I need help with PowerFlarm problem
Old July 19th 14, 09:06 PM posted to rec.aviation.soaring
Andy K
Default I need help with PowerFlarm problem
Here is my configuration:
PowerFlarm brick and Trig T22 mod S transponder. PowerFlarm configured with the transponder code to disregard it.
I get constant notifications of my own transponder; yesterday probably 100 times, not kidding. I will have to unplug LX9000 from the PowerFlarm as it is not possible to use it as the PowerFlarm warnings just take over the screen.
I have had this problem with ASG-29 and ASH-26E. In the first glider the PowerFlarm antenna was set up high over the glare shield in the second glider (the 26E) the PowerFlarm antenna is in the fuselage cone as front part of the fuselage does not have any carbon. The 26E has a transponder antenna at the gear door. There is no carbon interference between the two antennas. I have good coverage as proven by experience flying with others.
Any help how to get to the root cause of this problem is appreciated. I can accept sporadic alerts but yesterday it was simply unacceptable.
On the other hand it was really nice to see a couple of twins with ADS-B out doing big circles around me.
AK
PowerFlarm v3.40 Auxvache Soaring 35 April 24th 14 03:38 PM
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 05:56 PM
PowerFLARM 2.71...WTF? [email protected] Soaring 40 May 2nd 13 03:32 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
