Mandatory Radios
Old February 5th 10, 04:16 PM posted to rec.aviation.soaring
JJ Sinclair
Default Mandatory Radios
The majority of clubs and FBO's in Region 11 have gone to a mandatory
radio policy after the recent midair where the tow plane and glider
collided turning final. The tow plane was not radio equipped and
therefore didn't know (hear) that the glider was turning final from
the other direction. That makes 4 fatalities in this region caused by
lack of communication between the tow pilot and glider!
Several clubs are using hand-held radios for ships that don't have
radios. I flew last Sunday with a hand-held radio and it took some
getting use to. First off, where do you put it so you can hear the
speaker? Also, I found transmitting combersome................pick it
up with left hand, turn the mike toward you and squeeze key while
flying with right hand. Then I clipped it to the right side of my
collar using the big spring clip on the radio. That worked well as it
was clase enough to hear and simply rotate and press the mike button
to transmit. I believe students would need some guidance like this to
be able to make the required radio calls using a hand-held radio. It
looks like most tow pilots are using helmets with head-sets so they
can hear their radios. Also, a com-check before takeoff is essential
to make sure both radios are on and working, volume up, squelch set
and on the correct frequency. I used the $200 ICOM from Wings & Wheels
and found it quite satisfactory.
We can survive a lot of things in this sport, but running into each
other isn't one of them!
JJ
Mandatory ADS B Richard[_1_] Soaring 2 October 2nd 08 01:43 AM
Mandatory ELT [email protected] Soaring 9 March 8th 05 04:01 PM
Region 4 S: ELT Mandatory Chris OCallaghan Soaring 14 June 29th 04 08:38 PM
ELT Mandatory ? Jim Culp Soaring 20 June 19th 04 07:40 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 07:22 AM
