"john smith" wrote in message ... TripFarmer wrote: What is an acceptable CHT in cruise? How hot can one stay in extended cruise flight? I've got 6 new ones and want to take care of them. I asked those questions to each of the Lycoming and Continental reps at AirVenture a couple of weeks ago. The answers I got were, it depends on the engine and the airframe in which they are installed. You need a copy of the engine manual for your airframe. A range will be given in that reference. I was asking about Continental TSIO-360FB in a 1979 P28T and a Lycoming I0-520K1G5 in a 1978 PA32. I have seen this but never understood it. Why does the maximum allowable CHT depend on the airframe? |
"Stan Prevost" wrote in message ... \ I have seen this but never understood it. Why does the maximum allowable CHT depend on the airframe? Not so much the airframe but where the CHT probe is located relative to the actual head temperatures. |
Stan Prevost wrote:
"john smith" wrote in message ... TripFarmer wrote: What is an acceptable CHT in cruise? How hot can one stay in extended cruise flight? I've got 6 new ones and want to take care of them. I asked those questions to each of the Lycoming and Continental reps at AirVenture a couple of weeks ago. The answers I got were, it depends on the engine and the airframe in which they are installed. You need a copy of the engine manual for your airframe. A range will be given in that reference. I was asking about Continental TSIO-360FB in a 1979 P28T and a Lycoming I0-520K1G5 in a 1978 PA32. I have seen this but never understood it. Why does the maximum allowable CHT depend on the airframe? Baffeling and type of cooling (upflow, downflow, gills, cowl flaps). |
I just don't buy that "airframe" stuff. A cylinder head can only take
so much temperature for so long before it gives in. 400 degrees is 400 degrees no matter what airframe it's in. If I'm wrong please tell me why......... I've got about 15 hours on 6 new Superior Millinieums and just put in my first quart of oil since 2TT. I have a range of temps at cruise from 320 - 380. They dropped a lot after about the first 30 - 60 minutes of break in and seem to have stabilized since to these numbers. The hot one will run 400-410 in a full power climb in my PA28 235. Trip In article , says... TripFarmer wrote: What is an acceptable CHT in cruise? How hot can one stay in extended cruise flight? I've got 6 new ones and want to take care of them. I asked those questions to each of the Lycoming and Continental reps at AirVenture a couple of weeks ago. The answers I got were, it depends on the engine and the airframe in which they are installed. You need a copy of the engine manual for your airframe. A range will be given in that reference. I was asking about Continental TSIO-360FB in a 1979 P28T and a Lycoming I0-520K1G5 in a 1978 PA32. |
TripFarmer wrote:
I just don't buy that "airframe" stuff. A cylinder head can only take so much temperature for so long before it gives in. 400 degrees is 400 degrees no matter what airframe it's in. If I'm wrong please tell me why......... I agree the temperature a cylinder can tolerate probably doesn't depend on the airframe, but the method of measurement might. Where is the CHT probe on the cylinder? Don't know, but maybe Piper puts the probe in one hole, and Cessna in another. |
Dave Butler wrote: I agree the temperature a cylinder can tolerate probably doesn't depend on the airframe, but the method of measurement might. Where is the CHT probe on the cylinder? Don't know, but maybe Piper puts the probe in one hole, and Cessna in another. In a sense, you're probably right. There's a threaded hole in the cylinder head. The probe goes there, no matter what the airframe. The only way the airframe could make a difference is if a) they have the probe in only one cylinder and b) the temperatures on the other cylinders are known to be significantly different. So, if Piper puts the probe in cylinder #1 for one aircraft and cylinder #4 in another, the allowable max temperatures are likely to be different for the two. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
"G.R. Patterson III" wrote in message ... . The only way the airframe could make a difference is if a) they have the probe in only one cylinder and b) the temperatures on the other cylinders are known to be significantly different. And both of the above are the case. Unless you have an engine analyzer the CHT is only measuring one cylinder. They usually try to put it in the hottest cylinder (one of the back ones), but that varies based on how the engine cooling air is designed on the airframe. The oil temperature temps have an even greater variation. |
cylinder head. The probe goes there, no matter what the airframe. The only way the airframe could make a difference is if a) they have the probe in only one cylinder and b) the temperatures on the other cylinders are known to be significantly different. Actually, it can make a difference even beyond that. The fine folks at GAMI (as part of their liquid air project) completely instrumented a few cylinders (dozens of probes each) and went flying. They found 80 degree differences from one side of some cylinders to the other side. So even a threaded CHT probe may or may not be telling you the true temperature of even THAT cylinder. FWIW, GAMI theorizes that this uneven cooling air around each cylinder may be a significant cause of the cylinder operating "out of round" and causing significant scuffing and wear. |
"TripFarmer" wrote: I've got about 15 hours on 6 new Superior Millinieums and just put in my first quart of oil since 2TT. I have a range of temps at cruise from 320 - 380. They dropped a lot after about the first 30 - 60 minutes of break in and seem to have stabilized since to these numbers. The hot one will run 400-410 in a full power climb in my PA28 235. I have the same cylinders in a LYC O-360; they have 500+ hours on them. In order to keep mine below 380 deg., I have to keep the cowl flaps wide open in cruise in summer at 75% power. I can lean the engine in climb for better performance, but it takes careful attention to the mixture to keep the CHTs under 400. -- Dan C-172RG at BFM |
| Thread Tools | |
| Display Modes | |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| High CHTs on Cessna 175 | Ron Natalie | Owning | 2 | September 9th 03 03:14 AM |
| #1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 04:04 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
