#161
You are completely misinformed again.
On Feb 15, 9:27 pm, Mxsmanic wrote: John Theune writes: You must have incredible vision to see the color of a pilots eyes from more then 1/2 mile away. The upwind leg is on the opposite side of the runway from the downwind at the same distance from the runway as the downwind leg. No, it is not. The upwind leg is aligned with the runway; it includes the final and departure legs of the pattern (some people consider that it includes only departure), and the runway itself. If you're on the upwind leg, you're either landing or departing traffic, or you're about to collide with one of these. There is no leg on the opposite side of the runway. You're not supposed to be on the opposite side of the runway. That's why patterns are designated left or right. An upwind join means that you are flying right into departing traffic. You of course knew this because you had read about traffic patterns and spend 30 seconds googling the term upwind traffic pattern. _Someone_ needs to read a bit more, that's for sure. At least I can't kill anyone in a simulator. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#162
Tony writes:
You are completely misinformed again. Show the error. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#163
Mxsmanic wrote:
John Theune writes: You must have incredible vision to see the color of a pilots eyes from more then 1/2 mile away. The upwind leg is on the opposite side of the runway from the downwind at the same distance from the runway as the downwind leg. No, it is not. The upwind leg is aligned with the runway; it includes the final and departure legs of the pattern (some people consider that it includes only departure), and the runway itself. If you're on the upwind leg, you're either landing or departing traffic, or you're about to collide with one of these. There is no leg on the opposite side of the runway. You're not supposed to be on the opposite side of the runway. That's why patterns are designated left or right. An upwind join means that you are flying right into departing traffic. You of course knew this because you had read about traffic patterns and spend 30 seconds googling the term upwind traffic pattern. _Someone_ needs to read a bit more, that's for sure. At least I can't kill anyone in a simulator. What are your references for this information. Here are two that I just dug off the net http://www.globalsecurity.org/milita.../57-38/Ch3.htm EPARTMENT OF THE ARMY HEADQUARTERS AND HEADQUARTERS COMPANY 1ST BATTALION (AIRBORNE, 507TH PARACHUTE INFANTRY REGIMENT FORT BENNING, GEORGIA 31905 ATSH-TPP-HQ 071A0201 and Here's one you should really appreciate http://www.flightsim.com/cgi/kds?$=main/howto/glossary.htm |
#164
"Mxsmanic" wrote in message
... No, it is not. The upwind leg is aligned with the runway; it includes the final and departure legs of the pattern (some people consider that it includes only departure), and the runway itself. There is no leg on the opposite side of the runway. You're not supposed to be on the opposite side of the runway. That's why patterns are designated left or right. _Someone_ needs to read a bit more, that's for sure. At least I can't kill anyone in a simulator. A Circuit may be left or right of the pattern. The pattern itself is a square (or rectangular) area surrounding the airfield with the runway central to the pattern. Whilst a circuit is only half this area, the pattern encompasses it all. The pattern has 2 sides. a 'live' side, and a 'dead' side. Crash Lander |
#165
John Theune writes:
What are your references for this information. I googled for it. However, after doing a search in all the FAA documents I have on hand, I found _two_ definitions: one is a parallel course to the runway on the opposite side of the downwind, and the other is the course over the runway itself, including final and departure. The diagrams of traffic patterns in most of these documents make no mention of an upwind leg. So there does not appear to be a single definition for the term, unlike most of the other terms referring to a traffic pattern. One thing that is clear, whichever definition you prefer, is that you run an excellent chance of running into someone if you enter the crosswind leg, be it from a parallel upwind leg, or from the congruent upwind leg, or from anywhere else that brings you across the runway centerline. I did find one page that talked about an upwind entry into the crosswind, and it argued that if you are at pattern altitude, you aren't likely to meet other traffic, but that seems like an extraordinarily dangerous assumption given the variability of climb rates, runway lengths, departure points on the runway, and so on. It's even more dangerous if someone decides to go around. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#166
Not for real pilots.
It's been demonstrated again you are in error. You exhibit quite a high noise to signal ratio. On Feb 15, 10:07 pm, Mxsmanic wrote: John Theune writes: What are your references for this information. I googled for it. However, after doing a search in all the FAA documents I have on hand, I found _two_ definitions: one is a parallel course to the runway on the opposite side of the downwind, and the other is the course over the runway itself, including final and departure. The diagrams of traffic patterns in most of these documents make no mention of an upwind leg. So there does not appear to be a single definition for the term, unlike most of the other terms referring to a traffic pattern. One thing that is clear, whichever definition you prefer, is that you run an excellent chance of running into someone if you enter the crosswind leg, be it from a parallel upwind leg, or from the congruent upwind leg, or from anywhere else that brings you across the runway centerline. I did find one page that talked about an upwind entry into the crosswind, and it argued that if you are at pattern altitude, you aren't likely to meet other traffic, but that seems like an extraordinarily dangerous assumption given the variability of climb rates, runway lengths, departure points on the runway, and so on. It's even more dangerous if someone decides to go around. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#167
Crash Lander writes:
The pattern has 2 sides. a 'live' side, and a 'dead' side. The terminology seems appropriate. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#168
... I did find one page that talked about an upwind entry into the crosswind, and it argued that if you are at pattern altitude, you aren't likely to meet other traffic, but that seems like an extraordinarily dangerous assumption given the variability of climb rates, runway lengths, departure points on the runway, and so on. It's even more dangerous if someone decides to go around. Ever heard of a radio? If someone's going around, and you're close enough to be in their way, then you're a) going to hear their calls on the radio, and/or you're looking for traffic anyway. Crash Lander |
#169
... Crash Lander writes: The pattern has 2 sides. a 'live' side, and a 'dead' side. The terminology seems appropriate. Active and non-active. You know very well what I meant. Now you're just being facetious. Crash Lander |
#170
Ever heard of a radio? Ever heard of NORDO? And even with radios, pilots aren't obligated to use them. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Southern California airports have worst runway safety records | Larry Dighera | Piloting | 0 | November 26th 05 04:48 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Airports Rated Critical Unsatisfactory: Given Black Star Rating | Michael Ravnitzky | Piloting | 0 | February 3rd 05 03:34 AM |
IFR hold short line at uncontrolled airports? | Peter R. | Instrument Flight Rules | 30 | June 9th 04 04:47 AM |
fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 09:41 PM |
