1. I always try to discourage people from trying to fly in cloud in gliders, particularly if self teaching. I regard it as too risky, particularly with modern, slippery ships. I have posted to that effect on this forum before, and elsewhere. 2. I do fly in cloud myself when I can. It is legal in the UK, I did have some tuition, and I like to keep in practice. I know several others who do so too. I have a turn and slip (gyro). I also have an electronic attitude indicator, but I find it has too much lag to be sufficient on its own. For all I know there may be better ones with no such lag. 3. I have been told by two pilots of their experience climbing in cloud without a gyro instrument, and I do not doubt they were telling the truth. They told me the technique they used (the same in each case). I am not going to pass it on here. They were talking of older, wooden, draggy gliders, and at least one had really speed-limiting brakes (which in USA are called spoilers) as a safety fall-back. The other may have been flying a glider with what we call spoilers (hinged devices, little brake effect, they just spoil lift on the wing top surface) – I don’t know what you call them in the USA to distinguish them from the paddle-type brakes. 4. As for me – if I had tried cloud flying with no gyro, I wouldn’t tell here anyway. Regards – Chris |
Quote:
Colin Last edited by Ventus_a : April 5th 12 at 06:48 AM. |
On Apr 4, 1:08*pm, Max Kellermann wrote:
Mike C wrote: Thanks to Max and crew for making this version of 6.3 *available for USA soaring pilots. I did not contribute to this version. *It is not an official XCSoar release, even though the publisher confusingly calls himself "XCSoar developers". *I will not provide support for this build. It's open source and that means anybody may publish modified versions. Power to the people :-) Max Thanks for the experimental version Max Thanks for the Horizon Disabled version Rob Dunning. and thanks for the other experimental version by Peter Bradshaw. Your work is appreciated. I hope that covers everyone. Mike Carriw |
At 04:36 05 April 2012, Mike C wrote:
On Apr 4, 1:08=A0pm, Max Kellermann wrote: Mike C wrote: Thanks to Max and crew for making this version of 6.3 =A0available for USA soaring pilots. I did not contribute to this version. =A0It is not an official XCSoar release, even though the publisher confusingly calls himself "XCSoar developers". =A0I will not provide support for this build. It's open source and that means anybody may publish modified versions. Power to the people :-) Max Thanks for the experimental version Max Thanks for the Horizon Disabled version Rob Dunning. and thanks for the other experimental version by Peter Bradshaw. Your work is appreciated. I hope that covers everyone. Mike Carriw There is a very clever App for the iPhone which provides an AH. I have tested this in the air and it does work provided it is set up to do so. Having said that if I need to decsend through cloud I will stick with the benign spiral. I had a friend who regularly flew in cloud with no gyro instruments, it is alleged he relied on a gimballing compass. |
On Apr 5, 4:51*am, Don Johnstone wrote:
At 04:36 05 April 2012, Mike C wrote: Having said that if I need to decsend through cloud I will stick with the benign spiral. Benign becomes unbenign in turbulence. bumper |
At 16:04 05 April 2012, bumper wrote:
On Apr 5, 4:51=A0am, Don Johnstone wrote: At 04:36 05 April 2012, Mike C wrote: Having said that if I need to decsend through cloud I will stick with the benign spiral. Benign becomes unbenign in turbulence. bumper If there was turbulence I would not find it necessary to descend though cloud :-) |
Those 6.3 are worth nothing because they are not released by the software
authority. Which means that ideally anybody may take those "clean" versions and add back the AH. The software authority is declaring which version is approved for flight, and how to verify it is the correct one. A faked version will be different in size, different in checksums, and for sure won't be downloaded from the official source. Can pilot still cheat? Sure of course, unless the OO are checking each pilot at the contests. But if caught, they have no excuses. So eventually it will be the pilot to break the rules, not the software. "Mike C" ha scritto nel messaggio ... Thanks to Max and crew for making this version of 6.3 available for USA soaring pilots. Just downloaded the program for the Streak and hope to fly with it later this week. Your efforts are VERY MUCH APPRECIATED! Thanks you. Mike Carris |
Oh and before "someone" ask, yes it is possible to create a forked version
not released by xcsoar software authority. In that case, it must be changed for name, and in order to be a real software authority there should be evidences of a real organization, a download and web site, and these kind of things. Otherwise we would have one software authority every developer, and the RC may face hundreds of authorities, each one with a different software name. "PCool" ha scritto nel messaggio ... Those 6.3 are worth nothing because they are not released by the software authority. Which means that ideally anybody may take those "clean" versions and add back the AH. The software authority is declaring which version is approved for flight, and how to verify it is the correct one. A faked version will be different in size, different in checksums, and for sure won't be downloaded from the official source. Can pilot still cheat? Sure of course, unless the OO are checking each pilot at the contests. But if caught, they have no excuses. So eventually it will be the pilot to break the rules, not the software. "Mike C" ha scritto nel messaggio ... Thanks to Max and crew for making this version of 6.3 available for USA soaring pilots. Just downloaded the program for the Streak and hope to fly with it later this week. Your efforts are VERY MUCH APPRECIATED! Thanks you. Mike Carris |
Last month, the XCSoar team considered and declined to publish a version of XCSoar with no horizon. For US competition pilots, I have published an unofficial version of XCSoar with no horizon called "XCSoar-rd No Horizon." The US Rules Committee has agreed to accept this version published and maintained by Robert Dunning (me) as a compliant version of the software for US competitions.
"XCSoar-rd No Horizon" is available for download on the Android Market; for non-Android devices at http://xcsoar-robd.wikispaces.com/XCSoar-rd+No+Horizon . This software is the current version of XCSoar patched to remove the horizon feature. I shall republish this version for each new release of XCSoar excluding alpha and beta releases. See the wikispaces for more info.. Personally, I'd prefer to fly with an artificial horizon in the unlikely event that I am forced into a cloud; but for now I choose to fly in competitions without one. Rob Dunning |
On Apr 13, 7:17*am, wrote:
Last month, the XCSoar team considered and declined to publish a version of XCSoar with no horizon. *For US competition pilots, I have published an unofficial version of XCSoar with no horizon called "XCSoar-rd No Horizon.." *The US Rules Committee has agreed to accept this version published and maintained by Robert Dunning (me) as a compliant version of the software for US competitions. "XCSoar-rd No Horizon" is available for download on the Android Market; for non-Android devices athttp://xcsoar-robd.wikispaces.com/XCSoar-rd+No+Horizon. *This software is the current version of XCSoar *patched to remove the horizon feature. *I shall republish this version for each new release of XCSoar excluding alpha and beta releases. *See the wikispaces for more info. Personally, I'd prefer to fly with an artificial horizon in the unlikely event that I am forced into a cloud; but for now I choose to fly in competitions without one. Rob Dunning Thanks again Rob. |
| Thread Tools | |
| Display Modes | |
| gliding for the disabled | Paul T[_4_] | Soaring | 5 | January 28th 12 05:53 PM |
| For disabled veterans: a study on coping | Veteran Daughter | Naval Aviation | 0 | November 4th 06 11:41 PM |
| Emergency swimming ascent from a disabled sub | Jack | Naval Aviation | 6 | January 11th 05 05:13 AM |
| gliding for disabled people | Ralf S. | Piloting | 8 | February 11th 04 04:22 AM |
| Options for disabled glider pilot | Allan Smits | Soaring | 7 | August 28th 03 05:19 PM |
