The thread on brakes raised a question from the past- why nitrogen in the
tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. |
On Sep 15, 6:09*pm, "Viperdoc" wrote:
The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. |
On Sep 15, 6:20*pm, a wrote:
On Sep 15, 6:09*pm, "Viperdoc" wrote: The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that *the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. I got curious, did a quick check. The process also reduces water vapor, and N2 does not migrate through the rubber as fast as does O2, so pressure stays more predictable. So it's more consistent tire pressure, less corrosion. |
On Sep 16, 8:25*am, a wrote:
On Sep 15, 6:20*pm, a wrote: On Sep 15, 6:09*pm, "Viperdoc" wrote: The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that *the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. I got curious, did a quick check. The process also reduces water vapor, and N2 does not migrate through the rubber as fast as does O2, so pressure stays more predictable. So it's more consistent tire pressure, less corrosion.- Hide quoted text - Dont see why it would reduce water vapour, dry air has no more water than dry nitrogen. and migration or porosity is a function of molecular size. There is not much difference between nitrogen MW 28 and Oxygen MW 32. Terry |
On Sep 16, 6:39*pm, terry wrote:
On Sep 16, 8:25*am, a wrote: On Sep 15, 6:20*pm, a wrote: On Sep 15, 6:09*pm, "Viperdoc" wrote: The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that *the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. I got curious, did a quick check. The process also reduces water vapor, and N2 does not migrate through the rubber as fast as does O2, so pressure stays more predictable. So it's more consistent tire pressure, less corrosion.- Hide quoted text - Dont see why it would reduce water vapour, dry air has no more water than dry nitrogen. and migration or porosity is a function of molecular size. *There is not much difference between nitrogen MW 28 and Oxygen MW 32. Terry- Hide quoted text - - Show quoted text - OK , I will stand corrected, on the porosity, the proper word was permeation and nitrogen is actuallly a larger molecule than oxygen despite its lower molecular weight. Attached link is a really good explanation ..from an expert. oxygen does permeate 3 to 4 times faster through rubber. I guess leakage through the tire would occur even faster in an aircraft tire at altitude due to the driving force of the pressure differential. But still not convinced if its the primary reason.. I think I am leaning towards the fire risk. Anyways its a very interesting aviation topic. Terry http://www.getnitrogen.org/pdf/graham.pdf |
a wrote:
On Sep 15, 6:20 pm, a wrote: On Sep 15, 6:09 pm, "Viperdoc" wrote: The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. I got curious, did a quick check. The process also reduces water vapor, and N2 does not migrate through the rubber as fast as does O2, so pressure stays more predictable. So it's more consistent tire pressure, less corrosion. We bought a new Toyota and the salesman stated the tires were filled with N2 since the molecule was larger and less corrosive than air which contained O2. Now, how easy is it to find N2 around town. I can take it to the airport where the mechanic has a tank. But, all the years of owning a car, I never seem to really have a problem with tires going down that quick. At the 3K oil changes they top them off anyway. I did buy a small compressor for the hangar, but never really used it that much. I have a couple of bikes that I have to air up before each ride. Those tires really loose pressure. I brought the compressor home. -- Regards, Ross C-172F 180HP KSWI |
On Mon, 15 Sep 2008 15:25:21 -0700 (PDT), a wrote:
On Sep 15, 6:20*pm, a wrote: On Sep 15, 6:09*pm, "Viperdoc" wrote: The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that *the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. I got curious, did a quick check. The process also reduces water vapor, and N2 does not migrate through the rubber as fast as does O2, so pressure stays more predictable. So it's more consistent tire pressure, less corrosion. Howevwer even in air the % of O2 is considerably smaller than N2. I practice I've never been able to see a difference. Possibly with the old style "natural rubber" innertubes in aircrat tires it would make a difference, but I doubt any of us would see any difference in todays car and aircraft tires. I've not had to put air in the tires on either car in over two years. It's been over a year on the Debonair and the mains are still up to pressure. The nose gear which still has the old Natural Rubber has to be filled about every two to three months. OTOH I've nver tried N2 in it. Technically O2 leaks about 3 times as fast in Natural Rubber as does N2. However it that proved out in practice we'd actually be purifying the N2 in the tires and after refilling them 3 or 4 times there would be almost no O2 left. Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
On Sep 16, 8:20*am, a wrote:
On Sep 15, 6:09*pm, "Viperdoc" wrote: The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. The legend is that *the oxygen is reacting with the rubber. Even though compressed air has the same fraction of oxygen as does the atmosphere, the fact that it's compressed, it's been argued, increases its reactivity. I can't validate the legend. Thats is not a legend its a fact rubber is very prone to oxidation which is why it contains chemical antioxidants, and the reactivity will be proportional to the concentration , ie pressure of the oxygen. I am not however saying that is the only reason otherwise why dont we put nitrogen in our car tyres. Terry |
"Viperdoc" wrote:
The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. Consumer Reports noted: "The National Highway Traffic Safety Administration (NHTSA) has seen reduced aging of tires filled with nitrogen. Though the data does support that passenger car tires could benefit by all the claims made for nitrogen, tire manufacturers say that they already design tires to perform well with air inflation. And while nitrogen will do no harm, manufacturers say that they don't see the need to use nitrogen, which generally adds $5 or more per tire charge." From: http://blogs.consumerreports.org/car...nitrogen-.html Also CR's Q&A answers imply that if you have a lot of tires (as on a truck) then using N2 may be a net win, but probably not in other cases: "The positive benefits of nitrogen in high(er) service pressure applications, such as used in large truck tires, has been documented in the industry. Our test centered on passenger tires, only. We are not discrediting the use of nitrogen, but it is not a substitute for regular inflation checks." From: http://blogs.consumerreports.org/car...en-tires-.html |
"Viperdoc" wrote in message
... The thread on brakes raised a question from the past- why nitrogen in the tires of big jets and heavies? Air is around 78% nitrogen anyway, and the coefficient of expansion of the remaining 20% that's oxygen can't make that much difference in volume. Why not just use dry air? I couldn't imagine that dry air or dry nitrogen could make that much difference in corrosion, either. I seem to recall someone giving me the rationale for this a long time ago, but also seem to remember thinking it didn't make that much sense at the time. My local automotive tire dealer now has signs up touting the availability of nitrogen. However, I agree with you that dry air should work about as well. The big contributor to pressure change is water--since there isn't enough CO2 in the air for its nonlinearity to be a major factor. The only difference that would make nitrogen seen really beneficial to me would be in the case of an aircraft which is kept hangared and seldom operated. Then, if the tire threads last a number of years, and the tires are sheltered from UV radiation, the inert nature of the nitrogen could be usefull. Peter |
| Thread Tools | |
| Display Modes | |
| Tire inflation with Nitrogen or ? | [email protected] | Home Built | 52 | April 29th 07 05:49 AM |
| Filling with nitrogen | scott moore | Owning | 21 | December 8th 06 08:48 PM |
| 172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 07:28 PM |
