#11
"John R. Copeland" wrote: "Icebound" wrote in message ... The remainder of the article describes the 1-nm or 2-nm offsets allowed, and only to the right of centerline, with effective date of June 10, 2004. The name of this concept is "Strategic Lateral Offset Procedure", so everyone can understand they've now added SLOP to the route system! As Dave Barry might say, I am not making this up. ---JRC--- Keep in mind those offsets are in oceanic airspace where the route width is 25 or 30 miles, centerline to edge. Along a domestic airway, offsets of those magnitude would be far too large. An offset of 1/10 of a mile would probably be effective without creating an issue with compliance with FAR 91.189. (although the feds might not buy that rationale ;-) |
If the weather is IMC you are well advised to remain on centerline. If it is
VMC, and your equipment will support parallel track offset, then 1/10 of a mile is probably going to mitigate your concerns. But, if operating IFR it is essential to terminate offset operations before beginning an instrument approach procedure. If your equipment won't support parallel offset, then your only remaining option is to fly the autopilot in heading mode and try to keep the XTRK error at some value approximating 1/10 of a n.m. Icebound wrote: In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). So an eastbound VFR/IFR aircraft descending from 7500/7000 to his destination, was more than likely to avoid traffic... on the reciprocal track passing him by at 6500 or 6000... by some significant horizontal error-distance, even if they didn't see each other (big sky theory :-) ). GPS horizontal accuracy with WAAS is already in the order of magnitude of a Cessna's wingspan, and some are talking about getting it down to mere inches. So the question is: If my Westbound Cessna at 6000 feet (with the autopilot keeping it happily on the GPS-track centerline) meets the descending Bonanza on the reciprocal track between the same two airports (using a similar GPS/a-p combo), there is a distinct possibility that the horizontal clearance may be zero... ...so is there anything in the current crop of GPS and/or Autopilot systems that allow me to maintain a small cross-track error of my choosing, without actually entering off-navaid-off-airport waypoints? ...or do we care; am I overly concerned??? |
Stan Gosnell wrote: The Trimble 2102 has it, and so do most other units. Do you know whether the Garmin 400/500 series (other than the 480) have it? |
So the question is: If my Westbound Cessna at 6000 feet (with the autopilot keeping it happily on the GPS-track centerline) meets the descending Bonanza on the reciprocal track between the same two airports (using a similar GPS/a-p combo), there is a distinct possibility that the horizontal clearance may be zero... ...so is there anything in the current crop of GPS and/or Autopilot systems that allow me to maintain a small cross-track error of my choosing, without actually entering off-navaid-off-airport waypoints? ...or do we care; am I overly concerned??? As others have pointed out, the GNS 480/CNX 80 does allow a cross-track error. I did want to make one small philosophical point...here in the deep south, we generally get direct routing. If you have the capability, and you ask for the direct routing, you generally are increasing your safety (by an admittedly tiny amount). Further, anyone who is flying VFR and uses the airways is also increasing his/her risk by that same small amount. I do doubt that ATC will descend you through another aircraft on the same airway, so the chances of meeting an IFR aircraft is diminishingly small, but your concern is most likely regarding the VFR aircraft sharing the airway. Hence this discussion is of the "how many angels can dance on the head of a pin" sort...making it perfect for USENET. And the take-home points are(IMO) fly direct whenever allowed. Generate your courseline from some NON-standard point. That is, don't go direct from some intersection or from the runway...go from some offset point...avoiding the other guy (most likely VFR) doing the same thing from your destination. Don't use airways unless you must. And when you fly the Atlantic (in a non-radar environment)...or the non-radar environments of the USA...use SLOP! Jim |
Jim Harper wrote: . And when you fly the Atlantic (in a non-radar environment)...or the non-radar environments of the USA...use SLOP! SLOP is approved for oceanic. Do you know if it is approved for non-radar environments of the USA? If so, what are the numbers to use? How do I determine when I am in a non-radar environment in the USA? |
[how and whether to fly an offset on a GPS track]
Just hand fly. You can hand fly any offset you like. Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
I noticed the later posts referenced a set of "rules" for setting up the
"error", but absent those, you are back to the same old game of chance. What's to prevent another pilot from picking a corresponding "error" that would still maintain the head-on courses? And I don't know if this is a trick question, but if you are at 6000 (no +500) wouldn't you be on an IFR flight plan, talking to ATC, and receiving traffic advisories? "Icebound" wrote in message ... In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). So an eastbound VFR/IFR aircraft descending from 7500/7000 to his destination, was more than likely to avoid traffic... on the reciprocal track passing him by at 6500 or 6000... by some significant horizontal error-distance, even if they didn't see each other (big sky theory :-) ). GPS horizontal accuracy with WAAS is already in the order of magnitude of a Cessna's wingspan, and some are talking about getting it down to mere inches. So the question is: If my Westbound Cessna at 6000 feet (with the autopilot keeping it happily on the GPS-track centerline) meets the descending Bonanza on the reciprocal track between the same two airports (using a similar GPS/a-p combo), there is a distinct possibility that the horizontal clearance may be zero... ...so is there anything in the current crop of GPS and/or Autopilot systems that allow me to maintain a small cross-track error of my choosing, without actually entering off-navaid-off-airport waypoints? ...or do we care; am I overly concerned??? |
Bill Denton ) wrote:
And I don't know if this is a trick question, but if you are at 6000 (no +500) wouldn't you be on an IFR flight plan, talking to ATC, and receiving traffic advisories? In the US and outside of class B airspace, it is the pilot, not ATC, who is ultimately responsible for IFR/VFR traffic separation. A VFR traffic advisory to an IFR aircraft is a courtesy offered by ATC; it is not a guarantee. -- Peter |
"Peter R." wrote in message ... Bill Denton ) wrote: And I don't know if this is a trick question, but if you are at 6000 (no +500) wouldn't you be on an IFR flight plan, talking to ATC, and receiving traffic advisories? In the US and outside of class B airspace, it is the pilot, not ATC, who is ultimately responsible for IFR/VFR traffic separation. A VFR traffic advisory to an IFR aircraft is a courtesy offered by ATC; it is not a guarantee. -- Peter You might want to rethink your reply. A pilot in clouds or other IMC cannot provide separation to any traffic he cannot see. |
| Thread Tools | |
| Display Modes | |
| Can GPS be *too* accurate? Do I need some XTE?? | Icebound | Instrument Flight Rules | 82 | November 22nd 04 09:01 PM |
| General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 2nd 04 12:16 AM |
| How accurate was B-26 bombing? | ArtKramr | Military Aviation | 59 | March 3rd 04 11:10 PM |
| Local TV News ran an accurate story about airframe icing last night | Peter R. | Piloting | 5 | January 29th 04 02:01 AM |
| VOR and reverse sensing | Koopas Ly | Piloting | 40 | August 25th 03 02:26 AM |
