Cross country question? How is it done today?
Old September 11th 13, 07:08 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
Default Cross country question? How is it done today?
On Wednesday, September 11, 2013 1:54:37 PM UTC-4, Dan Marotta wrote:
You got it right when you said that you monitor whether the intended landing
field is rising or lowering in your windscreen...
Thank you Sir.
Tom
Old September 11th 13, 09:00 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
flgliderpilot wrote, On 9/11/2013 8:54 AM:
What happens if your GPS dies?
Same things that happens if my ruler ends up behind my seat, or I
make a gross error in the slide rule calculations. I fly field to
field, until I realize I am not going to make it to the next field
(kinda easy to see, the field is rising in my canbopy). I pick one of
the 3 fields I have selected as a possible landout for this scenario,
and I land in it.
That's one good solution. I currently carry charts as a backup, because
I used them for about 15 years before Loran, then GPS became options, so
I know how to use them well.
Even so, next year I plan to ditch the charts, and carry another,
independent, flight computer. It might be a Butterfly or ClearNav vario
with battery backup, an app on a smartphone/tablet thingy, or maybe a
PNA running XCsoar.
email me)
Old September 11th 13, 09:29 PM posted to rec.aviation.soaring
Daniel Sazhin
Get out your spare batteries And when those die, pillage the ones in the
oxygen system. Ask me how I know.
Regards,
Daniel
Old September 11th 13, 10:48 PM posted to rec.aviation.soaring
BobW
On 9/11/2013 10:53 AM, Soartech wrote:
Snip... I can't even imagine unfolding a map in the confines of my
sailplane.
Not to be contentious, but why would anyone seriously consider "unfolding a
map" in the confines of a sailplane? I certainly never did. I simply
pre-folded my sectional to place my launch site more or less in the middle of
a flat rectangle of map, folded wisely (as in, if I flew off the pre-selected
area, the next en-route area was no more than a fold away [sometimes two, if I
wished to keep my map rectangle the same size]), and occasionally hauled it
out as necessary (usually to double-check a town or distance). In less
familiar to me areas, I sometimes used my non-stick thumb to keep my place on
the sectional.
It's not as if glider XC speed-made-good is fast enough to warrant constant
refolding. Point being if refolding really is a problem, something needs to be
rethought...
Kinda-sorta related to the original question, try not and overthink XC issues.
Priority One is always to soar - as in, remain aloft. All the other stuff
merely tags along...navigation, can I get "there," O2 altitude (I know, not
generally a concern in FL), communication, speed made good, etc., etc.
Priority Two is to always be prepared (mentally and physically - as in you can
actually GET to your chosen field) to safely land along the way, because if
you fly XC you ARE going to make off-field landings, regardless of ship type.
To think otherwise is to make a serious mental error.
How you accomplish "priorities 3 through infinity" should reflect how you
think and interact with "all your soaring accoutrements." KISS is good, IMHO.
For example, I've never found it difficult/onerous to perform mental glide
calculations while on course. "X miles per thousand feet" and a decent
awareness of where I am (no cheating; you're AT wherever it is you're directly
above, NOT what you can see at some slight angle!) was/is dirt simple for me.
Where I can get from "there" sorts of "glider calculations" aren't
fundamentally different than is estimating where I plan to gas up the vehicle
when driving through western boonies...merely the view is distinctly more
pleasurable!
Bob - simple is good - W.
P.S. It would be fascinating to know the rates of airspace violations by
glider guiders, pre- and post-GPS. Even a cursory reading of contest reports
and scores on the SSA website quickly reveals a continuing litany of "airspace
violation penalties." GPS = "complete navigational precision?" Not!
Old September 11th 13, 10:54 PM posted to rec.aviation.soaring
Tony[_5_]
sailplane.
the sectional.
rethought...
pleasurable!
The GPS just makes the airspace violation much easier to prove.
I started off without a GPS but that was only because I couldn't afford one.. Now I don't leave home without it. In a 1-26 though, it's not too hard to tell whether or not you can glide to the next field. You don't need an advanced glide computer. If you can't see it you can't make it and if you can see it you might be able to make it. The only exception is if you can't see it because the nose is in the way, in which case you probably can make it. These same rules apply when I fly the Cherokee XC. Have fun!
Old September 12th 13, 12:18 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
reports and scores on the SSA website quickly reveals a continuing
litany of "airspace violation penalties." GPS = "complete navigational
precision?" Not!
Indeed, but there are different sorts of GPS units. If you ask that
question of a pilot flying with a vanilla device such as a Garmin GPS II+
or eTrex which points at your next waypoint and might tell you your cross
track error if you're lucky, I think the answer is that it doesn't do
anything more to keep you out of airspace than a map does.
However, if you're using even a very cheap satnav that is running LK8000,
XCSoar or equivalent with up to date map and airspace files and you've
set the airspace warnings appropriately, i.e. at least 500 feet vertical
warning and 60 seconds horizontal warning, then its very much easier to
stay clear of airspace.
Both programs will suppress airspace you're not in danger of entering:
this keeps the screen uncluttered. But, if you get within the vertical or
horizontal warning distances the airspace will be shown and an audible
alert is sounded.
In the UK its also possible to download a file containing plottable NOTAMs
for the day and to install that alongside the static airspace file for
use by XCSoar, LK8000, etc. This is excellent for avoiding temporary
NOTAMed airspace around air shows, major sporting events, etc.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 12th 13, 12:46 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
BobW wrote, On 9/11/2013 2:48 PM:
sailplane.
"unfolding a map" in the confines of a sailplane? I certainly never did.
I simply pre-folded my sectional to place my launch site more or less in
the middle of a flat rectangle of map, folded wisely (as in, if I flew
off the pre-selected area, the next en-route area was no more than a
fold away [sometimes two, if I wished to keep my map rectangle the same
size]), and occasionally hauled it out as necessary (usually to
double-check a town or distance). In less familiar to me areas, I
sometimes used my non-stick thumb to keep my place on the sectional.
You must have fly in very different places than I do, and you must fly a
much lower L/d glider. Keeping the map(s) in the right place was
constant struggle for me, even in relatively roomy cockpits like the Std
Cirrus and ASW 20. and a huge pain in the 301 Libelle. Flying in places
like Nevada with a high performance glider means my airport can be 60 or
70 miles away and in reach, but it's on the other side of the fold.
Unfold, you say? Well, then my alternate, which might be behind me,
disappears.
Worst case: fly where four maps come together - super hassle trying keep
track of where I am and what my options are.
glide calculations while on course. "X miles per thousand feet" and a
decent awareness of where I am (no cheating; you're AT wherever it is
you're directly above, NOT what you can see at some slight angle!)
was/is dirt simple for me. Where I can get from "there" sorts of "glider
calculations" aren't fundamentally different than is estimating where I
plan to gas up the vehicle when driving through western boonies...merely
the view is distinctly more pleasurable!
Sure, it's easy in flat lands, but not where there are mountains. I
can't use the distance/elevation of the airport, but have to use the
distance/elevation of somewhere along the mountain ridge that's between
me and the airport. That ups the mental effort a lot.
Agreed! But ... you find GPS complicated and maps simple; I find the
reverse.
precision?" Not!
The rates are much lower now, because now it's easier to avoid
unintentional violations, and pilots are much more motivated to avoid
intentional violations because they know they will be caught.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old September 12th 13, 12:50 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Martin Gregorie wrote, On 9/11/2013 4:18 PM:
precision?" Not!
snip
Thanks to Lynn Alley, US pilots can now do the same thing. With all the
fires we had in the West this year, getting the TFRs on the screen was
very useful.
email me)
Old September 12th 13, 12:58 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Tom, just remember if you land in a farmers field here is what you do. As he approaches in his Pick em up truck, get down on your knees, close your eyes, clasp your hands in front of you and say, "heavenly father, I thank you for having this wonderful farmer's field here for me to land in. I'm sorry if I scared his prized Hereford bull, I didn't mean to. I'm sure my insurance company will pay for any damages, AMEN." Also remember that if he is wearing a cowboy hat he is a Cracker, a baseball cap means he is a red neck and no hat means he is from New York and doesn't want to look like a Cracker or Red Neck. Call me if it's a Cracker or Red Neck, I can deal with them for you....a New Yakker and you are on your own.
Walt
Old September 12th 13, 12:59 AM posted to rec.aviation.soaring
Dave Springford
Understood, but when heading into a headwind or a cross wind, are you doing these arrival altitude calculations for the nearest airport in the cockpit? Ground school had us pre-calcualate these, but conditions change, and if off course, nearest airport changes also.
Hi Tom,
While airport hopping, or hoping as the case may be, is a technique that soothes the neophite cross-country pilot, in the long run it is counter-productive as it has you focus on the wrong things, such as you mention above.
You do not NEED to be able to glide to an airport at all times, but you do NEED to be able to glide to a landable field at all times. So, forget about continuous calculations to each airport enroute. Do the planning pre-flight and use those numbers. As you are flying, continually assess the conditions, your progress and availability of suitable landing options.
Of course, in some parts of the world, airports are the only option and you need to be able to reach a landable option. In FL, you should have plenty of field options. Sure, fields are inconvenient, but it's all part of cross-country soaring.
First solo cross-country flight completed - question Bertie the Bunyip[_25_] Piloting 19 March 13th 08 07:17 PM
Cross country in the 1-34 mat Redsell Soaring 3 October 22nd 04 04:56 PM
a different cross-country time question Arden Prinz Piloting 3 December 29th 03 01:17 AM
A 4,200 NM cross-country Phil Verghese Piloting 0 September 1st 03 10:03 PM
Got my ticket.... now what (the cross-country question) bdl Piloting 6 July 13th 03 02:06 AM
