Spinner strobing as a "Bird Strike Countermeasure"
Old December 2nd 07, 11:09 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Logajan
Default Spinner strobing as a "Bird Strike Countermeasure"
The following thread on the Van's Air Force web site was of general enough
interest that I thought it worthwhile to bring it to the attention of other
pilots:
http://www.vansairforce.com/communit...ad.php?t=24147
Would be quite useful if it really worked. Of course there would still be
strikes with inattentive and near-sighted birds. ;-)
Old December 2nd 07, 11:18 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Blueskies
"Jim Logajan" wrote in message .. .
pilots:
I wonder about doing the candy stripe spiral on them, or painting the blades different colors...
Old December 3rd 07, 12:02 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Maxwell
"Blueskies" wrote in message
t...
enough
other
pilots:
There is a design used on the American Airlines (and perhaps others) high
bypass engines that is reported to be effective too. Might check it out at
airliners.com or something. Considering visibility difference and rotation
speed, the design you are testing appears even more visible. My guess is, it
will work.
Old December 3rd 07, 12:08 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Maxwell
"Maxwell" wrote in message
t...
enough
other
pilots:
be
it will work.
http://tinyurl.com/2yjh2c
Old December 3rd 07, 12:59 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Roger (K8RI)
On Sun, 2 Dec 2007 17:02:07 -0600, "Maxwell"
et...
enough
other
pilots:
I rate this things right in there with the old ultrasonic deer
whistles you put in your car grill. Driving down the road was supposed
to put out a noise to scare the deer. Somebody made a small fortune on
those before they proved they don't work.
That's used to let people on the ground know if the engine is still
turning. An engine coasting to a stop is nearly silent and is silent
if you are out on the ramp wearing hearing protection.
Roger (K8RI)
will work.
Old December 3rd 07, 02:17 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Roger (K8RI)
Incorrect. The spiral on the fan hub is a bird deterrent measure. It
has nothing to do with ground personnel.
Old December 3rd 07, 05:01 PM posted to rec.aviation.piloting, rec.aviation.homebuilt
soaringpilot2
The candy stripe spiral on the spinner was a recognition thing, the
Germans started doing that in the summer of '44. The Japanese did
something similar thru the war years by painting the inboard leading
edge of the wing yellow. Quick recognition by your comrades in a
dogfight when head on...
This is the first I've heard of the 1/3 and 2/3's strobe effect, I
thought it was also for recognition...Maybe I'll try it on my 172...
-Ryan
Old December 3rd 07, 01:03 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Roger (K8RI)
On Sun, 02 Dec 2007 22:09:30 -0000, Jim Logajan
pilots:
At cruise RPM that effect would be completely lost. There's not a
bird or human alive that can discern stroboscopic effects of more than
a couple hundred cycles let alone over a 1000. Most of us can't even
discern 60 cps.
Roger (K8RI)
Old December 3rd 07, 02:39 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mike Noel
True, but aren't we talking about 40 cps when the prop RPM is 2400?
Best Regards,
http://photoshow.comcast.net/mikenoel
If any question why we died, tell them, "Because our fathers lied."
- Rudyard Kipling.
"Roger (K8RI)" wrote in message
other
pilots:
discern 60 cps.
Roger (K8RI)
Old December 3rd 07, 03:07 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Maxwell
discern 60 cps.
"Mike Noel" wrote in message
Seems I have heard the 16 cps is all that is required for movies to appear
continuous. I think the human eye loosed it around 12 or 13. However, we
don't seen consciously either. Hence the reason an aircraft propeller will
appear to be revolving slowly backwards at times.
I can say I worked in the engine shop at American for 15 years, and we were
always told it was a very cost effective bird strike tool. But that is no
guarantee. We always did say if you hadn't heard a good rumor my 10:00 am,
then start one.
But then again, it shouldn't be needed by ground personnel. If someone can
look at a high bypass engine and tell if it's turning fast enough to be
dangerous, the need to be teaching English in France or something.
Spinner strobing as a "Bird Strike Countermeasure" Jim Logajan Piloting 259 December 13th 07 06:43 AM
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 11:48 PM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 09:20 PM
Bird strike Bob Chilcoat Piloting 5 September 6th 05 08:05 AM
Bird strike Jase Vanover Piloting 16 May 17th 05 12:44 PM
