertial reference platform. An IRS uses laser gyros. They are still big, heavy, and expensive. They can take hours to settle on a usable reading. An IRS can find true north in a few minutes, depending on latitude. An INS system can NOT find true north and requries an external input to tell it where north is. You are clueless. An INS system has to be initialized with it's current position and just tells you where you have moved relative to the starting position. But it also finds true north on its own, without any need for external data. It simply detects the rotation of the Earth, and that gives it an east-west reference, to which true north is perpendicular. No, INS can not find true north, only a gyro compass can find true north. A gyrocompass doesn't work at airplane speeds. You have no idea what you are talking about. Google for it. You'll be surprised. Lets sum up reality versus your babbling ignorance: Only a gyrocompass can find true north. A gyrocompass won't work at all at airplane speeds and is problematic at fast, modern ship speeds. Because a gyrocompass uses the precession caused by the Earth's rotation to find north and the Earth rotates so slowly, it can take several hours for a gyrocompass to settle when first turned on. An INS is a collection of gyros and accelerometers that sense movement. An INS does not contain a gyrocompass. An INS requires an external input to tell it where north is. An INS has to be initialized to tell it it's current position. Once an INS is initialized, it can tell you how far you have moved. An INS has to be periodically updated with it's true position because the gyros, including laser gyros, drift. No GA aircraft and few transport aircraft have INS installed. For how gyrocompasses work: http://en.wikipedia.org/wiki/Gyrocompass http://www.navis.gr/navaids/gyro.htm http://tpub.com/content/administrati...s/14221_74.htm For how INS works: http://en.wikipedia.org/wiki/Inertial_guidance_system -- Jim Pennino Remove .spam.sux to reply. |
#132
#133
writes: I can't think of any local anomaly that is both strong enough and large enough to be anything other than a transitory "burble" at most to the compass of an airplane in flight. Try flying just outside Reno. I have, have you? Did I miss something? -- Jim Pennino Remove .spam.sux to reply. |
#134
Jose writes: "It must be true - I found it on the internet" I think you'll find that the more you research about the geomagnetic field, the less reliable you find it to be for navigation. I think you'll find that if you ever get an education, the less likely you will be to babble nonsense like that. -- Jim Pennino Remove .spam.sux to reply. |
#135
Kev wrote:
On Apr 4, 2:32 am, Tauno Voipio wrote: EridanMan wrote: Why in gods name are VOR's Mag heading based? It's a nuisance for maintenance, but it frees the pilot from calculating the variation at the operative time. Just to off-load the pilot. A good answer. Same for winds in flight, etc. Everything is based on the magnetic to make it easier for the pilot. At least, the pilot of old. If we had 100% reliable aids in the plane, then I suppose you could argue for just following the red line on the electronic map, and never even know what course you're taking ;-) I know, ideally, that means that you can sync your DG and your VOR indicator to fly to a waypoint... except that most VOR's around here have long since fallen behind Magnetic drift... so - now, not only do you have to flightplan in True Heading, convert to Mag Heading to get your vectors, THEN you have to get the corrective factor for each of the VOR's your using for navigation and note that as well? huh? If they are off the mag variation, it is mis-maintenance, and the VOR should be marked defective or taken off-line. VORs are allowed to get +/- 6 degrees off. Seems a lot, but it's only a handful of miles off-course over most VORs' ranges. Anyway, see: http://www.naco.faa.gov/index.asp?xml=naco/faq#q2h Kev This seems too much to match the ICAO specified system accuracy of +/- 5.2 degrees. The system accuracy includes transmitter and receiver errors and the operative margin. The VORs here are adjusted for an error of less than 1 degree at the station, and a flight test is not passed if the error exceeds 3 degrees (except on special terrain cases, which have to be announced by NOTAMs). -- Tauno Voipio tauno voipio (at) iki fi |
#136
![]() "Mxsmanic" wrote in message ... writes: INS is too big and expensive for GA aircraft. That's one reason why I often like to fly big aircraft. Just how big is your desk???? Not all real airplanes have electrical systems. True, and some are powered by rubber bands as well, but there's a lower threshold below which I don't bother. Then how can you be bothered by playing a sim???? |
#137
![]() "Mxsmanic" wrote in message ... Ron Natalie writes: This is makes you look pathetically stupid and is the main reason that most people on this forum are hostile to you. I think that's a bit backwards. People who are stupid are likely to be hostile. Odd..you are clearly the poster child for stupidity, but you don't see hostile. |
#138
![]() "Mxsmanic" wrote in message ... Jose writes: "It must be true - I found it on the internet" I think you'll find that the more you research about the geomagnetic field, the less reliable you find it to be for navigation. That's OK, you can relax anyway. No matter how many hours you sim, you will still find your desk in your bedroom. |
#139
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
