FAA Operating Limitations
Old January 26th 10, 01:35 PM posted to rec.aviation.soaring
rlovinggood
Default FAA Operating Limitations
My glider has an old Experimental Operating Limitations letter from
the FAA, dated 16 APR 1980. Among other things, it states:
"No person may exceed the designer's or builder's recommended limits
as follows: Maximum gross weight 1,100 lbs..."
Eleven Hundred Pounds? Where did that come from??? My aircraft
manual states the maximum weight of 752 lbs for my LS1-d. NOT ELEVEN
HUNDRED POUNDS!
The Operating Limitations continue,
"...And maximum airspeed in smooth air 121 knots..."
Back to the aircraft manual, the limit is 130 knots.
Why would the FAA, back in 1980, have different limits than the
manufacturer? How could they come up with a weight that is almost 1.5
times greater than what LS said? At 752 lbs, my wing loading (using
9.75 sq meters = 104.95 sq. ft) is 7.2 lbs/sq.ft. and at 1,100 lbs,
the loading is 10.5 lbs/sq. ft.
Don't worry, I don't fly with water and I'm not going over 752 lbs.
Just wondering if anyone might know where the FAA found their numbers.
Ray Lovinggood
Carrboro, North Carolina, USA
Gyrocopter requirements and limitations Andy L Piloting 1 October 28th 08 04:25 PM
Registering a Warbird with the FAA (Experimental Operating Limitations) [email protected] Owning 21 October 11th 05 01:52 AM
changing operating limitations pittss1c Home Built 46 August 22nd 05 04:28 AM
Limitations of Lemon Pledge Jay Honeck Owning 36 May 6th 04 08:44 PM
regs re flying outside the limitations of a plane...? Ron Natalie Piloting 0 July 9th 03 04:12 PM
