Master Switch
Old October 23rd 13, 07:34 PM posted to rec.aviation.soaring
JS
Default Master Switch
Sorry, the line looked vertical before shipping.
Old October 24th 13, 01:10 AM posted to rec.aviation.soaring
son_of_flubber
I would put a fuse downstream of the PV charger. If it develops a short, your whole system dies.
Old October 24th 13, 02:01 AM posted to rec.aviation.soaring
Dan Marotta
Thanks Kirk,
The panel on my LAK is incredibly small and I'm pulling out my hair trying
to figure out where to cram terminal strips.
"kirk.stant" wrote in message
On Thursday, October 17, 2013 9:10:25 AM UTC-5, Dan Marotta wrote:
Or I could simply divide my equipment across two (or three) busses and
then
rely on the load division to allow the batteries to last an entire
flight.
Dan, that's how I've had my LS6 setup for over 13 years and it has worked
just fine so far.
2 separate busses, one for each battery, with load divided as equally and
logically as possible (split varios and loggers, for example).
In addition, the master switch for each buss can also select either
battery, so if one battery fails (forgot to charge it?) the essential
instruments can be powered by the remaining battery.
Probably WAY over-engineered, but it was fun to wire up and has worked as
designed so far (ugly to look at, though - bit of a spaghetti factory
behind that small LS6 panel that I want to clean up some day...).
Kirk
66
Old October 24th 13, 02:04 AM posted to rec.aviation.soaring
Dan Marotta
Those switches look like what I used as my new master switch, except mine is
DPDT. I could use one to power two separate busses from two separate
batteries.
"JS" wrote in message
How about this, diagram below.
Each battery should have its own fuse.
Switches are drawn as -o\-
Vertical line is the Master bus.
Optional PV charge controller charges the active battery, whether avionics
are on or off.
I'd suggest locking switches like Alcoswitch MTL106D available from Mouser
for $12.60.
Bat 1 -----o\-----|
Bat 2 -----o\-----|
Bat 3 -----o\-----|
|-----o\----- Avionics
PV Charger -------|
Old October 24th 13, 04:15 AM posted to rec.aviation.soaring
JS
Right you are, Flub.
As well as the individual loads.
Old October 24th 13, 06:55 AM posted to rec.aviation.soaring
Alan[_6_]
In article JS writes:
Optional PV charge controller charges the active battery, whether avionics are on or off.
I'd suggest locking switches like Alcoswitch MTL106D available from Mouser for $12.60.
Bat 1 -----o\-----|
Bat 2 -----o\-----|
Bat 3 -----o\-----|
PV Charger -------|
I would seriously recommend against this.
If you only turn on the avionic load switch, with no batteries in
the circuit, the avionics will see the full open circuit output of
the solar panel.
Many "12 volt" panels deliver in the vicinity of 21.6 volts open
circuit -- even if not that high, they can easily be enough to damage
electronics.
Charge should be applied through a charge controller, so the panel
doesn't overcharge and cook the battery, and should be applied in
such a way that it cannot be applied directly to the load alone.
Alan
Old October 24th 13, 11:45 AM posted to rec.aviation.soaring
Jim White[_3_]
If anyone is interested my panel wiring can be found he
www.boffins.co.uk/downloads/j1mwiring.pdf
Old October 24th 13, 03:55 PM posted to rec.aviation.soaring
Dan Marotta
Very nice, Jim. I'm going to save a copy of that!
"Jim White" wrote in message
Old October 24th 13, 10:17 PM posted to rec.aviation.soaring
John Strzebrakowski
I have just rewired my Lak19T and have shared your frustration with the
small panel. I have Butterfly vario, Butterfly dispaly for powerflarm,
ClearNav vario and display (remotely mounted, Oudie (remotely mounted) ASI,
T/S, Radio and Altimeter all packed in running off two extra batteries
mounted 'in' the wheelbox. The standard batteries and mountings supply the
engine management.
For the instruments two terminal strips are mounted at the side of my knees
in the sloping part of the panel and the common earth sits on the floor of
the panel behing the ASI.
There are two way switches and fuses for each instrument. A master switch
each for engine and instrument circuits.
Have fun i did. i am sending a photo of the panel but photo of the rear of
the panel or a circuit diagram will take a little longer.
Oh i forgot there is panel space for a transponder display but sadly not a
main unit but i think this might be able to go on the cockpit floor behind
the panel unit if i eventually fit one.
Strzeb
At 01:01 24 October 2013, Dan Marotta wrote:
Thanks Kirk,
then
flight.
worked
just fine so far.
and
as
Kirk
66
Old October 27th 13, 01:47 AM posted to rec.aviation.soaring
JS
Sorry to confuse.
There's a Strobl OS2H charge controller on the glider installations:
"Optional PV Charge Controller" Abbreviated like the fuses and connectors are in the text-only drawing.
Bat 1 -----o\-----|
Bat 2 -----o\-----|
Bat 3 -----o\-----|
PV Charger -------|
the solar panel.
electronics.
Alan
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (1/3) Glen in Orlando[_3_] Aviation Photos 2 July 8th 12 10:23 PM
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (3/3) Glen in Orlando[_3_] Aviation Photos 0 July 1st 12 01:14 AM
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (2/3) Glen in Orlando[_3_] Aviation Photos 0 July 1st 12 01:14 AM
Source for PA28-180 split master switch Mike Noel Owning 3 October 5th 05 02:29 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 01:46 AM
