Self-launch two-seater
Old August 6th 10, 05:02 PM posted to rec.aviation.soaring
sisu1a
Default Self-launch two-seater
I was a bit scared because Taurus being UL. How good speed-gliding
performance you can realistically get from relatively light glider?
Does anyone have experience how this bird behaves in thermals?
In USA it is not even close to an Ultralight, but can be registered
Light Sport (1000lb difference), and of courser one can also register
it as a normal motorglider as well. It's not light per se', just not
as heavy as most 2 seaters since it only has 15m of wing. The fuselage
shape contributes lift to make up for lack of wing area. I read a
review sometime back that spoke very favorably in it's flight
characteristics, including thermaling.
-Paul
Old August 6th 10, 06:07 PM posted to rec.aviation.soaring
nimbus
There is also the LAK-20 M....
Old August 6th 10, 10:22 PM posted to rec.aviation.soaring
Kevin
The Taurus is "ultralight" in the sense of meeting certain European
licensing classifications. I believe that 4 of the 5 now in the US
are licensed as experimental and the 5th one as an LSA glider. I
understand that the factory is preparing a new manual for countries
like US, in which the gross weight and max payload will be
substantially greater than for the ships licensed in Europe. Empty
weight on my ship is 309 kg / 618 lbs. (including the engine &
ballistic parachute).
The informal consensus seems to be that it has a real world L/D in the
high 30s, which is consistent with my experience.
Thermals nicely. Relatively short wings make for very nice handling,
but of course, you're losing the benefits of longer wings in pure L/D.
I've been very happy with mine so far, other than not flying it
enough....
- Kevin
-Paul
Old August 7th 10, 12:57 AM posted to rec.aviation.soaring
brianDG303[_2_]
licensing classifications. *I believe that 4 of the 5 now in the US
are licensed as experimental and the 5th one as an LSA glider. *I
substantially greater than for the ships licensed in Europe. *Empty
Thermals nicely. *Relatively short wings make for very nice handling,
enough....
- Kevin
-Paul
Here is an write-up of the Taurus-
http://flightlog.seven-alpha.com/taurus.html
F-16 Two Seater Canuck[_2_] Aviation Photos 0 September 3rd 08 03:40 PM
two seater BD5 Philippe Vessaire Home Built 6 October 28th 07 05:28 PM
WTB 2 seater L/S Nav Sleigh Soaring 0 June 11th 06 06:50 PM
WTB L/S Nav 2 Seater Sleigh Soaring 0 May 20th 06 08:28 PM
4-seater Nyal Williams Soaring 54 November 29th 04 10:53 AM
