Using the magenta circles
Old April 4th 04, 04:29 AM
Ace Pilot
That was my impression, too, CJ. And I'm in the Midwest where we don't
have to worry about mountains. I just have a hard time picturing
someone following their progress on a sectional flying under a ceiling
of 1,000 feet and dipping below 700 feet AGL everytime they approach
an airport with a magenta circle around it.
"C J Campbell" wrote in message
There are people who try to remain in class G airspace in order to stay VFR,
including those in the pattern, but I have found it to be impractical in
many respects. If it is that bad you spend too much time dodging clouds to
get any serious pattern work done. The terrain around here is very
mountainous, which severely restricts how far you can fly and stay VFR in
weather like that. In this area it seems mostly useful to seaplanes and
charter pilots flying around the San Juan Islands.
Old April 2nd 04, 07:03 PM
Ron Natalie
"Ace Pilot" wrote in message =
But I was curious to know if there are pilots that take full advantage
of this distinction. Does anyone actually make use of the Class E/G
boundaries depicted on sectionals? If so, how? I suspect the most
common use is doing T&Gs in the pattern below 700 feet AGL when the
weather is marginal. Other uses?
Those circles aren't to keep VFR pilots safe when the weather is marginal.
They are to lower the floor of controlled airspace for the benefit of IFR
pilots.
This accomplishes two things:
1. Allows ATC to provide control to lower altitudes, primarily
separation from other IFR aircraft.
2. Makes sure any there is sufficient visibility / cloud clearance
for visual separation techniques to be used between any
VFR aircraft that might be present.
Old April 2nd 04, 07:12 PM
Steven P. McNicoll
m...
pilots.
Changing weather has no effect on the floor of controlled airspace.
Old April 3rd 04, 05:04 AM
BTIZ
ink.net...
m...
marginal.
IFR
pilots.
There he goes again...
But I did not think he said anything about changing the floor of the
airspace for weather, he stated that the lower floor provides transistions
for IFR pilots to get close to the airport, and CLEAR OF VFR traffic in
marginal weather, that should be remaining in Class G and not Class E where
the approach may dump them off.
BT
Old April 3rd 04, 05:14 AM
Steven P. McNicoll
"BTIZ" wrote in message
news:vJqbc.69606$1I5.24219@fed1read01...
where
He said; "Those circles aren't to keep VFR pilots safe when the weather is
marginal. They are to lower the floor of controlled airspace for the
benefit of IFR pilots."
Old April 3rd 04, 02:22 PM
mike regish
Exactly.
Even I knew what he said as well as what he meant.
mike regish
nk.net...
transistions
where
Old April 5th 04, 05:11 PM
Ron Natalie
"Steven P. McNicoll" wrote in message nk.net...
where
Correct. The transition area lowers the floor of controlled airspace. I never
said it had anything to do with changing weather conditions. The first sentence
was to refute the hypothesis of the original poster.
Old April 5th 04, 05:09 PM
Ron Natalie
"Steven P. McNicoll" wrote in message ink.net...
m...
pilots.
I never said it did.
Old April 5th 04, 08:01 PM
Steven P. McNicoll
m...
Well, if you didn't, then somebody else is posting here under the name "Ron
Natalie".
Ice meteors, climate, sceptics Brian Sandle General Aviation 43 February 24th 04 12:27 AM
