#161
wrote)
Normally what happens when thread drift begins is that it increases at an increasing rate such that what was originally zepplin aerodynamics becomes the best recipe for strawberry preserves... So you're saying zeppelins should take advantage of jam-jet propulsion technology? ....when in season, of course Paul-Mont Usually needs to snow twice before I get the drift ~~~~ |
#162
On Aug 11, 9:47 pm, "Bill Daniels" bildan@comcast-dot-net wrote:
... I've already made a cell holder for A123 Systems "A1" cells. That's the lithium phosphate nano cathode one used in 36V DeWalt power tools. You can buy a couple of new DeWalt 36V power packs for $50 or so on Ebay. Then, dismantle the pack to retrieve the individual cells. My pack will be 13.8 volts and 11AH weighing 3 pounds. It will be the same size as a 7AH 12V SLA but weigh less than half as much. Don't forget to add a brick of lead to the bottom of your new battery pack, to keep the CG in the right place ;-) Best Regards, Dave "YO" |
#163
wrote)
In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. Speculate please: 1. Two 3,600 lb cars - good tires 2. Traveling 60 mph (no wind) 3. 4cly - 150 hp (Honda Accords) 3. Flat highway in North Dakota 4. Fuel flow meters hooked up to both vehicles (Honda #1) Driver ................ 105 lbs Fuel .................... 15 lbs TOTAL .............. 120 lbs (1/30th of 3,600 lb car) (Honda #2) Driver ................. 300 lbs Passengers ........ 700 lbs Luggage ............. 100 lbs Fuel ................... 100 lbs TOTAL ............. 1,200 lbs (1/3 of 3,600 lb car) ....BTW, BTDT! g If both vehicles were monitored for 50 miles, would their fuel flow be (approx) the same, in cruise? Paul-Mont |
#164
("Charles Vincent" wrote)
According to SAE studies, aerodynamic drag accounts for 60% of the resistance that must be overcome for highway cruise, with tires being 25% and driveline friction making up the last 15%. Semi: Tires ........... 18 Footprint ..... big per tire Weight ....... 80,000 lbs Drag .......... HUGE!! MPG .......... 5 (loaded) Minivan: Tires ........... 4 Footprint ..... smaller per tire Weight ....... 4,000 lbs (for easy math) Drag .......... MUCH less + no cab/trailer drag MPG .......... 22 I've never really understood why an 800 lb motorcycle/rider gets (only) 50 mpg and a fully loaded semi can get (about) 5 mpg? Motorcycle: Tires ........... 2 Footprint ..... very small per tire Weight ....... 800 lbs (with rider) Drag .......... It's a motorcycle! g MPG ........... 50 Paul-Mont |
#165
Montblack wrote:
("Charles Vincent" wrote) According to SAE studies, aerodynamic drag accounts for 60% of the resistance that must be overcome for highway cruise, with tires being 25% and driveline friction making up the last 15%. Semi: Tires ........... 18 Footprint ..... big per tire Weight ....... 80,000 lbs Drag .......... HUGE!! MPG .......... 5 (loaded) Minivan: Tires ........... 4 Footprint ..... smaller per tire Weight ....... 4,000 lbs (for easy math) Drag .......... MUCH less + no cab/trailer drag MPG .......... 22 I've never really understood why an 800 lb motorcycle/rider gets (only) 50 mpg and a fully loaded semi can get (about) 5 mpg? Motorcycle: Tires ........... 2 Footprint ..... very small per tire Weight ....... 800 lbs (with rider) Drag .......... It's a motorcycle! g MPG ........... 50 Motorcycles have a terrible coefficient of drag given their shape and the shape of the rider. A fully faired bike is much better, but still much worse than most cars. My K1200LT is one of the better motorcycles and its Cd is above 0.5 with the windshield fully lowered and I believe it is closer to 0.6 with the windshield at the highest setting. So even with the relatively small frontal area as compared to a car (although not as much smaller as you might think as the bike is taller than most cars), the drag coefficient is so high that the total drag is quite high in comparison. Matt |
#166
Montblack wrote:
I've never really understood why an 800 lb motorcycle/rider gets (only) 50 mpg and a fully loaded semi can get (about) 5 mpg? Motorcycle: Tires ........... 2 Footprint ..... very small per tire Weight ....... 800 lbs (with rider) Drag .......... It's a motorcycle! g MPG ........... 50 Paul-Mont Check this: http://www.bgsoflex.com/airdragchart.html Matt |
#167
"Montblack" wrote So you're saying zeppelins should take advantage of jam-jet propulsion technology? Oh, isn't that a sweet idea? -- Jim in NC |
#168
In rec.aviation.piloting Montblack wrote:
wrote) In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. Speculate please: 1. Two 3,600 lb cars - good tires 2. Traveling 60 mph (no wind) 3. 4cly - 150 hp (Honda Accords) 3. Flat highway in North Dakota 4. Fuel flow meters hooked up to both vehicles (Honda #1) Driver ................ 105 lbs Fuel .................... 15 lbs TOTAL .............. 120 lbs (1/30th of 3,600 lb car) (Honda #2) Driver ................. 300 lbs Passengers ........ 700 lbs Luggage ............. 100 lbs Fuel ................... 100 lbs TOTAL ............. 1,200 lbs (1/3 of 3,600 lb car) ....BTW, BTDT! g If both vehicles were monitored for 50 miles, would their fuel flow be (approx) the same, in cruise? A pulled out of my ass, wild assed guess is that since you are increasing the load by 33%, then yes, you will see a difference, and at that loading the tires will be visibly deformed. Now, would you care to calculate the energy required to accelerate 3720 pounds to 60 mph versus accelerating 4800 pounds to 60 mph? Assume gasoline is 45 megajoules per kilogram and the engine is 38% efficient. You may neglect all drag for this calculation and express the energy in kilograms of gasoline. -- Jim Pennino Remove .spam.sux to reply. |
#169
("Charles Vincent" wrote) According to SAE studies, aerodynamic drag accounts for 60% of the resistance that must be overcome for highway cruise, with tires being 25% and driveline friction making up the last 15%. Semi: Tires ........... 18 Footprint ..... big per tire Weight ....... 80,000 lbs Drag .......... HUGE!! MPG .......... 5 (loaded) Minivan: Tires ........... 4 Footprint ..... smaller per tire Weight ....... 4,000 lbs (for easy math) Drag .......... MUCH less + no cab/trailer drag MPG .......... 22 I've never really understood why an 800 lb motorcycle/rider gets (only) 50 mpg and a fully loaded semi can get (about) 5 mpg? Motorcycle: Tires ........... 2 Footprint ..... very small per tire Weight ....... 800 lbs (with rider) Drag .......... It's a motorcycle! g MPG ........... 50 The coefficient of drag for motorcycles is usually pretty bad unless they are faired, and it still ain't great. The power required to overcome drag is 1/2(p*v^3*A*C) p is the densitity of the fluid v is the airspeed A is the area C is the coefficient of drag -- Jim Pennino Remove .spam.sux to reply. |
#170
| Thread Tools | |
| Display Modes | |
| Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 02:11 PM |
| World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 02:50 AM |
| Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 04:28 AM |
| Is JB Weld electrically conductive? | Scott | Home Built | 14 | July 13th 04 12:24 AM |
| Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 02:02 AM |
